Schimbare MAC permanent prin FTP - DM500
Am gasit pe un forum de afara ([Only registered and activated users can see links. Click Here To Register...]) o modalitate de schimbare a MAC-ului permanent fara a folosi jtag.
HOW TO USE :
ATTENTION : Don't forget to make a backup image !
1st Download FLASH WIZZARD and upload the modified firmware image "brainwave mac address changer.fw2" to dreambox
2nd Reboot dreambox and then, connect using telnet (use dhcp, and find the assigned IP in the control panel).
The login/password are the default credentials (root/dreambox).
3rd execute the script calling it like this :
/var/patchME XX XX XX XX XX XX
The XX XX XX XX XX XX is the desired MAC ADDRESS. Do not use colons to separate the bytes.
example:
This is ok --> /var/patchME 00 09 CC 01 AA 55
This is not ok --> /var/patchME 00:09:CC:01:AA:55
Congratulations ! Mac address permanently changed.
Feel free to upload your backup image.
If you have any questions, PM me at [Only registered and activated users can see links. Click Here To Register...]
bra|wave
Re: Schimbare MAC permanent???? Cine se incumeta?
Am verificat si vad ca functioneaza , am bagat exact cum au zis si dupa asta am bagat pe curat gemini 430 si ... blue panel nu era blocat si nici in var/etc nu era fisierul init .
Sper sa fie asta rezolvarea fara jtag , mai trebuie testat cu o imagine cu bomba in ea.
Tasteaza in telnet "ifconfig",da enter si vezi daca ai MAC original la hardware addres.
Testat si e ok , in router dreamul este vazut cu mac original , inainte aveam un mac gen 00:33:22:33:22....si asa era vazut de router acum vad ca e macul ce l-am bagat. Totusi cineva cu jtag la indemana sa verifice mai bine. Parca e prea simplu si e aparuta metoda in luna mai si noi nu am stiut nimic.
Atunci e bine.Nu conteaza daca e simplu sau nu,important e sa functioneze.:D
Tot nu am curaj sa incerc gp 4.4. :sorry:
Incearca linistit,daca se intampla ceva te rezolv eu cu jtag fara probleme.Cu mac original merge 100%.Testat.:D
Ar fi super sa mearga , daca testezi te rog sa ne tii la curent.
Cateva intrebari suplimentare :
- daca salvezi o imagine cu FlashWizard sau cu DreamUP , se salveaza totul ? ma refer si la boot si la MAC ?
- daca nu , doar cu JTAG-ul se poate face un full backup ?
- cele doua imagini ([Only registered and activated users can see links. Click Here To Register...] si [Only registered and activated users can see links. Click Here To Register...] ) sunt identice doar ca sunt salvate cu programe diferite ?
Pai si bomba este simpla , o pui cu gemmini si .... voila : Adios Amigos :D
Boot se citeste numai cu jTag dar nu avem programul de dump .
Cu Fw sau dreamUP faci backup numai la imagine cu setarile aferente , nu si la bootloader .
Am dat flash erase se vreo 10 ori cred , am pus cateva imagini , mac-ul a ramas cel de original schimbat cu backup ul ala. Am bagat gemini 4.4 si merge ,deocamdata , in telnet imi spune ca e macul ce l-am bagat eu inainte .
Metoda vad ca a functionat.
Pentru SMV ....Cred ca a actionat la fel ca bomba , a rescris bootloaderul , daca ai vazut cum se face , se modifica din telnet cu ajutorul scriptului pachME .
Am schimbat si eu MAC si este totul ok!!!!! Faceti exact cum scrie acolo si nu sunt probleme!! :cheers:
Gata si la mine :) , acum sa bagam si o bomba sa vedem daca moare sau nu , am instalat si imagine noua si macul ramane :dance:
Multam` @Zappa
V-am facut un generator si validator de adresse MAC ;)
Cine stie un server bun sa ma contacteze pe irc sau prin pm, ca acuma este pusa pe desktopul meu serverul.
Click aici -=> [Only registered and activated users can see links. Click Here To Register...]
Bafta ;) :D
E vreo adresa MAC din seria 00:09:34:..... care nu este valida? Atunci ce sens are validarea lor?
Click aici -=>
Bafta ;) :D
Sa fie linistit cel care apeleaza la generatorul de MAC ca este valida !
:P
Nu toata lumea este in curent cu astea ! infine.
Multumim! Util generatorul! :drinks:
Am modificat si eu MAC-ul la o clona. Am pus gemini 4.30 , aveam acces la blue panel. Am pus 4.40. Deocamdata e OK
A depasit uptime 24 de ore. Am testat diverse (net , reboot etc) si totul e OK.
Atunci dai un reboot de vre-o 3 ori la interval de 12min[din aparat cat si scotindul din priza in timpul functionarii] si vezi tot asa ramane?
Numai un reboot crezi ca am dat ? Am dat destule , si legat la net si fara net.
