Dislikes:
- Rep Power
- 82
Mbox Manager 1.9 (2009.11.06)
- Autorefresh position save
- Customizable default status filter
- Added Intruder alert Table: count alerts when the mbox log is enabled (MBOX Log -> Intruder alerts)
- Added Offline peer alert function (Options -> Settings -> Peer alert)
Info: If this function is enabled, on data refresh will appear a list with your offile peers who are offline more than setted days. If you have some exception peers (don't want to alert you), add them to the ignore list (you can add/remove when the alert window is showed).
<A href="http://www.2shared.com/file/8982782/86e95e63/mbox_manager_19.html" target=_blank>http://www.2shared.com/file/8982782/86e95e63/mbox_manager_19.html
AB IPBOX 9000HD
DVB/S2-CABLE TUNER
