Update Azbox HD Glass Skin 16 v2.16
In the previous version we got these new arrivals:
2.15
- you can set permanent extrainfobar via setup, if this option is disabled press OK twice - extrainfobar is displayed
- added multiextrascreen option - choose screen via setup and press yellow button - actually 8 screens are defined, you can create and add/use own screen by editing file: G16screens.py located in: /usr/lib/enigma2/python/Screens/, you can define max 99 screens
- added icon set option - choose set of icons via setup and press blue button - actually 4 sets from max 5, you can add/change own set of icons, this set is used for active screen always (dirs for icons are: i_type-1(5) located in: /usr/*****/enigma2/hd_glass16/icons/
- added new option: type of menu, may be the type list or icons (icons type is standardized for DMM image menu list, if your image have not a item in menu like icons (BP, LTmenu....) name of item is showed bottom with arrow icon -right bottom icon)
- updated name of satellites for all orbit
- added help button to show/hide detailed Ecm and TP info (help button is active only when tuner is active - if you watching movie from hdd, listen music, internet radio..., button is inactive), you can change mapping this button editing file: keymap2.xml located in: /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/, you can set position of the screen using arrow buttons on RC in setup and press OK button
Changelog v2.16:
- Fix enhanced info font size in screen 1 and 8
Download:
[Only registered and activated users can see links. Click Here To Register...] (3.62 MB)
Skin blackmodern_azboxhd exclusivo azbox
by: @Mpiero
This is a new skin just for our azbox (for enigma2).
Product:
Code:
Show info on emus, satellite, channel number, in the InfoBase.
• It is also adapted for the blue panel on gemini, ie works in 2 versions: gemini and officers RTi (rc4, rc5, rc6, rc7,...).
• Compatible with secondinfobar and virtualzap plugins (if you have installed)
Install:
Code:
Copy the file enigma2-skin-blackmodern-Mpiero-hd_1.0_mipsel.ipk to / tmp (or any other folder we) with FTP
• Enter through telnet and type:
cd / tmp
chmod 755-skin-enigma2-Mpiero-hd_1.0_mipsel.ipk blackmodern
ipkg-force-overwrite install enigma2-skin-blackmodern-Mpiero-hd_1.0_mipsel.ipk • We will choose the skin in settings and same is rady to use.
[Only registered and activated users can see links. Click Here To Register...] (1.07 MB)
---------- Post added at 09:36 ---------- Previous post was at 09:13 ----------
BlueDoor skin by: Ilje
[Only registered and activated users can see links. Click Here To Register...] (1.57 MB)
[Only registered and activated users can see links. Click Here To Register...] (17.5 KB) >>change skin.xml, and restart box..
Corectie Keymap pentru hdglass skin(RCU AZBOX)
RC1X + enigma2-skin-hdglass16_2.39_mipsel + Keymap based on original firmware
se modifica in
Code:
./usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/
keymap.xml:
Code:
<keymap>
<map context="g16Actions">
<key id="KEY_GREEN" mapto="ok_pressed" flags="m" />
<key id="KEY_EXIT" mapto="exit_pressed" flags="m" />
</map>
</keymap>
keymap2.xml:
Code:
<keymap>
<map context="GlobalActions">
<!-- <key id="KEY_HELP" mapto="showSpecialScreen" flags="m" /> -->
<key id="KEY_AUDIO" mapto="showSpecialScreen" flags="mr" />
</map>
</keymap>
buton "OK" (native key_id = KEY_OK): Bouquet list.
buton "CHECK" (native key_id=KEY_AUDIO): ECM/TP Info
buton "GREEN" (native key_id = KEY_GREEN): canal TV curent
buton "GREEN" (apasat de 2 ori) : User Screen
stie careva care sunt key_id-urile native atribuite pentru "RESOLUTION", "CHECK" si "SEARCH"?
eu nu mai am fisierul cu care vine RC-ul(/usr/share/enigma2/keymap.xml), e modificat.
