Thanks Thanks:  1
Likes Likes:  1
Results 31 to 45 of 55
Thread: Imagini DM 500HD
    Opendroid V.5.5 DM500HD
    http://images.opendroid.org/5.5/Drea...d-20160427.nfi
    Opendroid V.5.5 DM500HDv2
    http://images.opendroid.org/5.5/Drea...2-20160427.nfi
    Thumbs up SatDreamGR 4.0-gst1 DM500 HD/DM500HDv2 Image
    http://sgcpm.com/satdreamgr-images-e...d-20160430.zip
    http://sgcpm.com/satdreamgr-images-e...2-20160430.zip
    Opendroid V.5.5 DM500 HD/DM500HDv2 Image
    http://images.opendroid.org/5.5/Drea...d-20160430.nfi
    http://images.opendroid.org/5.5/Drea...2-20160430.nfi
    Thumbs up OpenPLi Images for DM500HD
    04-05-2016
    OpenPLi-4.0-beta-dm500hd-20160504.zip
    http://downloads.pli-images.org/buil...d-20160504.zip
    Thumbs up OpenLD 2.9 - DM500HD/DM500HDv2 Image
    Thumbs up OpenPli 4.0 IPTV by MastaG / Japhar Team with 1300 FREE IPTV Channels
    OpenPli 4.0 IPTV by MastaG / Japhar Team with 1300 FREE IPTV Channels and with GStreamer 1.9.0.1b (May 6th 2016)
    Changes:
    - Latest gstreamer 1.9.0.1 snapshot based on recipes from christophecvr:
    * Proper fix for HLS segfault on stop
    * Re-enable the rtmp seeking and potential segfault fix
    * gstreamer1.0-libav is now built against system ffmpeg instead (this differs from chris recipes) *
    * dvbmediasink patches for Vu Solo 4K, hd1265 and hd1500 from oe-alliance
    - FFMpeg updated to 3.0.2 and is now installed by default *
    - Backports to enigma2 for sh4 (mainly servicemp3.cpp related)
    - Fix EPG on sh4 receivers
    - exteplayer3 is now installed by default, thank you mx3L and samsamsam *
    - gstplayer is now installed by default, thank you mx3L and samsamsam
    - Mediatomb is now in the feeds
    - MediaPlayer2 is now installed by default, thank you mx3L
    - SubsSupport (for MediaPlayer2) is now installed by default, thank you mx3L
    - No more russian tuxtxt
    - Its now possible to set the debug level again in the UI-settings menu, thank you christophecvr
    - Latest enigma2 changes, thank you OpenPLi
    - latest openpli-oe-core changes, thank you OpenPLi
    - ServiceApp, thank you mx3L !!!
    Known issues:
    - On spark7162 (and 7111 probably as well) fragmented streams such as hls (m3u8) will skip and freeze a lot.
    This happened sometime after the official Gstreamer 1.8.0 release and I didnt found the cause yet.
    It is not related to the dvbmediasink since it doesnt happen on mips receivers and the code in the dvbmediasink didnt change.
    Configure your streams to play with exteplayer3 instead, read below.
    - * On the 64MB Dreambox models (DM800HD, DM800Se and DM500HD) there is not enough space to ship ffmpeg.
    This means that exteplayer3 and gstreamer1.0-libav arent installed as well because they depend on ffmpeg.
    See my attached guide to copy over the root filesystem to a storage device.
    - Some Dreambox remotes may behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    Thanks for the hard work from mx3L and samsamsam you can now play your IPTV streams with exteplayer3 or gstplayer instead of the default dvbmediasink.
    Especially using exteplayer3 will give much better performance on playing HLS streams compared to gstreamer + dvbmediasink.
    For example, playing DJING underground 720p never worked very well on my DM800HD and now it does
    DM500HD+ Japhar : https://mega.nz/#!9JtGwAAb!ePV-MQPr9...2PM2HgB-9gjxhI
    OE2.0 experimental DM 500HD Images
    Date: 2016-05-20 15:20
    Enigma2: 3.999git20151231-r9.1
    Distro: opendreambox 2.0.0
    Machine: Dreambox dm500hd
    Link: http://dreamboxupdate.com/opendreambox/2.0.3/ipk
    MD5: deb8644921d3f7e77a0b6f3f9d61a52e
    SHA256: 7ca04d9278c898b11048ea7ad6e28f2f07d04c5a73db621554b1cd8f24442e2e
    http://www.dreamboxupdate.com/opendr...d-20160520.nfi
    Date: 2016-05-20 16:11
    Machine: Dreambox dm500hdv2
    MD5: 90806b174ae23839ce90b0e16e32908f
    SHA256: 562875d6aa76f63e3b6f148c8621d1a8e0e048c079d670e2b6e39efbd503f0d1
    http://www.dreamboxupdate.com/opendr...2-20160520.nfi
    http://sgcpm.com/satdreamgr-images-e...d-20160522.zip
    http://sgcpm.com/satdreamgr-images-e...2-20160522.zip
    D.M.S-Img-dm500hd-OE2-v 5.1 Image
    http://www.demonisat.info/demonisat-...dex.php?dir=DM 500 HD/&file=D.M.S-Img-dm500hd-OE2-v5.1.zip
    D.M.S-Img-dm500hdv2-OE2-v 5.1 Image
    http://www.demonisat.info/demonisat-...dex.php?dir=DM 500HDv2/&file=D.M.S-Img-dm500hdv2-OE2-v5.1.zip
    Thumbs up Opendroid V.5.5 DM500HD/DM500HDv2 Image
    Thumbs up Opendroid V.5.5 DM500 HD/DM500HDv2 Image
    Thumbs up Opendroid 5.5 DM500 HD/DM500HDv2 Image
    Thumbs up Satdreamgr-4.0-gst1 DM500 HD/DM500HDv2 Image
    http://sgcpm.com/satdreamgr-images/d...d-20160829.zip
    http://sgcpm.com/satdreamgr-images/d...2-20160829.zip
    OpenPli 4.0 /DM500HD Image
    OpenPLi-4.0-beta-dm500hd-20160831.zip
    http://downloads.pli-images.org/buil...d-20160831.zip
    http://images.opendroid.org/5.5/Drea...d-20160929.nfi
    http://images.opendroid.org/5.5/Drea...2-20160929.nfi
