atîta timp cît nu ai "system time" actualizat (ntp client in samygo?) nu o sa porneasca oscamul.
Salut,Quote:
Originally Posted by mirel [Only registered and activated users can see links. Click Here To Register...]
Si eu am probleme cu pornirea oscam...
Cum se poate schimba data compilarii? (Sunt novice in linux)
la mine a disparut problema cu timpul dupa ce am pus alta versiune de oscam.[Only registered and activated users can see links. Click Here To Register...]
fisierul liboscam - [Only registered and activated users can see links. Click Here To Register...]
fisierul SoftCam.Key se gaseste pe net si se pune in folderul oscam
functioneaza perfect pe samsung UE32H5500 cu versiune T-MST14DEUC_2130.0 si root "[Only registered and activated users can see links. Click Here To Register...]"
urmatoarele setari care se fac manual:
oscam.server:
oscam.user:Code:
[reader]
label = emulator
protocol = emu
device = emulator
caid = 1801
detect = cd
ident = 1801:000000,007301,001101;1801:002111
group = 1
emmcache = 2,1,2,1
saveemm-unknown = 1
saveemm-u = 1
saveemm-s = 1
saveemm-g = 1
lb_weight = 300
emu_auproviders = 1801:002111
oscam.conf:Code:[account]user = dvbapi
keepalive = 1
emmreassembly = 1
group = 1
Code:[global]logfile = stdout
nice = -1
maxlogsize = 256
waitforcards = 0
preferlocalcards = 1
block_same_ip = 0
lb_mode = 1
lb_save = 100
lb_max_ecmcount = 1000
lb_retrylimit = 100
lb_max_readers = 2
[cache]
[streamrelay]
[dvbapi]
enabled = 1
pmt_mode = 6
request_mode = 1
delayer = 60
user = dvbapi
extended_cw_api = 2
boxtype = pc-nodmx
@[Only registered and activated users can see links. Click Here To Register...] sunt doua posibilitati:
la compilare, schimbi data pe care compilezi :) oscamul in 1970 sau deschizi binul de oscam cu un editor de ex. notepad++ si cauti anul (2020) si schimbi numai acolo din 2020 in 1970...salvezi si incerci...le-am incercat pe amindoua, merg fara probleme.
mie îmi deschide programul (cu tot cu samygo) la 20 de secunde dupa ce-l pornesc...
S-a rezolvat. Probleme cu versiunea de firmware. Eu am UE32J5200 care este de fapt un H deghizat! Am pus o versiune mai veche de firmware si a inceput sa mearga si oscam.
Dar doar o singura versiune am reusit sa fac sa mearga: oscam-svn11110-samsungtv-webif-emu
Am luat oscam cu emu de aici> [Only registered and activated users can see links. Click Here To Register...]
Pentru mine sunt cele cu ARM.
Dar nu am reusit sa fac sa mearga (decodeze Gigi) versiunile mai noi de oscam.
Nu ma pricep prea bine la linux de aceea afisez logurile poate imi spuneti voi de ce nu decodeaza:
liboscamH.log
Oscam Live logCode:(11:40:12) SamyGO H T-NT libOscamH build 32 - (c) MrB 2015
(11:40:12) _Z21SdTSData_StartMonitorjP19SdTSData_Settings_tj12SdMainChip_k [0x6c857c].
(11:40:12) _Z20SdTSData_StopMonitorjj12SdMainChip_k [0x6c9bd8].
(11:40:12) PLAT_TSPU_GetDpHandleByDemuxHdl [0x426dc744].
(11:40:12) DRV_TSPU_DESC_CWB_Enable [0x42c018f0].
(11:40:12) DRV_TSPU_DESC_CWB_Disable [0x42c01964].
(11:40:12) DRV_TSPU_DESC_CWB_Config [0x42c01854].
(11:40:12) DRV_TSPU_DESC_Config [0x42c01730].
(11:40:12) DRV_TSPU_DESC_PID_Open [0x42c01308].
(11:40:12) DRV_TSPU_DESC_PID_Close [0x42c013c0].
(11:40:12) DRV_TSPU_DESC_PID_Enable [0x42c01570].
(11:40:12) DRV_TSPU_DESC_PID_Disable [0x42c015e0].
(11:40:12) DRV_TSPU_DESC_PID_Config [0x42c0144c].
(11:40:12) _Z9SdCP_Openj12SdMainChip_k [0x6c7934].
(11:40:12) _ZN5TCAPI9GetWindowEN8TCWindow7EWindowE [0xacd258].
(11:40:12) _ZN12TCWindowImpl9GetSourceEPii [0xbdb8fc].
(11:40:12) _ZN12TCWindowImpl12GetTVChannelEP9TCChanneli [0xbdb9e4].
(11:40:12) _ZN12TCWindowImpl15SetChannelQuietEPK9TCChannelb [0xbde94c].
(11:40:12) _ZN9TCChannelC2Ev [0xc86690].
(11:40:12) _ZN9TCChannelD2Ev [0xc829a4].
(11:40:12) _ZNK9TCChannel13ProgramNumberEv [0xc84344].
(11:40:12) _ZNK9TCChannel16SizeOfDescriptorEv [0xc8333c].
(11:40:12) _ZNK9TCChannel10DescriptorEii [0xc8337c].
(11:40:12) _ZNK3CIM15TCMwUtilsBridge11GetSourceIdEP12TCSourceConf [0x13726ac].
(11:40:12) _ZN9DemuxBase18m_Demux_SICallbackEPN8CDiDemux20SICallBackSettings_tE [0x831a44].
(11:40:12) _ZN16TCCIMManagerPlus13ChannelChangeEPK9TCChannelP12TCSourceConf [0x133c700].
(11:40:12) _Z13SdDemux_Startj13SdDemux_Out_k12SdMainChip_k [0x6c7eec].
(11:40:12) _Z12SdDemux_Stopj13SdDemux_Out_k12SdMainChip_k [0x6c8714].
(11:40:12) _ZN3CIM25TCServiceSelectionManager8SetAvPidEN8TCWindow7EWindowEii [0x139e1d0].
(11:40:12) SdCP_Open=0x00000000
(11:40:12) init done...
(11:40:12) Waiting for incoming connections...
(11:40:16) Client connected
(11:40:16) Got SERVER_INFO: OSCam v1.20_svn, build r11429 (arm-v7a8v3r1-linux-gnueabi); , protocol_version = 3
(11:40:16) channel set...
(11:40:36) SdDemux_Stop, dmxHandle=0x12345600, eDemuxOut=0x00000001, eMainChip=0x00000000
(11:40:36) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:36) SdDemux_Start, dmxHandle=0x12345600, eDemuxOut=0x00000001, eMainChip=0x00000000
(11:40:36) using dmxHandle=0x12345600
(11:40:36) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, g_dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:36) DRV_TSPU_DESC_PID_Open=0x00000000, descPid=0x54530000
(11:40:36) DRV_TSPU_DESC_PID_Open=0x00000000, descPid=0x54530100
(11:40:36) New video and audio pids, pidVideo=0x1979, pidAudio=0x197A
(11:40:36) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530000
(11:40:36) DRV_TSPU_DESC_PID_Config=0x00000000
(11:40:36) DRV_TSPU_DESC_PID_Enable=0x00000000, descPid=0x54530000
(11:40:36) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530100
(11:40:36) DRV_TSPU_DESC_PID_Enable=0x00000000, descPid=0x54530100
(11:40:37) TCCIMManagerPlus_ChannelChange, TCChannel=0x8F48846C, TCSourceConf=0x8F4883F0
(11:40:37) Source id=17
(11:40:37) Service changed, new sId=0x028C
(11:40:37) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, g_dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:37) DRV_TSPU_DESC_CWB_Disable=0x00000000
(11:40:37) DRV_TSPU_DESC_Config=0x00000000
(11:40:37) DRV_TSPU_DESC_CWB_Enable=0x00000000
(11:40:37) Got DMX_SET_FILTER request, pid=0x0000, byte1=0x00, mask1=0xFF
(11:40:37) ECM monitor started, dmxHandle=0x12345600, monHandle=0x65432E21
(11:40:37) Got DMX_SET_FILTER request, pid=0x1585, byte1=0x80, mask1=0xF0
(11:40:37) ECM monitor stopped, dmxHandle=0x12345600, monHandle=0x65432E21, ret=0x00000000
(11:40:37) ECM monitor started, dmxHandle=0x12345600, monHandle=0x65432F21
(11:40:37) PMT sent, sId=0x028C
(11:40:37) Got ECM80
(11:40:41) Got ECM81
(11:40:47) SdDemux_Stop, dmxHandle=0x12345600, eDemuxOut=0x00000001, eMainChip=0x00000000
(11:40:47) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:47) ECM monitor stopped, dmxHandle=0x12345600, monHandle=0x65432F21
(11:40:47) SdDemux_Start, dmxHandle=0x12345600, eDemuxOut=0x00000001, eMainChip=0x00000000
(11:40:47) using dmxHandle=0x12345600
(11:40:47) ECM monitor restarted, dmxHandle=0x12345600, monHandle=0x65433221
(11:40:47) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, g_dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:47) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530000
(11:40:47) DRV_TSPU_DESC_PID_Close=0x00000000, descPid=0xFFFFFFFF
(11:40:47) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530100
(11:40:47) DRV_TSPU_DESC_PID_Open=0x00000000, descPid=0x54530000
(11:40:47) DRV_TSPU_DESC_PID_Open=0x00000000, descPid=0x54530100
(11:40:48) New video and audio pids, pidVideo=0x19A1, pidAudio=0x19A2
(11:40:48) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530000
(11:40:48) DRV_TSPU_DESC_PID_Config=0x00000000
(11:40:48) DRV_TSPU_DESC_PID_Enable=0x00000000, descPid=0x54530000
(11:40:48) DRV_TSPU_DESC_PID_Disable=0x00000000, descPid=0x54530100
(11:40:48) DRV_TSPU_DESC_PID_Enable=0x00000000, descPid=0x54530100
(11:40:48) TCCIMManagerPlus_ChannelChange, TCChannel=0x8F48846C, TCSourceConf=0x8F4883F0
(11:40:48) Source id=17
(11:40:48) Service changed, new sId=0x0290
(11:40:48) PLAT_TSPU_GetDpHandleByDemuxHdl=0x00000000, g_dmxHandle=0x12345600, dpHandle=0x54440000
(11:40:48) DRV_TSPU_DESC_CWB_Disable=0x00000000
(11:40:48) DRV_TSPU_DESC_Config=0x00000000
(11:40:48) DRV_TSPU_DESC_CWB_Enable=0x00000000
(11:40:48) ECM monitor stopped, dmxHandle=0x12345600, monHandle=0x65433221, ret=0x00000000
(11:40:48) Got DMX_STOP request, pid=0x0000
(11:40:48) Got DMX_STOP request, pid=0x1585
(11:40:48) Got DMX_SET_FILTER request, pid=0x0000, byte1=0x00, mask1=0xFF
(11:40:48) ECM monitor started, dmxHandle=0x12345600, monHandle=0x65430A21
(11:40:48) PMT sent, sId=0x0290
(11:40:48) Got DMX_SET_FILTER request, pid=0x1599, byte1=0x80, mask1=0xF0
(11:40:48) ECM monitor stopped, dmxHandle=0x12345600, monHandle=0x65430A21, ret=0x00000000
(11:40:48) ECM monitor started, dmxHandle=0x12345600, monHandle=0x65430B21
(11:40:48) Got ECM81
(11:40:56) Got ECM80
(11:41:06) Got ECM81
(11:41:16) Got ECM80
(11:41:26) Got ECM81
(11:41:36) Got ECM80
(11:41:46) Got ECM81
(11:41:56) Got ECM80
(11:42:06) Got ECM81
(11:42:16) Got ECM80
(11:42:26) Got ECM81
(11:42:36) Got ECM80
(11:42:46) Got ECM81
oscam.confCode:
2020/12/26 11:40:13 00000000 s (main) System name = Linux
2020/12/26 11:40:13 00000000 s (main) Host name = (none)
2020/12/26 11:40:13 00000000 s (main) Release = 3.8.13
2020/12/26 11:40:13 00000000 s (main) Version = #1 PREEMPT Mon Apr 6 11:27:36 KST 2015
2020/12/26 11:40:13 00000000 s (main) Machine = armv7l
2020/12/26 11:40:13 00000000 s (main) creating pidfile /dtv/oscam.pid with pid 5099
2020/12/26 11:40:13 00000000 s (config) services reloaded: 0 services freed, 5 services loaded, rejected 0
2020/12/26 11:40:13 00000000 s (emu) OSCam-Emu version 771
2020/12/26 11:40:13 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2020/12/26 11:40:13 00000000 s (main) signal handling initialized
2020/12/26 11:40:13 00000000 s (config) 865 provid's loaded
2020/12/26 11:40:13 00000000 s (reader) emulator [emu] creating thread for device emulator
2020/12/26 11:40:13 00000000 s (stat) loadbalancer: could not open /dtv/stat for reading (errno=2 No such file or directory)
2020/12/26 11:40:13 00000000 s (main) waiting for local card init
2020/12/26 11:40:13 302B468D r (emu) Stream key delayer initialized
2020/12/26 11:40:13 302B468D r (emu) Stream relay server initialized
2020/12/26 11:40:13 302B468D r (reader) emulator [emu] Reader initialized (device=emulator, detect=cd, mhz=357, cardmhz=357)
2020/12/26 11:40:13 00000000 (emu) INFO: FFDecsa parallel mode = 32
2020/12/26 11:40:13 55BF1470 h (webif) webif: decompressed 178899 bytes back into 441784 bytes
2020/12/26 11:40:13 55BF1470 h (webif) HTTP Server: ERROR: Creating IPv6 socket failed! (errno=97 Address family not supported by protocol)
2020/12/26 11:40:13 55BF1470 h (webif) HTTP Server: Falling back to IPv4.
2020/12/26 11:40:13 55BF1470 h (webif) HTTP Server running. ip=:: port=8888
2020/12/26 11:40:14 302B468D r (reader) emulator [emu] card detected
2020/12/26 11:40:15 302B468D r (reader) emulator [emu] found card system emu
2020/12/26 11:40:15 302B468D r (reader) emulator [emu] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
2020/12/26 11:40:15 302B468D r (emu) Reading key file: /mnt/opt/privateer/usr/bin/oscam/config/softcam.key
2020/12/26 11:40:15 302B468D r (emu) Total keys in memory: W:0 V:0 N:3 I:0 S:0 F:0 P:0 D:0 T:0
2020/12/26 11:40:16 00000000 s (main) init for all local cards done
2020/12/26 11:40:16 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
2020/12/26 11:40:16 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
2020/12/26 11:40:16 00000000 s (anticasc) anti cascading disabled
2020/12/26 11:40:16 49308A11 c (client) plain dvbapi-client granted (dvbapi, au=off)
2020/12/26 11:40:16 49308A11 c (dvbapi) dvbapi channelcache loaded from /mnt/opt/privateer/usr/bin/oscam/config/oscam.ccache
2020/12/26 11:40:16 49308A11 c (dvbapi) Using /tmp/camd.socket listen socket, API forced to DVBAPIv3 (0), userconfig boxtype: 12
2020/12/26 11:40:16 49308A11 c (dvbapi) PMT6: Trying connect to enigma CA PMT listen socket...
2020/12/26 11:40:16 49308A11 c (dvbapi) PMT6 CA PMT Server connected on fd 19!
