Thanks Thanks:  21
Likes Likes:  31
Page 1 of 7 12345 ... LastLast
Threads 1 to 20 of 139
SATELITI: Discutii & Suport
  1.   Sticky Threads
  2. Sticky Thread Sticky: Tunerul USB sundtek DVB-C/DVB-T
    Started by motoru, 08-11-10 19:34
    3 Pages
    1 2 3
    11-03-14, 03:38 Go to last post
  3. Sticky Thread Sticky: Vu+ Duo II ( second edition ) info
    Started by SuperSonic, 26-05-12 19:32
    5 Pages
    1 2 3 ... 5
    27-01-14, 00:25 Go to last post
  4. Sticky Thread Sticky: VU+ Duo concurent Dm8000
    Started by mirel, 14-01-10 11:24
    22 Pages
    1 2 3 ... 22
    01-12-11, 11:22 Go to last post
  5.   Normal Threads
  1. Post Daca este cineva dispus...
    Started by shadowman, 17-11-22 15:18
    20-11-22, 11:10 Go to last post
  2. ajutor
    Started by w2kclan, 18-12-21 12:09
    20-12-21, 22:21 Go to last post
  3. DVB-C in E2 cu UPC si pe DIGI simultan
    Started by w2kclan, 17-02-21 01:59
    17-02-21, 16:12 Go to last post
  4. Subtitrari cu diacritice Vu+duo
    Started by Cha0s, 22-06-11 12:56
    21-04-20, 13:33 Go to last post
  5. HDD mount in VU Duo4K
    Started by essco, 17-04-20 12:12
    17-04-20, 12:12 Go to last post
  6. Remote code
    Started by lao, 28-04-19 17:58
    28-04-19, 17:58 Go to last post
  7. Problema LCD4Linux
    Started by lao, 06-01-19 17:12
    08-01-19, 16:37 Go to last post
  8. vu duo - probleme placa retea
    Started by luciandan, 09-12-18 15:25
    13-12-18, 22:25 Go to last post
  9. Vuplus community
    Started by suporter, 26-10-18 18:53
    03-11-18, 15:01 Go to last post
  10. Tuner vu+ blocare pozitioner
    Started by dingo31, 10-02-18 14:25
    12-02-18, 12:57 Go to last post
    09-12-16, 18:28 Go to last post
  11. Oscam TVR HD cccam Focussat VU PLUS DUO
    Started by pandurelul, 25-11-16 21:41
    27-11-16, 11:22 Go to last post
  12. Cron Manager pentru VTI
    Started by suporter, 06-02-16 16:02
    06-02-16, 17:27 Go to last post
  13. Montura sau multifeed
    Started by Seby2193, 29-10-15 20:02
    02-11-15, 00:21 Go to last post
  14. afisare EPG limba romana imagine VTI
    Started by luciandan, 16-04-15 17:56
    16-04-15, 17:56 Go to last post
  15. card viacces
    Started by messi, 15-02-15 21:01
    27-02-15, 03:18 Go to last post
  16. Vu+zero
    Started by umbra, 01-12-14 18:07
    01-12-14, 18:07 Go to last post
  17. tuner failed
    Started by grasububu, 21-10-13 22:10
    2 Pages
    1 2
    16-07-14, 14:13 Go to last post
    15-07-14, 20:32 Go to last post
  18. memorare sateliti vu duo?
    Started by grasububu, 15-07-14 19:27
    15-07-14, 19:41 Go to last post
Forum Information and Options
Moderators of this Forum
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 150 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
