Page 3 of 22 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 327
Thread: KAON de la Focus
    trezeste-te mondo.....rec..e mort!!!! cum naiba sa intru in meniu daca nu porneste??....daca intra in meniu nu mai postam pe aici intrebari de kaon...l-am ucis eu intentionat cu un alt boot loader acum vreo 2 luni...si nu mai porneste....aici unul nou e 49 euro asa ca nu merita sa-l repar..am intrebat pur si simplu,din curiozitate..
    38 Post(s)
    Quote Originally Posted by outcast
    ...atunci la pubela cu el!!!
    Default y
    Quote Originally Posted by mondo
    pai daca e arsa numai sursa?Spaniolul :wink:
    38 Post(s)
    Default Re: y
    Quote Originally Posted by spaniolul
    ...atunci el hotaraste ce va face cu rec.(la doctor sau ...)! :wink:
    la gunoi!!
    16 Feb 2007
    Cine poate sa-mi zica si mie ceva despre asta?
    Engineer Mode
    KAON UPTOOL! KUP 2.30 Simple & Speedy
    File open O.K.!
    > Old version binary
    -. Target loader version :L 219
    -----------> Front :: 74HC164 used (connector: 14pin)
    -----------> Target 2M Flash.
    -----------> Target AMD/ST FLASH(TOP).
    Connect Success
    //FileInfo.: SatFR-C570SS, H/W(12.C1.A5), S/W(0A.E8.88)
    // Target: L 219, u-C[0] , FLS[2M], AT-7010DCIZ, H/W(12.C1.A5), S/W(02.00.07)
    Target Model Mismatch : AT-7010DCIZ
    -.STB Model : SatFR-C570SS
    -. STB H/W Ver : 12.C1.A5
    -. STB S/W Ver : 02.00.07
    DownLoad Start
    > flash not ok.RESPONSE_DOWNLOAD_FAIL
    > ERR: on STB->PC
    Plus ca mai e faza cu incercarea de a incarca un soft si daca am noroc merge dupa a x-a incercare, in timp ce cu acelasi cablu pe Echolite merge brici.
    Quote Originally Posted by doroftei
    Engineer Mode
    File open O.K.!
    > Old version binary
    Connect Success
    DownLoad Start
    > ERR: on STB->PC
    Incearca cu un alt soft tot cu HW12C1A5,Spaniolul :wink:
    vrei sa spui cu alt loader!? spaniolule??
    Default y
    cu acelasi dar sa fie diferit,ca denumire;ex;HW12C1A5 tps,absatok,altul kaon tabanl?lar SoftCam d+ok,altul,Kaon - SatFR-C570SS - HW12.C1.A5 - SW0A.E8.88 - FR - MenuStreamSystem-SS - SatFR Team,acum ai inteles? Spaniolul :wink:
    01 Apr 2007
    Corbu de C-ta
    Unhappy Re: KAON de la Focus
    Am pus un patch universal pe kaonul de focus luat de la SAT.US.PN si la scanare nu gaseste niciun program(semnal este destul),rog o explicatie daca se poate.
    Multumesc.
    Default Re: KAON de la Focus
    Quote Originally Posted by p_ionel View Post
    Multumesc.
    Softurile universale nu merg pe kaonul de la focussat,acesta avand o alta placa de baza care nu este compatibila cu softul,de aceea iti arata lipsa A/V si nu iti incarca nici un program,pune orce alt patch vrei in afara de cele 2 variante universale care NU MERG pe KAON FOCUSSAT!! dar merg bine m,ersi pe orce alkt model de kaon!
    10 Nov 2007
    are idee cineva ce e cu acel mesaj "halt" pe display? s-a mai intamplat cuiva?
    29 Jul 2007
    Quote Originally Posted by MaxxJr View Post
    ce versiune ai?
    Standard RSP member edisitaru's Avatar
    08 Aug 2007
    Giurgiu, Romania
    ATENTIE !!!! A aparut soft original de Focus care citeste toate cardurile Focus, deci nu mai are treaba cu adresa unica UA !!!! Il gasiti in sectiunea upload la receptoare Kaon. Redenumiti (sau adaugati) extensia .rar.
    01 Apr 2007
    Corbu de C-ta
    Am incercat sa ajut pe cineva sa puna un patch pe un Kaon (focus) si sa intamplat urmatorul lucru: merge tot ce se poate deschide cu un Kaon m-ai putin inXtc(hotbird),a pus acelasi soft ca al meu,acelasi procedeu de incarcare,aceleasi key,si nu vrea sa deschida acest program (pe al meu merge),keyle sant in receptor si as ruga pe cineva daca stie sa-mi explice unde ar fi problema.
    Multumesc
