Page 8 of 9 FirstFirst ... 456789 LastLast
Results 106 to 120 of 127
Thread: AZBOX HD Emu
  1. #106
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    Default Oscam azbox hd
    recomand rev.2991 pare cea mai stabila si rapida(zapping /meniu)
    setup-ul meu:
    Code:
    [global]
    pidfile                       = /tmp/oscam.pid
    usrfile                       = /tmp/oscamuser.log
    logfile                       = stdout
    cwlogdir                      = /tmp/cw
    disablelog                    = 0
    disableuserfile               = 0
    usrfileflag                   = 0
    clienttimeout                 = 5000
    fallbacktimeout               = 2500
    clientmaxidle                 = 120
    cachedelay                    = 120
    bindwait                      = 120
    netprio                       = 0
    clientdyndns                  = 1
    resolvedelay                  = 30
    unlockparental                = 1
    nice                          = -5
    serialreadertimeout           = 1500
    maxlogsize                    = 10
    waitforcards                  = 1
    preferlocalcards              = 1
    saveinithistory               = 1
    readerrestartseconds          = 5
    readerautoloadbalance         = 1
    readerautoloadbalance_save    = 100
    [monitor]
    port                          = 988
    serverip                      = 192.168.2.X
    nocrypt                       = 127.0.0.1,192.168.2.1-192.168.2.40
    aulow                         = 120
    hideclient_to                 = 0
    monlevel                      = 4
    appendchaninfo                = 1
    [newcamd]
    port                          = 34000@0500:FFF720,025900;34001@092F:000000
    key                           = 0102030405060708091011121314
    allowed                       =
    keepalive                     = 1
    mgclient                      = 1
    [cccam]
    port                          = 12001
    reshare                       = 2
    version                       = 2.1.3
    [dvbapi]
    enabled                       = 1
    au                            = 1
    boxtype                       = none
    user                          = dvbapi
    pmt_mode                      = 1
    priority                      = 093B,1880,09C4,1702
    ignore                        = 09C7,1802
    [webif]
    httpport                      = 808
    httpuser                      = root
    httppwd                       = *******
    httprefresh                   = 5
    httpallowed                   = 127.0.0.1,192.168.2.1-192.168.255.255
    httphideidleclients           = 0
    httpreadonly                  = 0
    Azbox HD with OpenSPA 3.0 powered by OSCam
    UE46F8000 powered by SamyGO_OSCam
  2. #107
    26 Oct 2009
    Walachia / Paname
    2 versiuni oscam cu Info ECM ( tasta >>)
    oscam-0.99.4-SB-svn2894-si 3032
    OpenXCAS.conf:
    Code:
    [module]
    name = oscamCAS
    daemon = oscam_module
    #daemon = oscam_module -255
    version = 1
    INFO = /tmp/ecm.info
    REFRESH = 2
    Afisarea:
    caid: 0x093B
    pid: 0x06A7
    prov: 0x000000
    reader: cccam-topex
    protocol: cccam
    hops: 2
    ecm time: 0.759
    cw0: 00 00 00 00 00 00 00 00
    cw1: 00 00 00 00 00 00 00 00
    oscam-0.99.4-SB-svn2894-azbox-mips.zip Size: 308,3 Kb
    oscam-0.99.4-SB-svn3032-azbox-mips.zip Size: 322.1 Kb
  3. #108
    26 Oct 2009
    Walachia / Paname
    oscam3066_dvbapi_webif_ecminfo
    (patch)
    changelog:
    r3066 | schlocke | 2010-09-14 13:55:50 -0700 (Tue, 14 Sep 2010) | 3 lines
    cccam: cc_maxhop fix
    removed some unnessasary logmessages
    openxcas.conf:
    Code:
    [module]
    name = oscamCAS
    daemon = oscam
    version = 1
    REFRESH = 2
    Code:
    caid: 0x0500
    pid: 0x0021
    prov: 0x025900
    reader: smargo1
    protocol:
    hops: 0
    ecm time: 0.343
     cw0: 8D FC 9A 23 2D 84 F8 A9
    cw1: D5 BC 42 D3 4D FD AC F6
  4. #109
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162E-A12 full update 22-9-2010
    Bulsat 39°E Hellas
    Attached Files Attached Files
    RSP-TEAM
  5. #110
    26 Oct 2009
    Walachia / Paname
    Default MultiCAS-v162E-C02
    MultiCAS-v162E-C02
    MultiCAS
    -DATE : 2010/10/18
    -Version : v1.62E-C02
    MOD : More stablility to better for CCcam server of 2.1.0 / 2.1.1 / 2.1.2
  6. #111
    26 Oct 2009
    Walachia / Paname
    Default MultiCas v1.62E-C03A
    MOD : Improve about send ECM for Newcamd
    MOD : Already added 'INFO = /tmp/ccc_ecm.info // REFRESH = 2' in openxcas.conf (>> key will be working to direct)
  7. #112
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162E-C06
    Added support multi-AES key for TNTSat and CSat via new_via.key (Already included active AES Key)
    RSP-TEAM
  8. #113
    14 Feb 2007
    Baia Mare
    Default MultiCAS-v162E-C07
    MultiCAS-v162E-C07
    MultiCAS
    -DATE : 2010/11/24
    -Version : v1.62E-C07
    ADD : added via 3.0 emu (add working 03xxxx in new_via.key)
    MOD : Improve for new server of CCcam 2.2.x (Need more test..)
    RSP-TEAM
  9. #114
    14 Feb 2007
    Baia Mare
    Default MultiCAS v.162E C07A
    This MC has been more update as below
    1. TNTS*t for official CARD
    2. TNTS*t for EMU
    3. New CCcam 2.2.x Updated
    RSP-TEAM
  10. #115
    14 Feb 2007
    Baia Mare
    Default MultiCAS v1.62E -C08 15.12.2010
    MOD : More Improve about new server of CCcam 2.2.x
    FIX : Fixed about TNT emu and card
    FIX : Fixed about boxkey for NDZ3 of SkyITA
    FIX : Fixed New Sky-Link (White card : Need testing..)
    RSP-TEAM
  11. #116
    26 Oct 2009
    Walachia / Paname
    Default MultiCAS_v162E-C11B_2k110124
    -DATE : 2011/01/24
    -Version : v1.62E-C11B
    FIX : Fixed small bug of ECM for Irdeto
    Download:
    MultiCAS_v162E-C11B_2k110124.tgz (608.05 KB)
  12. #117
    26 Oct 2009
    Walachia / Paname
    Default MULTICAS v1.62E-C11C
    MultiCAS
    -DATE : 2011/01/27
    -Version : v1.62E-C11C
    MOD : More improvement about DRE-Cr*pt for CCcam and Newcamd
    Download:
    MultiCAS-v162E-C11C.tgz (608.26 KB)
  13. #118
    26 Oct 2009
    Walachia / Paname
    Default MultiCAS v1.62E-C11D
    MultiCAS
    -DATE : 2011/02/08
    -Version : v1.62E-C11D
    FIX : Fixed minor bug about log-in part of Newcamd
    FIX : Fixed about make to slow something by CCcam
    MOD : More improvement about EMM for Cryptoworks Card
    Download:
    MultiCAS_v162E-C11D_2k110208.tgz (608.45 KB)
  14. #119
    Standard RSP member iceman's Avatar
    13 Sep 2007
    Cluj-Napoca
    Cu ultimele versiuni de Multicas nu mai vrea să-mi mearga nici in ruptul capului Sky UK, cu toate că am linie bună. Cred că asta are legătură cu implementarea in prio.caid a chestiei cu "pre fix hops" pentru NDS, cu toate că alte pachete criptate in NDS merg.
    Am incercat cu o versiune mai veche de Multicas (A10 parcă) şi Sky UK merge fără probleme. Nu inţeleg de ce nu merge pe versiunile actuale de Multicas, posibil să fie ceva configurat greşit. Vreo idee?
    Cluj-Napoca
    AzBox HD Premium, HDD Western Digital Caviar Green 750 GB, conservă Hyundai HSS 3169,
    Antenă toroidală T90 12 LNB (Astra 1, Astra 2, Astra 3, Astra 4, HB, W2, Thor, Amos, Eurobird 9, Badr, Hellas, Turksat)
  15. #120
    10 Nov 2008
    Sensul la pre fix este ca decodarea sa se faca NUMAI din hop-ul ales prin configurare in priocaid.cfg .
    Exemplu :
    09xy : 1
    Va deschide pe providerul 09xy NUMAI din hop 1 .
