Black Hole 3.0.5 Quad PiP Vu+ Zero Image
What is new ?
- Update and fix CrossEPG
- Fix Timer recording bug
- Fix USB recording
- Add Overlayfs for new kernel (Uno4KSE, Zero4K)
- Add Uno4KSE support
- Add Zero4K support (beta)
- Add VP9 Support (Ultimo4K, Uno4KSE, Uno4K, Zero4K)
- Add Dvb-S2X support (Zero4K)
- Add Multistream/PLS support (Zero4K)
- Add Blindscan support (Zero4K)
- Update Drivers (Ultimo4K, Uno4KSE, Uno4K, Solo4K, Zero4K, Duo2, SoloSE, Solo2, Zero)
BlackHole-3.0.5-vuzero_usb_release_20171224_610e58d.zip
Black Hole 3.0.5.A Quad PiP Vu+ Zero Image
What is new ?
Update drivers(4k models)
- Fix demux problem
[bluetoothsetup/util] update for solo4k.
[vuplus-blindscan-utils] update TT2L08/TT3L10
[Scan] Fix DVB-T2 Network Scan. (need update libdvbsi++ 0.3.8)
- Fix HDR/HLG problem
- Fix grab problem
- Fix demux problem
- Improve overall performance
- Update kernel config
- Adjust driver memory allocations
update kodiegl/chromium/directfb.
[libdvbsi++] update to 0.3.8
[dvbmediasink] update EXTRA_OECONF (solo4k, uno4k, ultimo4k, uno4kse).
update driver(zero4k)
- Fix DVB-CI problem
- Fix PLS
- Improve demux
This is available as an online update from 3.0.5 or as a full flash update.
Black Hole 3.0.5.E Quad PiP Vu+ Zero Image
Black Hole 3.0.5.E
What is new ?
update drivers(uno4k, uno4kse, ultimo4k)
- Fix DiSEqC timing
- Support Dual DVB-S2X FBC tuner(needs E2 update)
update drivers(solo4k, uno4k, uno4kse)
- Fix media playback(24Fps)
Fix default recording path and usb recording.
[dvbapp] update.
[autofs] remove sync option for broken recording issue for ext4 filesystem.
[udev] fix automount.
BlackHole-3.0.5-vuzero_usb_release_20180226_4accc58.zip
The latest BlackHole image is 3.1.0 Multistream Vu+ Zero Image
BlackHole-3.1.0-vuzero_usb_release_20201005_b5f1952.zip
