Thanks Thanks:  2
Likes Likes:  2
Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 239
Thread: Optibox Koala HD, ATEVIO 700 HD, OCTAGON SF 1008 HD
    19 Post(s)
    Noua versiune de MCAS ( MultiCas ) pare sa miste bine ! AKTA, FOCUS si ...
    DOLCE ! Am luat cardul meu de Dolce ...l-am introdus in slot ...si s-a facut lumina !
    fara BoxKey ... asa pur si simplu !!! s-a facut lumina pe programele la care aveam subscriptie !
    19 Post(s)
    A aparut o noua versiune de firmware Optibox Koala 1.07.97 !
    Noutatile versiunii nu sint prea numeroase :
    - ridicarea unor mici anomalii
    - un nou skin "Modul albastru" vechiul fiind "Modul rosu"
    Iata si nota de lansare oficiala :
    Changelog:
    1. STB dead issue by long time watching : fixed.
    System config register changed
    2. Multifeed bug fixed
    3. CI Iredeto CAM recognition error fixed.
    4. Video codec updated to lates version (this codec is upgraded for week signal).
    5. Wi-Fi WPA2 security connection bug fixed.
    6. MHW EPG problem fixed
    Imaginea se misca excelent si cu noul skin este mai vesela ...prietenoasa ...
    Noutatea cea mare este alta ... in acest weekend va apare prima imagine
    Enigma2 operationala
    ... ca rezultat al colaborarii grupurilor de la HD-Freaks si
    AAF !!! si se pare ca va fi o imagine flash ! Platforma destinatie este
    Octagon 1008 / Optibox Koala. Procedura de instalare va implica ..deocamdata o
    manevra de upgrade bootloader ... cam riscanta dar vom vedea cu ce suport !
    19 Post(s)
    Default Versiune noua a "plugin"-urilor Koala !
    MCAS ( Multi CAS System )
    - TimeShift + Record bug fix (forward back spooling,trickmode)
    - Stability imporved
    - Minor bugs fix.
    XCAM Client
    - CCcam improved
    - Newcamd Newcs libary update
    - Minor bugs fix.
    - Important : Pls use with SW 10797 !
    Constatari ... merge uns pe Sky Italy !!! cu frezes rarisime de cca o secunda !
    O excellenta performanta pe servere CCcam 2.1.3 !!!
    ---------- Post added at 18:25 ---------- Previous post was at 17:24 ----------
    PVR la Optibox Koala
    Sistemul PVR la Koala este dintre cele mai complete vazute la un receptor Non-Enigma
    ... spun asta pentru ca permite :
    - inregistrarea programelor FTA sau codate si redarea lor cu decriptare daca este cazul
    - inregistrarea se face in format .TS dar tentativa de redare prin VLC pe PC a esuat ... mai incerc !
    - fiind un format de tip transponder stream ... evident necomprimat , calitatea este excelenta dar
    cu pretul dimensiunii fisierului ... o inregistrare de 1 minut in format 720p ocupa cca. 100Mb pe disc
    - playerul poate reda formatul .TS propriu dar si fisiere XVID ( .avi) de pe discul local sau de pe un drive
    de retea !!!
    - fisierele XVID pot avea inclusiv subtitrare model .srt cu diacriticele specifice limbii de meniu alese
    - inregistrarile in format .TS preiau inclusiv canalele de sunet alternativ
    19 Post(s)
    Default Noua versiune de "plugin"-uri Koala
    Emulatorul oficial Octagon suportat si de Koala :
    - CCcam version update 212+213
    - CCcam libary update
    - Stability improved
    - OSD Font changed
    - Important :
    --> existing Plugin Format User Data (Green Button) User Data Download !
    Personal prefer XCam pentru stabilitate si complexitate !
    19 Post(s)
    Default Un nou "release" de firmware Koala v1.08.01
    History Release Note
    - v1.08.01 / 2010. 03. 23 / Build Version : 2801
    1. Freezing Scrren when Flash writing : fixed
    2. Diseq Command error : fixed
    3. Voltage changing issue when receiver turn to standby condition during recording: fixed
    4. not appearing popup message for plugin download : fixed
    5. Audio delay sync feature added and it can set on AV Output Menu
    6. Recording fail message appears in case default recording device is set incorrectly: fixed
    receiver will ask to find correct recording device.
    7. incorrect channel searching result between two TP which has very near frequency : fixed
    receiver operated it as same TP with last version SW.
    8. TP data update(eutel W2 16.0E), new Satellite added (eutel sesat 1 16.0E)
    9. receiver hangup in System Informaiton Menu: fixed
    Ca orice noua editie ( versiune majora ) cumuleaza toate reviziile precedente si introduce
    o noutate importanta ... o versiune nou de Kernel :
    Linux hmp7109 2.6.17.14_stm22_0039-HMP_7109-STFAE #106
    PREEMPT Thu Feb 4 14:11:10 K ST 2010 sh4 GNU/Linux
    Odata cu lansarea noii versiuni au aparut si noul XCamClient in care s-au
    adus unele compatibilizari la serverele CCcam 2.1.2 si 2.1.3.
    Golden Member istvan's Avatar
    14 Feb 2007
    Baia Mare
    RSP-TEAM
    19 Post(s)
    Pe Optibox koala puteti folosi dispozitive de retea (NAS) pentru a inregistra sau reda
    filme in formatul intern sau divx ( doar pentru redare )! Pentru a descrie accesul la
    acest tip de dispozitiv trebuie procedat astfel :
    - identificam IP-ul PC-ului ( sa zicem 192.168.1.3 )
    - cream un director local ( sa zicem /media )
    - facem un share pe acest director cu drepturi RW
    - descriem pe Koala conexiunea de retea astfel :
    192.168.1.3/media
    username ( din Windows)
    password ( din Windows )
    - din acest moment , odata conexiunea stabilita , putem scrie fisiere movie sau sa le
    redam pe Koala ele fiind gazuite de hardiscul PC-ului
    25 Mar 2010
    Where if firmware v1.08.01 for Koala?
    Thanks
    Quote Originally Posted by mihaip View Post
    Ce se mai aude cu instalarea/rularea imaginii E2 pe acest receiver ?
    19 Post(s)
    Situatia E2 Koala este urmatoarea :
    - echipa realizatoare a realizat o implementare E2 pe Ocatgon 1018 ,
    fratele mai mare a lui Octagon 1008 = Optibox Koala !
    - versiunea pentru 1018 este bine merci ...functionala !
    - versiunea pentru 1008 este pentru moment blocata in jurul problemei
    driverului de tunner ( este un tunner nou )
    - rezolvarea acestei probleme ar putea sa genereze o imagine E2 in cca
    doua saptamini
    - deocamdata astept si eu ca toti celalti interesti in soarta acstui receptor
    Ca sa citez pe un prieten de pe forum ( nu-l numesc pentru ca nu stiu daca
    doreste asta ) "este un receptor asa de bun ca n-are nevoie de Enigma" !
    Chestia cu Enigma este o moda ..sau si o moda ..dar recunosc ca daca ar
    avea o Enigma la fel ca cea de la IPBOX ...as prefera softul sau actual.
    @radik -- www.sat-support.org
    Ma joc cu aparatul asta de cateva ore cu imaginea originala si incubus.
    E rapid, stabil si nu se blocheaza.
    E o imagine originala foarte reusita, pe $K| UK a mers ore si doar facea usoare frame, comparabil cu un Dm800 !
    O sa testez si celelalte emulatoare care merg.
    LE:
    De mine vorbea Mihai mai sus!
    O zi frumoasa! Snow's Avatar
    Dupa parerea mea poti sa ai cea mai stabila enigma scoasa, daca n-ai emu bun......
    19 Post(s)
    Asta asa este ! 90% din succes sta in emulatoare ... si din pacate ... nimic
    nu se compara cu CCcam ...poate Oscam sa aiba sansa asta ... testele facute
    cu oscam pe Ipbox arata incurajator ..dar mai este mult ... pana departe !
    Zildan zice ca daca s-ar lucra serios 3 luni la incubus ...ar fi egalul CCcam !
    La Koala XCam creste rapid cu fiecare versiune ... dar nu prea are mecanism
    de prio asa ca ... mai vedem. Interesant este ca la CCcam si daca nu zici
    nimic la prio ... el tot se descurca !
    Blind scan cu Koala pe 0.8W, surprize mari:
    NRK1 HD 11372 V 24500 Conax
    Transponderul urmator nu apare pe KINGOFSAT!!
    M1 HD 11840 V 29999 Nagra si CW, prov: UPCD_Thor
    HBO HD HUN
    Nova HD
    Nova Sports HD
    CT1 HD
    ESPN HD 12399 H 28500 Conax
    TV 2 HD
    Din pacate nu reusesc sa scot toti parametrii de receptie din aparat .
    O sa mai incerc.
    Raman la impresia ca e un aparat foarte reusit, trebuie sa mai incerc si celelalte emulatoare.
    LE:
    Dsne Channel ROM e simulcrypt:
    CA Descriptor | CAID: 0b00, EMM PID: 03e6, PROV ID: 000000
    CA Descriptor | CAID: 0b02, EMM PID: 03e7, PROV ID: 000000
    CA Descriptor | CAID: 1815, EMM PID: 0378, PROV ID: 000000
    CA Descriptor | CAID: 0d02, EMM PID: 0309, PROV ID: 000000
    si mai sunt multe canale asa.
    MGM 12178 V 27999 are subtitrare DVB in RON si SLOsi somor in ENG, HUN si CZE, e codat :
    19 Post(s)
    He he ! v-am prins vrajitoarelor ! canalele respective fac parte din pachetul
    UPC care a migrat de pe Astra pe Thor si a carui inaugurare oficiala este
    prvazuta pentru data de 1 Aprilie ! speram sa nu fie o pacaleala ...
    deocamdata nu pare ! UPC se afla in plin program de restructurare a celor doua
    pachete , restructurare care vizeaza in egala masura controlul costurilor
    si structura grilei de programe. In mod evident aparitia pachetului HD face din
    UPC , implicit UPC Romania - FocusSat , un ofertant interesant.
