Dislikes:
VIP
- 0
PGI v0.5 for Ipbox 9000HD
PGI v0.5 for Ipbox 9000HD PGI v0.5
Many thanks to uncle.f for contributing to this release!
Features
- Based on GSA 11,577
- HD channels to function smoothly, thanks to fixed second driver.
- Newcs, mgcamd-1.33, incubus and mbox are installed, but are pre-configured only newcs and mgcamd.
- Current stable busybox 1.15.3 installed.
The shell commands so that all the work, and the shell has a continuous history.
Moreover, the text editor nano is still attached to the console.
- Own card drivers.
- Streaming Player sbox fixed (server part):
Works better with encrypted channels, the quality of the stream.
- Reduce boot time
- Color keys covered with scripts to change emus (see below)
- And other minor changes ...
Changes
General:
- NFS share can be used as a disk replacement
- Support for DRE-Cam's
- Added: mg_launcher for people who have problems with the normal mgcamd.
- Update: WebIF 1.5
- Update: Busybox 1.15.3
- Update: Sqlite 3.6.21
- Update: e2fsprogs 1.41.9
sbox:
- Fix: auto mounting works again
- Fix: connected and disconnected to be translated into the no longer mount_manager_fstab
- Fix: The EPG parser no longer hangs on channels with just now & next information (thanks to kneubi)
- Function of PgUp / Down buttons, and buttons in the channel and favorites lists exchanged
- Timeshift can be terminated with the stop button
- Recording playback can now be stopped directly in the file list
- Normal volume bar is displayed in the video player
- Inquire password can now generally by purchase or option to be switched off (in the Parental Control menu)
- The volumes are stored by channel switch when applied immediately
- The channel list can be sorted Alphabetically with the blue button instead of jumping to your Favorites.
The favorites are still accessible via the FAV button.
- Multicast in streaming player working again
- Unicast streaming option on the player away. If you only need unicast should rather use the WebTV Webif.
- WWW button on the Fb may be assigned a script, / bin / var / www.sh
- New menu item in the main menu Forecasts
- OSD Screenshots now work in WebIF
Configuration
The image specific configurations are in / var / etc.
boot_services.cfg
This specifies which services are started at boot.
Services are for example samba, nfs, newcs, etc.
In addition, here are the skin and the standard set emu.
my.zooms
List of zooms are available.
Is used by the Open button.
my.ethaddr
If the box crashes or is shut down properly, then change the next time you boot the mac address
the NIC.
In this file, you can enter a fixed mac address, which is always maintained, even after crashing.
Example of the contents: 12: BB: CD
One can only represent the three most recent change of address, the first three are always 00:13:18.
Not have this file, it will automatically use the current address.
nonstandard_encoding
With the fan scrplg script disable.sh the fan-in boxes without HDD can be permanently disabled.
To run the script in the plugin script.
Functions on color keys
Red => Favpip
Yellow => Emu restart
Green => zoom mode switch.
Have fun,
pacco
http://hotfile.com/dl/23915900/3f6ac...-v0.5.zip.html
