Thanks Thanks:  16
Likes Likes:  18
Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 91 to 105 of 210
Thread: Sbox - New cardserver/emu
  1. #91
    Moderator sorin8m's Avatar
    22 Apr 2007
    Eu am sbox, dar nu cu card de conax. Din catea stiu eu conax merge direct in cccam.
  2. #92
    03 Sep 2008
    Default Sbox - New cardserver/emu
    pune cardu in rec original si dezactiveaza pinul
  3. #93
    29 Nov 2008
    Cu capu' in nori
    SBox 0.0.5-2 Testing Version
    Translated using google
    SBox upload this version for those of you interested the testing. There have been changes in the newcamd server to try to achieve greater stability, have also been small changes to the client CCcam. In the webinterface has added a little chat.
    Attached Files Attached Files
  4. #94
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.5-2 #3 (Tests)
    The minimum value of the timeout on the server newcamd goes from 300 to 150 seconds. Now the file can be locked port.list channels have not hired (SF), an example;
    code:
    SF: {1234} # block this channel / Block This channel
    SF: {2345} # block this channel / Block This channel
    SF: {3456} # block this channel / Block This channel
    # the other channels are accepted / all channels are accepted Others
    One note, if you mix SA and SF in the same file will only accept the first one it finds an example;
    code:
    SF: {1234}
    SA: {2345}
    SF: {3456}
    The first to appear is a SF therefore all SA held on the port.list be ignored.
  5. #95
    29 Nov 2008
    Cu capu' in nori
    Hi, I raise this version of SBox for those of you interested the testeeis. There have been changes in the newcamd server to try to achieve greater stability, have also been small changes to the client CCcam. In the webinterface has added a little chat. Greetings
    thx to EDK
  6. #96
    29 Nov 2008
    Cu capu' in nori
    SBox 0.0.5-2 # 5 (Tests)
    I made ​​major changes on both the client and the server (CCcam) hoping to solve the falls that occurred.
    Other small changes.
    thx EDK
  7. #97
    29 Nov 2008
    Cu capu' in nori
    New SBox 0.0.5-2 #6 (Tests)
    - Small bug fixes in general
  8. #98
    Golden Member gigelsat's Avatar
    PPC, MIPS, X86_64, X86, SH40, Fritz
    Poate explica cineva pentru ce e fiecare dintre versiuni?
    De exemplu, eu in DM800 ce varianta pun?
    Multumesc.
    Gigel
  9. #99
    29 Mar 2009
    Austria - TM
    gigele nu ai mai lucrat de loc cu Sbox sau Oscam ?
    sbox.ppc enigma1
    sbox.mips enigma2
    sbox.x86 linux pc (32 bit)
    sbox.x86_64 linux pc (64 bit)
    sbox.sh40 qbox/ipbox/kathrein
    sbox.fritz fritbox routers
    care tre sa pui in Dm 800 ?
    Bafta la configurari
  10. #100
    Pai eu am un n3 in sbox, cred ca de vreo 2-3 ani n-am mai umblat la setari, efectiv de atunci am mai actualizat doar rar lista de canale. Cand am pus eu sbox nici nu stiu daca erau atatea variante, am gasit una pusa si explicata de un coleg si e OK si astazi inclusiv face update. Pentru ca ecm time e in jur de 0,300-0,320, ma gandeam ca poate cu o versiune mai noua sa fie scurt.
    Evident, pt DM 800 voi pune cea pt enigma2.
    Multumesc.
    Gigel
  11. #101
    29 Post(s)
    Daca folosesti port.list, si ar fi foarte bine sa-l folosesti, verifica in el ca s-au schimbat destule SID-uri. Exemplu cel mai recent ar fi TVR3
    Nu cred ca vei obtine alt ecm time, nu tine de sbox...
  12. #102
    06 Mar 2010
    Default sbox
    Salut, la dm500hd cu newenigma 3.3.1 cum instalez manual sboxul , in server
    nu am decat oscam, cccam etc, ex: sbox fritz,sbox mips, sbox ppc e.t.c , in ce director le pun pe fiecare in parte , nu ma descurc manual rog ajutor Multumesc!.
  13. #103
    Membru de onoare
    08 Apr 2007
    Foloseste configurarile pentru DM500 si schimba binul cu sbox.mips redenumindu-l in sbox simplu.Iti va mai trebui scriptul pe care il faci dupa modelul unui script de oscam sau cccam de pe receptor,aici depinde de imaginea pe care o folosesti si e greu sa iti dea cineva un script functional.Cred ca era o arhiva prin topic si explicatii.
    Am testat ultima versiune dar tot crapa ca si client cccam.A mai incercat cineva sa puna linie din cccam in sbox?
  14. #104
    29 Mar 2009
    Austria - TM
    SBox 0.0.5-2 # 7 (Tests)
    - (CCcam-Server) Fixed bug that caused a timeout on clients
    - (Viaccess) You to added support for multiple keys aes, more info in the sbox.conf
    - ( Viaccess) You to added support for the nano and ECMs d2 long (thanks to mitega) without checking
  15. #105
    31 Jan 2008
    Rog confirmare ca updateaza cardu 1880.Si mai exact ce versiune.
Tags for this Thread
