Azbox hd e2 plugins
Project Valerie for AzBox HD
"The aim of project valerie is to create an easy to use full feature media center for all enigma2 based set top boxes.
The main improvement to a standard enigma2 installation is that instead of being multimedia support just a nice re on the side, in Project Valerie multimedia support is the key feature. "
How to Install project-valerie_rev473_mipsel_oe16.ipk :
Put file [Only registered and activated users can see links. Click Here To Register...] bu FTP in /tmp
Connect by telnet on AzBox and execute this command :
cd /tmp
opkg install project-valerie_rev473_mipsel_oe16.ipk
After you have installed Valerie, unpack file [Only registered and activated users can see links. Click Here To Register...] and transfer files :
em8634dvb.ko and irvfd.ko to /lib/modules/2.6.22.19-19-the_ripper/extra
libshowiframe.so.0.0.0 to /usr/lib/enigma2/python/Plugins/Extensions/ProjectValerie
Wizard.py to /usr/lib/enigma2/python/Screens
After that, reboot your device.
NOTE: Stop button is mapped to Resolution button.
PC App : [Only registered and activated users can see links. Click Here To Register...] is application to use on PC and to manage Valerie.
---------- Post added at 17:31 ---------- Previous post was at 15:47 ----------
Glass System Utility v. 2.40
- System info plugin for Enigma2 OE 1.6
Look's nice with new HD Glass skin..[Only registered and activated users can see links. Click Here To Register...]
Download:
Rsync 3.0.0 for Azbox E2
for synchronizing files or backups
Download:
IPTV Stream Player E2
nStreamPlayer - IPTV Stream Player
v.0.3
merge foarte bine pe AZBOX E2- RC11(http-rtsp)
Download:
am modificat lista de canale + 2 in HD, se copiaza in:
Code:
./usr/lib/enigma2/python/Plugins/Extensions/nStreamPlayer/
Download:
