HD Glass 16 ver. 10.89
- fix detection audio type
update is available online (setup and website)
HD Glass 16 ver. 11.06
- fix date in some extrascreens and base infobar
- added to translation text from help pictures
- help: updated en, sk, cz translations
- added in "INFOBAR": TP type(color), TP info(color), Video resolution(color)
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- added screens def.: autotimer plugin
- display info about new version as "Changelog"
HD Glass 16 ver. 11.22
- updated enhanced weather translations
- changed User defined path to selection of dir by using Location box, if is
Picons/Icons path used as User defined path the one will be set to default value
and you can set your prefered options after autorestore
- updated help sk, cz, en, lt
- setup of the skin: added moving to last item/section if is active first item
press Up/Ch + and moving to first item/section if is active last item press
Down/Ch -
- fix TP info a ECM status
- added new option: Calculation of channel numbers - static/dynamic, section OTHERS
static - recommended for old HW
- added color "grey 5" at all color selection
- added new option: Date format - in sections: INFOBAR/EXTRA INFOBAR, OTHERS,
CHANNEL SELECTION, MENU
- splitted section INFOBAR to sections: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
- added new options: Date (color), Time (color), Seconds (color) in section
EXTRA INFOBAR
- added autodetection of possible OLED type by hw
- fix detection of decoding type - dynamic icons
- added autohiding of options unusable in image/hw
HD Glass 16 ver. 11.60
- fix saving of weather location
- OLED: added OLED type - only time 2
- added alternative method to detection tuner type in some types of enigma
Thanks @Shammann
enigma2-skin-hdglass16_11.60_all.ipk.zip
enigma2-skin-hdglass16_11.60_all.deb.zip
