Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 127
Thread: AZBOX HD Emu
  1. #61
    10 Nov 2008
    Din pacate nu functioneaza ; libc.so.6 da eroare : cannot handle TLS data .
    Trebuie refacut si scriptul dvbapi_module care gestioneaza cccam.mipsel .
  2. #62
    26 Jul 2007
    Default CCcam 2.1.4 for AZ Box HD
    Download PLUGINS.rar
    Extract PLUGINS.rar and you will have 3 folders
    Folders CCcamFakeRoot ,OpenXCAS and realcccaminfo
    Put folders in Azbox PLUGINS folder..
    Open PLUGINS/OpenXCAS/libdvbapiCAS all file 755 mode
    Open PLUGINS/realcccaminfo all file 755 mode
    Edit module.seq edit and add libdvbapiCAS
    /PLUGINS/CCcamFakeRoot/etc/ folder put CCcam.cfg
    Restart Azbox and select libdvbapiCAS from plugins menu
    Thanks to kanber_kav
    http://www.megaupload.com/?d=U4C246RG
  3. #63
    06 Jun 2008
    Default Concluzii
    Pare destul de stabil, dar.... lipsesc functiile streaming si rec. Nu merg.
    Probe facute cu FW 4295 si KGD 4348
    FW + Multicas 162b + 3c 0.2+ 3c 2.1.4
    1. Multicas vede si stream si rec (freeze in HD)
    2. 3c 0.2 (mai stabil) vede si stream si rec
    3. 3c 2.1.4 destul de stabil dar fara suport stream si rec.
  4. #64
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    Default MultiCAS v1.62C
    -DATE : 2010/02/24
    -Version : v1.62C
    MOD : More improve about CCcam client mode for CCcam 2.1.4
    ADD : Add support DT08 for Nagra (HD+ will be work)
    ADD : Add support about working together CCcam and Newcamd
    -- check the splitterdata.txt 'CCCAM_NEWCAMD_WORK_TOGETHER = 0' -
    Attached Files Attached Files
    RSP-TEAM
  5. #65
    14 Feb 2007
    Baia Mare
    Default MultiCAS v162C-A01 2k100228
    RSP-TEAM
  6. #66
    14 Feb 2007
    Baia Mare
    Default multicas v1.62C-A03A
    new multicas v1.62C-A03A
    -fixed bug in careader
    -fixed bug newcamd and cccam ok...
    RSP-TEAM
  7. #67
    14 Feb 2007
    Baia Mare
    Default MultiCAS_v162C-A03b NET BR
    NOVEDAD HD RECEIVERS SAT E CABLE 06-03-2010...
    RSP-TEAM
  8. #68
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162C-A04
    MultiCAS-v162C-A04
    RSP-TEAM
  9. #69
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162D-A01
    MultiCAS-v162D-A01
    at moment no changelog
    Se poate descarca din meniu...
    RSP-TEAM
  10. #70
    14 Feb 2007
    Baia Mare
    Default MultiCAS 1.62D-A03
    22-03-2010
    FIX : Fixed s#y Italia
    RSP-TEAM
  11. #71
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162D-A04 SAT E NET OK
    RSP-TEAM
  12. #72
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Exclamation Link refacut:1.62D-A05
    -DATE : 2010/04/05
    -Version : v1.62D-A05
    FIX : Fixed about CONAX Update
    tks @licapavel
    Download
    Azbox HD with OpenSPA 3.0 powered by OSCam
    UE46F8000 powered by SamyGO_OSCam
  13. #73
    14 Feb 2007
    Baia Mare
    Default MultiCAS v1.62D-A06
    Added emu for I2 of NOVA (Need to put a key by manual : 10 06 04 - 06/16 or 08/1
    RSP-TEAM
  14. #74
    14 Feb 2007
    Baia Mare
    Default multiCAS-162D-B01
    multiCAS-162D-B01
    FIX : Fixed some channels with Freeze
    MOD : More improve about Re-Connection to CCcam's Server
    MOD : Message disabled in connection with "Connect to Server"
    RSP-TEAM
  15. #75
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162D-B02.tgz
    MOD : improve about Betacrypt
    MOD : Message Enable again in connection with "Connect to Server"
    RSP-TEAM
