nemesis EMU pack
Camd3_3.899
CCcam_2.08
Evocamd_2.17c
MGcamd_1.29a
Scam_3.29a
Downloand;
nemesis EMU pack
Camd3_3.899
CCcam_2.08
Evocamd_2.17c
MGcamd_1.29a
Scam_3.29a
Downloand;
nemesis EMU pack
Camd3_3.899
CCcam_2.08
Evocamd_2.17c
MGcamd_1.29a
Scam_3.29a
Downloand;
@outcast ....imaginea se misca mai bine decat gemini. Nu se blocheaza. Am testat multe imagini, iar gemini mi s-a parut o imagine instabila, insa beneficiaza de cel mai bun suport.
DS TEAM 3.5 for DM7000, ITGATE TGS100,110, 220, TECHNOMATE 9100, 9101
Image per FLASH / USB / HDD / CF / NFS
+ CVS 28.12.2007
+ kernel v. 2.6.9 (1.10)
+ enigma v. 1.10 Mod (28.12.2007 mod DS Team)
+ BusyBox v1.01
+ Web Interface: 6.04-Expert mod DS
+ Gcc 3.4.4
+ FP Firmware 1.06
+ LZMA Patch
+ ScriptService 2.05 mod DS
New mapping of Buttons:
+ BLUE Button - EmuManager
+ YELLOW Button - DS Extras
+ HELP Button - QuickButton
+ GREEN Button - Subservices (NVOD)
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - EPG List for the current channel
+ 2x RED Button - Double Click for EPG Style Menu
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT!!
!!! DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
NEWS & FIXES in DS 3.5
- New Web Interface Graphic
- Rebuilded Management Addons ( Skins, Plugins, Games, System, ScriptService Menus, Languagues, SoftCams. Channel Settings )
- Moved fromSetup->Expert Setup (Movie folder setup, Quick Button setup) and moved them to Yellow->Blue DS "Extras" menu )
- Removed gSUB - it is aviable via Management Addons
- Removed Samba - it is aviable via Management Addons
- Removed OpenVPN - it is aviable via Management Addons
- New Drivers ( sound quality improved )
- Full Clock- HH:MM:SS -> you can enable it on Infobar Setup
- Fixed DS Style Menu -> you can enable it on Infobar Setup
- Added Inadyn Manger ( Start, Stop, Reload, Config )
- Added Syslogd Manager ( Start, Stop, Reload )
- Added DropBear SSH Manager ( Start, Stop, Reload )
- Added OpenVPN Manager ( Start, Stop, Reload ) - it is aviable via Management Addons -> ScriptService Menus
- Added Samba Manager ( Start, Stope, Reaload ) - it is aviable via Management Addons -> ScriptService Menus
- Added HTTPD Manager ( Start, Stop, Reload ) - it is aviable via Management Addons -> ScriptService Menus
--- TM & IT
-Support For all Dreambox Skins
-egague support
-color progres bars
CVS Changes:
-call waitpid on the child process, when it finished. This avoids zombies, and allows us to get the exit status.
-signal the whole child process group, instead of just the child process.
- EPG - No need to wait (in service selector) until eventcache is loaded from hdd
- Remember subtitle settings for every channel
- Reorganize eServiceDVB to use less memory that's 100KB in my case (Astra/Hotbird with ca. 4000 services)
- Subtitles - Only display subtitle regions that are mentioned in the page composition segment (this is correct behaviour according to ETSI EN 300 743 V1.2.1 (2002-10) paragraph 5.1.3) . Subtitles should now correctly be hidden when required (especially at the end of the movie)
- less memory usage by keeping "big" images of the current skin compressed in memory
(saves about 400k on small skin)
- RDS more robust rtp plus tag parsing
- fix memleak
- Show shortcut icons in menus (can be disabled in expert settings)
Imagine f. buna cu iz de RuDream (daca stiti despre ce vorbesc).
Nu are firewall inclus. Are o singura mare problema; nu afiseaza subtitrarea, desi o poti selecta si ramane selectata chiar daca schimbi programul.
Daca nu va deranjeaza problema subtitrarii (desi sunt convins ca da) puteti instala imaginea. O recomand.
Sper ca teamul polonez va remedia problema.
DA. Nemesis e peste gemini. Si inca am imaginea chiar daca intre timp am mai testat cateva imagini (PGb1.0dm500, STRMR_500_MAXVAR_2.02, castle_106_maxvar_500, ds_sunrise_500, punt@ltwodm500MV-last image, TWD).
Dintre toate ds_sunrise mi-a lasat o impresie placuta. La fel si cea turceasca (TWD). Pe castle_106_maxvar_500 nu am reusit sa instalez gbox. E singura cu care nu m-am descurcat.
Ai ca mai facut curios,o sa o instalez si eu sa vedem ce poate.:)
Da, asteptam impresiile tale.Quote:
vrem detalii:cool2:
Poze aici (ca eu inca n-am facut)
Mmmda,imagine stabila,se misca rapid dar.....mie nu imi place,revin la geminii 431:dance: :)
..interfata web de la nemesis.....arata sooper dupa parerea mea:
