Pune si tu imaginile alea mai mari, te rog, ca sa nu fie nevoie sa ne mai inregistram pe forum
OK!
Daca s-a rezolvat ce ma deranja pe mine (adica afisarea informatiilor cu ptest ) ar fi cea mai buna img ptr clone .Am sa incerc azi .
Iar aici fisierul pentru DM500;
Sattv-forum image 1.2
DM500
S-a rezolvat , merge si ptest adica skinul gen enigmatique ,si au o noua imagine de boot.
Testata , am verificat daca are bomba si nu are (verificat cu dm500_clone_bomb_checker_v1.0). Are alta imagine de boot fata de 1.2 si in rest nu am vazut nimic.
Sattv-forum image 1.3
DM500/DM56X0/DM7000/IPBox200S/IPBOX250S
Technical Infos:
CVS Version: 11.05 2008
Linux kernel version: 2.6.9
GCC 3.4.4 Original CVS
Web Inteface 6.0.4-Expert
Busybox 1.01
BLUE - Blue Panel (Emu Addons)
1 sec BLUE - ECM Info
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Download Addons - Emus,keys,Plugins,Setting....
Manual Install Addons tar.bz2
Delite Addons
Fix & Add:
Add missing file
Fix create new bouqet bug
Fix crash on inadyn
New bootlogo by Ohem2000
IPBox200S:
Last Kernel: 2.6.17 (Thanks to Sandali)
U-Boot: 1.2.0 (Thanks to Sandali)
New driver from sandali
IPBox200S mID 20
IPBox250S:
IPBox250S mID 25
IPBox login:
user:root
password:ipbox
Thanks to Ohem2000,tobe,burster for helping me!!!!!!
Support: [Only registered and activated users can see links. Click Here To Register...]
This image doesn't include keys or emulators.
Sattv-forum is not responsible any damage caused by this software.
DOWNLOAD
Adminul de pe sattv-forum a specificat asta , referitor la intrebarea daca vor introduce in imaginile lor time bomb ptr clone.
jasko
post Yesterday, 03.06.2008 17:20
---UNKNOWN---
Group Icon
Group: Administrators
Thank(s): 64
Dont panic there is no time bomb in sattv-forum image.
IPBox200S Sattv-forum Image 1.3
Sattv-forum Image developer
sattv_forum DM500_1.2
Technical Infos:
Busybox 1.01
YELLOW - plugins
RED - EPG
GREEN - subservices
Blue Panel Info:
Start/Stop Emu
Green - News
Red - Sys Info
Blue - Addons
Yellow - Settings
Addons info:
Delite Addons
Removed:
1 sec yellow emuinfo you can download from addons server
Old sattv-forum news
Add:
Add support for picons (Put picons in var/tuxbox/icon *png) thanks to fergy
Add Preview skin
Add ebrowser (brows your box directory thanks to emanuel)
Add News reader
Add manage movie folder
Add Web Interface 6.0.4-Expert
Add MHW EPG
Add hide ecm info in OSD
Add easy swap script over NFS (Thanks to tobe)
Add supprt for VLCF 1.8.0
Add RF Modulator Option (IPBox)
Moved rcdmxxxx to var/tuxbox/config/enigma/resources now you can manual edit file
Fix:
Fix some bugs in Blue Panel
Fix bug with Movieplayer now works
And more..........
IPBox200S:
Auto mID
Add New driver from Enigma Basic rel.5 (Thanks to Sandali)
Change EPG button use now EPG button (200s)
IPBox250S:
Auto mID
Change MID to 25
If you want multiboot on ipbox250S change MID to 05 dm7000 And multiboot works
IPBox login:
user:root
password:ipbox
New skin DarkCenter
New bootlogo
Deja au scos versiunea 1.3 , ai ramas in urma un pic .
Asta acum a fost pusa la downloand deoarece mai intai sunt.....testate!Quote:
pe dm500 clona, care este recomadarea de(de la dm500 ) versiune pe care o recomandati?
Orcare din versiunile de mai sus sau; geminii 420.Quote:
deci pana la germini 4.20?
pot sa pun fara bomba asa zisa?
am dm7025 dar nu lam modificat pana acum am luat un dm 500(vb vine e o clona) cu care sa ma pot juca si acum vreau sa vad ce poate chiar daca e sa ajung la jtag nu e problema, dar daca pot evita e si mai bine!
Pana la geminii 420 inclusiv poti folosi orce imagine vrei pe clona.Quote:
Am testat sattv 1.3 dar nu vad diferente fata de 1.2 decat imaginea de boot.