2020/12/26 11:40:16 49308A11 c (dvbapi) Client connected: 'libOscamH_build 32' (protocol version = 2)
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1801 ECM_PID: 1585 PROVID: 000000
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 15B7 PROVID: 000000
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 06BB ECM_PID: 1AFD PROVID: 000000
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1874 ECM_PID: 1B2F PROVID: 000000
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 found 4 ECMpids and 4 STREAMpids in caPMT
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 0
2020/12/26 11:40:37 49308A11 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 000000 ECMPID 1585 ANY CHID PMTPID 0000 VPID 1979
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 stop descrambling program number 028C (1801@000000:028C unknown)
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1801 ECM_PID: 1599 PROVID: 000000
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 15CB PROVID: 000000
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 06BB ECM_PID: 1B11 PROVID: 000000
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1874 ECM_PID: 1B43 PROVID: 000000
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 found 4 ECMpids and 7 STREAMpids in caPMT
2020/12/26 11:40:48 49308A11 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 000000 ECMPID 1599 ANY CHID PMTPID 0000 VPID 19A1
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 stop descrambling program number 0290 (1801@000000:0290 unknown)
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 ecmpid 0 CAID: 1801 ECM_PID: 1597 PROVID: 000000
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 15C9 PROVID: 000000
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 ecmpid 2 CAID: 06BB ECM_PID: 1B0F PROVID: 000000
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 ecmpid 3 CAID: 1874 ECM_PID: 1B41 PROVID: 000000
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 found 4 ECMpids and 4 STREAMpids in caPMT
2020/12/26 11:58:16 49308A11 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 1801 PROVID 000000 ECMPID 1597 ANY CHID PMTPID 0000 VPID 19D3
Code:# oscam.conf generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11402
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.conf.txt
[global]
logfile = /dtv/oscam.log
pidfile = /dtv/oscam.pid
maxlogsize = 50
block_same_ip = 0
block_same_name = 0
lb_mode = 1
lb_save = 100
lb_nbest_readers = 2
lb_nfb_readers = 2
lb_force_reopen_always = 1
lb_auto_betatunnel = 0
[cache]
csp_allow_request = 0
[streamrelay]
[dvbapi]
enabled = 1
pmt_mode = 6
delayer = 60
user = dvbapi
boxtype = pc-nodmx
[webif]
httpport = 8888
httpscript = /mnt/opt/privateer/usr/bin/oscam/scripts
httpshowecminfo = 1
httpshowloadinfo = 1
httpallowed = 0.0.0.0-255.255.255.255
httposcamlabel = Samsung TV
http_status_log = 1
oscam.server
oscam.servicesCode:[reader]
label = emulator
protocol = emu
device = emulator
detect = cd
nagra_read = 1
group = 1
emmcache = 2,1,2,1
emu_auproviders = 1801:000000,002011,002111
oscam.userCode:# oscam.services generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11058
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.services.txt
[hd01]
caid = 1830
provid = 000000,003411,008011
srvid = 5273,5274,157C,157F,1581,EF10,EF11,EF14,EF15,2774,2777,0002,2E9B,2EAF,30D4,126E,126F,EF74,EF75,EF76,EF77,EF78,1519,151A
[hd02]
caid = 1843
[all1]
caid = 0100,0500,0B00,0B01,0B02,0BAA,0D05,0D95,0D96,0D22,0D97,0D00,0D01,0D02,0D03,0D04,0627,0648,0628,0624,0601,0602,0603,0604,0608,0622,0654,0664,1702,1722,09C4,098C
provid =
srvid =
[all2]
caid = 098E,09C8,09CD,090F,091F,092B,093B,09B6,0919,09C7,0931,0963,09AF,1800,1801,1802,1803,1804,1810,1830,1833,1831,1843,1880,1838,1805,1834,1835,183D,1850,1860,1861
provid =
srvid =
[all2]
caid = 4AA1,4AE1,4AEE,0CA4,1702,098C,09C4
provid =
srvid =
p.s. Pentru cine vrea versiuni mai vechi de firmware si nu gaseste pe Gogu, sa ma contacteze in PMCode:
[account]
user = dvbapi
keepalive = 1
group = 1
din pacate nu am cablu aici, si nici oscam-emu nu folosesc, sa-ti pot spune setarile corecte...poate se gaseste cineva care are si sa te indrume
@[Only registered and activated users can see links. Click Here To Register...] Din câte știu eu nu ai și tuner de satelit pe tv tău, adică dvb - s.
