Page 1 of 9 12345 ... LastLast
Results 1 to 15 of 123
Thread: Optibox cx extra pvr ready - Noutati.
    Standard RSP member gigibamse's Avatar
    28 Jan 2009
    London.
    Thumbs up Optibox cx extra pvr ready - Noutati.
    In speranta ca ne vom ajuta reciproc,postati noutati cu privire la NEW SW ORIGINAL si PATCH - numai pentru OPTIBOX CX EXTRA PVR READY (pentru a evita confuzia si a pastra ordinea intre receptoarele OPTIBOX).
    Sper sa va ajute:http//:www.sat-support.org/.
    28 Jan 2009
    London.
    Default Re: Optibox cx extra pvr ready - Noutati.
    New sw for Optibox v1.17.71
    - sharing is working now
    - added small window in channel edit menu
    Optibox.CX_PVR_Ready.Extra.v1.17.71.2009Jul01.rar
    http://www.sat-universe.com/showthre...=101122&page=2
    Standard RSP member romero69's Avatar
    05 Dec 2008
    Romania Satu Mare(Acis)
    Post Re: Optibox cx extra pvr ready - Noutati.
    A aparut si pentru FTA PVR Ready?
    28 Jan 2009
    London.
    Doar Optibox_cx_extra_pvr_ready si HDMI_PVR_Ready.
    28 Jan 2009
    London.
    Noi versiuni de soft OptiboX;
    - Added newcamd sharing by RS232...
    - In cardsharing menu, select "single share".
    - For this type of sharing You must add the caid in providers! (find the application in 'Tools') added PIG (Picture-in-graphic) function in channel editor.
    http://sat-support.org/
    28 Jan 2009
    London.
    Original firmware (no patch)
    Daca aveti ceva probleme in instalarea unui sw patch si nu pot fi remediate,se da factory reset (resetare de fabrica)si apoi se instaleaza acest sw original (de regula prin cablu null modem,rs 232)dupa care puteti instala sw-ul patch care doriti.
    01 Mar 2008
    No Man's Land
    http://optibox.cc/?a=products -pare mai simplu aici ... fara inregistrare.Decat alegi receptorul si sectiunea software... (si te bucuri si de noutatile care au aparut)
    01 Mar 2008
    No Man's Land
    New SW 1.17.80
    24 Sep 2008
    Suceava
    Deschide cineva tv globo de pe hotbird cu acest receptor? Daca da, cu ce soft? Eu am incercat cu mai multe softuri, am pus si ultimele key dar la toate a ramas ecranul negru!
    01 Mar 2008
    No Man's Land
    New firmware 1.17.85
    01 Mar 2008
    No Man's Land
    Optibox 1.17.93 fixed B*SS and some other bugs...
    02 Jun 2008
    Am o problema la un cx extra pvr ready si vreau sa stiu daca este nevoie sa il trimit la garantie sau ii pot face ceva. Are acum instalata ultima veriune de soft aparuta, dar si cu altele 2 (cea cu care a venit si inca una) a facut la fel.
    Fara nici o logica din cand in cand imaginea trece pe alb/negru, ramane blocata, afisajul aprins dar uneori telecomanda functioneaza. Il scot din priza si porneste normal, dar dupa un timp (cateva minute) face a fel.
    Uneori merge ore intregi si nu are nici o problema. Chestia asta se intampla am observat seara. Ziua pare ok.
    M-am gandit a fie sensibil la fluctuatii de curent (cu toate ca la alte aparate din casa nu observ probleme) sau sa aiba vreo buba de fabricatie.
    Dati-mi va rog ceva idei sau sfaturi.
    05 Jun 2008
    Ploiesti
    cu ce program se poate pune softul pe optibox prin rs 232 [cum este chEdit pt echolite] multumesc .
    28 Jan 2009
    London.
    Thumbs up Re: Optibox cx extra pvr ready - Noutati.
    Salut.
    Ai aici;
    Instructions how to use the tool Porter Software, Keyfile and channel lists on the following receivers played. OPTIBOX FTA PVR, CX PVR, TSCX PVR, PVR FTA PRIMA via RS232
    http://www.sat-universe.com/showthread.php?t=112982
    si aici gasesti loderul se numeste Porter.
    http://www.sat-universe.com/showthread.php?t=112977
    multa bafta
    01 Mar 2008
    No Man's Land
    Default New firmware v1.18.04
    New sw for Optibox PVR's_1.18.04! Fixed bug with card reader & Added CCCam Dongle sharing option. For home sharing use 9600 baud rate
    http://www.sat-support.org/
