Re: Nabilosat Enigma1 DarkStar II - DM500 OpenVPN
a probat cineva imaginea Nabilosat Enigma1 DarkStar II - DM500? ... mai intereseaza daca isi mentine subtitrarea.
Da.Isi mentine subtitrarea,are pluginul CCcam info inclus,face update la EPG,ce sa mai,super.Parca si calitatea imaginii este mai buna.Poate a mai testat si altcineva si poate confirma.
Blue Panel
Re: Imagini dreambox-clone!
Pe clone merge oare fara probleme GP 045?
Nu are si asta un timebomb?
Merge sigur si pe clone...insa trebuie schimbat MAC-ul, altfel te saluta cei de la GP :).
Crezi ca Gemini Team va mai scoate imagini pentru DM 500S fara timebomb inclus ???
Banuiesc, ca prin avertizarea de mai jos GP spune tot.
"...Gemini Images may only be used on receivers of the manufacturer Dream-Multimedia-TV.
The use of this Image is on your own risk."
PLi® Jade Final Dm500 old-framebuffer
A new Enigma1 PLi® Dreambox release is available for download.
* PLi®-Jade-DM500 old-framebuffer
See below for what's new & fixed since the initial PLi® Jade RC release
Highlights:
- Satellite.xml split in Ka, Ku, C, S, L band
- Remote control behaviour reverted to pre-Jade
* (Some remotes suffered from very bad reception in the Jade RC)
- North America scan fix by Updatelee
- CDK Flashtool: support flashing between standard partition layout and 'MaxVar' partition layout!
* ('Var' partition is erased when the layout changes)
- Rotor improvement for the OpenEmbedded (OE) boxes
Enigma1:
- CVS Repository June 29th 2008
- PLi® Repository September 29th 2008
- Enigma Movieplayer fixed by ims
- Default sleeptimer now 30 minutes
- Insert and delete character support for DM500 remotes (Red and Green)
* Now Red (delete) en Green (insert) can be used.
* For all other boxes Vol+/Vol- and Red/Green can be used - it does not care...
- Remote control behaviour restored to pre-Jade
- Fixed 'DM7000 style' remote control for DM500
* (Added the ability to use the DM600, 7000, 7020 large remote on your DM500, DM56x0)
- Show serviceselector again with TV/RADIO key, but only if the mode already was TV resp. RADIO.
* Toggling TV/RADIO doesn't bring up the service selector
- Timeshift delay input value limited to 999 instead of 60 seconds
- Timeshift / reco***ng support for DM500+ (settings equal to DM600)
* (Smooth start and faster rotating at 18 V, motor stop detection improved)
Plugins:
- Bitrate plugin fixes for NTSC
PPanel:
- Channelsetting reload in PPanel fixed
EPG Features:
- Use audio key for searchEPG in EPG channel
OSD Features:
- OSD transparancy setting in smaller steps for DM500+ and DM600 (5 instead of 25)
Web Interface Fixes:
- Some info in WebIf missing for IE fixed by ims
Network:
- Enable network and DHCP as default in case the Enigma config is not copied from /Var_init
* May fix some move /Var to network issues
- Do NOT add manually created mounts to the Enigma mount.conf
* It can cause double mounts if such a mount was already done in /Var/etc/init
Highlights DM500 MaxVar:
We've created 1Mb extra /Var space for you...
The removed items are now available via the PLi® downloads at the Software Management
We rebuilt the internal Flash tool completely!
So now you can flash back and forward between the standard PLi DM500 images and the PLi DM500-MaxVar images without using the serial cable[IMG]http://***-board.com/images/smilies/excl.gif[/IMG]!
We advise you to use the 'root.cramfs' method for this!
See the url below on how to Flash your DM500 via the 'root.cramfs' method:
See our DM500 Installation Wiki...
Moved to Software Management downloads:
- MV EPG plugin, Mediapli_8 skin, CCcam SoftCam, Cables/Terrestrial.xml, Translations, Games, traceroute, nslookup, IPtables, Netfilter drivers
Further:
- Thanks to Updatelee for North America scan fix
Thanks to the PLi testers for several fixes and features
Support:
- Online update support (IPKG feed) for OpenEmbedded boxes
* (DM500Plus/DM600/DM7020)
- Global satellites.xml updated September 29th 2008
* (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal; DVB-S2 can't handle auto-FEC)
- Satellites.xml split in Ka, Ku, C, S, L band
__________________
Evolution 2.0 - new Sattv image
Sattv image is now Evolution 2.0 Image
DM500/DM56X0/DM7000/IPBox200S/IPBOX250S
Technical Infos:
CVS Version: 12.10 2008
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delite Addons
Removed ebrowser
Removed 1sec ecm.info
Add Backup Manager (make var backup install var backup)
Add new satellites.xml latest update
Add Infobar Adjust
Add Extra Setting disable enable option
Add Disable EPG Caching (Important for ipbox200 disable this option for free memory)
Add Support for Ptest Plugin (need new skin)
Add ezap_main faild recovery
Add ecm.info in Blue panel
Add move var manager
Fix bugs on skin
Fix bug crash when try to recording (now works)
Fix bug when change Emu (now starting emu faster)
Fix crash when try mount on ipbox
And more..............
IPBox200S:
Last Kernel: 2.6.17 (Thanks to Sandali)
U-Boot: 1.2.0 (Thanks to Sandali)
New driver from sandali
IPBox200S mID 20
IPBox250S:
IPBox250S mID 25
IPBox login:
user:root
password:ipbox
Support: [Only registered and activated users can see links. Click Here To Register...]
This image doesn't include keys or emulators.
satkeynet is not responsible any damage caused by this software.
DOWNLOAD DM 500S [Only registered and activated users can see links. Click Here To Register...]