Eu știu că doar la serii mai mari de 7 mii sau 8 mii au pus cei de la Samsung și satelit.( Tuner de satelit)
Di gi doar pe cablu funcționează cu kley.
În setările tale ai Caid-uri pentru provideri care nu te interesează de pe satelit: HD...etc
La CAID poți lăsa doar 1801
Și ident 1801:002111
Tu unde ai pus softcam key?
In folderul oscam trebuie pus.
Tu in folderul oscam mai ai alt folder "config" unde ai pus și softcam key ?
De ce vrei versiuni mai noi de oscam dacă nu ai și mufa pentru satelit?
Versiunile mai noi de oscam sunt pentru alte tipuri de cheițe power Vu
Librăria liboscam H ai citit tu că e bună pentru tipul tau de TV?
Cum scrie in meniul tv tău exact: tipul televizorului?
T-NT?
Probabil ai nevoie de o altă librărie pentru tipul tau de televizor.
Salut!
Pe un UE32ES6710 cu software T-MST10PDEUC-2009.0, BT-G se mai poate pune oscam?
da, se poate. mergi pe forumul samygo si download ce-ti trebuie... e free
Am facut downgrade la 0000 dar nu pot sa fac contul develop. Am intrat in Smart Hub<Tools<Settings< dar aici Account Manager este inactiv.
Aveti idee care e problema?
Nu cred că trebuia neapărat să faci downgrade.
Respectivă informație a fost necesară la un anumit timp.
In fine hai să rezolvăm problema.
Din câte știu eu downgrade la 0000 se face pentru a putea să schimbi versiunea firmware a TV ului pentru ai putea face Root.
Cred că acum tu trebuie să upgradezi o versiune de soft pentru a avea acces la toate opțiunile, inclusiv user develop.
Nu am citit(studiat) metoda de Root la seria ES, dar principiul este la fel: intri in meniul de service și oprești OTN suport, uneori la ultimile versiuni de soft opțiunea OTN suport era ON dar era de culoare gri inaccesibilă și de asta se făcea downgrade.
La unele versiuni trebuie să intri in meniul de service extins cu 3factory Speed . Dacă ai un telefon pe android cu port infraroșu îți pot da o aplicație care transmite televizorului fișierul 3factory Speed și intri destul de ușor acolo pentru a pune OTN suport pe off.
Trebuie să citești tot atent despre root la seria E:
Am inteles!
Acum caut SamyGO_data_E.zip si SamyGO-F-SM-MST-Fix-USB. Trebuie sa ma inregistrez ca sa pot face download de pe samygo? Daca da, poate imi zici si mie cum sa fac. Eu am gresit cand am facut prima incercare de inregistrare si acum zice ca trebuie sa mai astept dar nu spune cat! De 3 ore tot imi zice ca nu ma pot inregistra.
Trebuie instalat skype sau nu?
Am rezolvat un update pe off.
---------- Post added at 22:39 ---------- Previous post was at 22:29 ----------
Am gasit pe undeva pe samygo cele doua arhive dar acesta e raspunsul la download......The selected attachment does not exist anymore
Ce trebuie să faci este sa nu te grăbești.
Citește tot atent și apoi dacă ai înțeles pașii faci totul pas cu pas.
Pentru toate arhivele pentru seria e
cu ultimul soft:
Unpack attached SamyGO_data_E.zip to FAT USB
Nu gasesc arhiva.
Download and extract 128mb.xfs from: [Only registered and activated users can see links. Click Here To Register...] ... YnMLVKqU4o
128mb.xfs l-am descarcat
Copy file 128mb.xfs to folder SamyGO_data on FAT USB
Nu am inca samygo_data
Unpack SamyGO-F-SM-MST-Fix-USB to FAT USB
Nu am arhiva
Am citit, spune clar ce trebuie sa fac dar nu am cu ce.Nu ma pot inregistra.
Vezi postul meu dinainte am mai editat la el.
Ai acolo ce trebuie.
Caută să nu te grăbești
Cred că tu trebuie sa pui ce ai descărcat in samygo dată E , nu simplu *"samygo data".
Cred că simplu samygo data E pentru seria F cu ultimul soft.
