VideoStrong KII Pro Android Set-top Box with DVB-T2 & DVB-S2 Tuners
Dupa cum era de asteptat , ia-ta ca a aparut si ''fratele mai mare'' a lui K1 Plus DVB-T2/S2 , in speta - KII Pro DVB T2+S2
E ''bazat'' pe aceeasi arhitectura ca la K1 Plus DVB-T2/S2 , insa avand unele diferentieri :
- 2Gb ram in loc de 1Gb ram ca la K1 Plus......
- 16Gb storage in loc de 8Gb storage ca la K1 Plus.......
- Wi-Fi AC cu Ampak AP6335 , in loc de Wi-Fi cu Realtek 8189
KII Pro specifications:
•SoC – Amlogic S905 quad core ARM Cortex-A53 @ up to 2.0GHz with penta-core Mali-450MP GPU @ 750 MHz
•System Memory – 2GB DDR3
•Storage – 16GB eMMC flash + micro SD card slot up to 32GB
•Video Output – HDMI 2.0 up to 4K @ 60Hz, and 3.5mm AV (composite video) jack
•Audio – HDMI, AV (stereo audio), optical S/PDIF
•Video Codecs – 10-bit H.265 up to 4K60, MPEG/VC-1/AVS+/H.265 up to 4K30
•Tuner – Combo DVB-T/T2 and DVB-S/S2 with two connectors
•Connectivity – 10/100M Ethernet, 802.11 b/g/n/ac Wi-Fi, and Bluetooth 4.0 (Ampak AP6335) – Not Realtek RTL8189 as shown in Aliexpress according to VideoStrong.
•USB – 4x USB 2.0 host ports
•Misc – Power button and LED, IR receiver
•Power Supply – DC 12V/1A
•Dimensions – 130 x 120 x 32 mm
•Weight – 187.50 grams
Sursa - [Only registered and activated users can see links. Click Here To Register...]
KII PRO Amlogic S905 Quad-core 2GB RAM
Salutare tutturor, ce imagine recomandati pentru acest model ?
Folosec: pentru
iptv 50%
ipcam-viewer 30%
vizionare dvbs2/t2 20%
Enigma2 posibil ?
