Thanks Thanks:  44
Likes Likes:  13
Page 3 of 16 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 231
Thread: Activare smartcard TVR tel: +40213058951
    23 Apr 2007
    P3X-888
    @saulescu nu este nicio "vrajeala" am un receptor echosmart 791 care il scot doar pe intai ale lunii pentru update focus ( nici nu stiu ce soft al pe echosmart ) si pe 23 luna asta o sa incerc update la cardul tvr daca merge o sa spun ce soft are pe el
    Standard RSP member SAFETRON1's Avatar
    De azi s-a dat drumu la update , noua valabilitate pana la 28 sept.Astept confirmari sau infirmari daca acest card face au cu oscam.
    Golden Member qwess's Avatar
    26 Oct 2009
    Walachia / Paname
    la mine nu a vrut de nici un fel in oscam, cu dvbapi, fara dvbapi, intern, smargo cu diferite frecvente card....rula dar nu facea AU
    nici macar in combinatie cu mgcamd nu a vrut, in schimb cum am comutat pe newcs+mgcamd a facut imediat:
    | Provider | Class/Theme | From | To | Name |
    | 025900 | 04 | 2011-02-08 | 2011-09-28 | TVR 1
    | 025900 | 04 | 2010-08-18 | 2011-02-23 | TVR 1
    | 025900 | 04 | 2010-03-27 | 2010-08-26 | TVR 1
    | 025900 | 80 | 2010-02-18 | 2010-03-19 | TVR 1
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Face update in oscam!
    providers: 3 (FFF720,025900,025910)
    provider: 1, id: FFF720, name: TVR, sa: BF645910, geo: empty
    provider: 2, id: 025900, name: TVR 1, sa: BF645910, geo: FF FF FF FF
    class: 0A, expiry date: 2011/02/08 - 2011/09/28
    class: 0A, expiry date: 2010/08/27 - 2011/02/23
    class: 0A, expiry date: 2010/08/18 - 2011/02/23
    class: 0A, expiry date: 2010/06/01 - 2010/06/30
    class: 0A, expiry date: 2010/04/15 - 2010/08/26
    class: 0A, expiry date: 2010/02/22 - 2010/08/26
    class: 0A, expiry date: 2010/02/01 - 2010/02/28
    class: 0A, expiry date: 2010/01/01 - 2010/01/31
    class: 0A, expiry date: 2009/12/05 - 2010/08/26
    class: 0A, expiry date: 2009/12/01 - 2009/12/31
    provider: 3, id: 025910, name: TVR 2, sa: BF645910, geo: FF FF FF FF
    26 Oct 2009
    Walachia / Paname
    bine ar fi,
    un screen/log cu cererile EMM e posibil?
    la mine nici mgcamd nu a reusit sa trimita prin oscam !
    04 Jan 2010
    Parpaneata ,poti posta setarile la .conf .user si .server cu care ai facut update la card ?
    si cu ce versiune ..
    Multumim !!
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Vremea cand oscamul meu deschidea din localul TVR...e apusa de vreo 5-600 variante svn oscam. Prefera cardurile akta. Deschide din local doar daca ii tai internetul. La fel si cu update-ul. Cu internetul taiat. Deci...print screen...n-am de unde. Logurile le am oprite din .conf...deci trebuie sa ma crezi pe cuvant sau....sa-mi incerci setarile.
    Oscam svn 4702.
    oscam.conf:
    [global]
    usrfile = /var/log/oscamusr.log
    logfile = /var/log/oscam.log
    cwlogdir = /var/log/oscam/cw
    disablelog = 1
    disableuserfile = 1
    usrfileflag = 0
    clienttimeout = 10
    fallbacktimeout = 5
    clientmaxidle = 150
    cachedelay = 2500
    bindwait = 150
    netprio = 1
    clientdyndns = 1
    resolvedelay = 40
    unlockparental = 0
    nice = 1
    serialreadertimeout = 1500
    maxlogsize = 10
    WaitForCards = 1
    preferlocalcards = 1
    saveinithistory = 1
    readerrestartseconds = 7
    lb_mode = 1
    lb_save = 0
    lb_nbest_readers = 1
    lb_nfb_readers = 3
    lb_min_ecmcount = 5
    lb_max_ecmcount = 1000
    lb_reopen_seconds = 200
    resolvegethostbyname = 1
    [newcamd]
    port = 24000@0500:025900
    allowed =
    keepalive = 1
    mgclient = 0
    [dvbapi]
    enabled = 1
    au = 1
    boxtype = dreambox
    user = local
    pmt_mode = 0
    oscam.server:
    [reader]
    label = slot0
    enable = 1
    protocol = internal
    device = /dev/sci0
    services = tvr
    caid = 0500
    boxid =
    detect = cd
    mhz = 398
    cardmhz = 398
    ident = 0500:025900
    group = 1
    emmcache = 1,3,2
    lb_weight = 140
    oscam.user:
    [account]
    user = dreambox
    pwd = xxxxxx
    disabled = 0
    #expdate =
    group = 1
    #hostname =
    uniq = 0
    sleep = 0
    monlevel = 1
    au = 1
    services = tvr
    caid = 0500
    #betatunnel =
    ident = 0500:025900
    cccmaxhops = 3
    keepalive = 1
    numusers = 0
    penalty = 0
    [account]
    user = local
    pwd = dreambox
    group = 1
    sleep = 0
    uniq = 0
    betatunnel = 1833.FFFF:1702
    keepalive = 1
    #CAID = 1702,1833,1830
    au = 1
    26 Oct 2009
    Walachia / Paname
    nu am taiat net dar in schimb am lasat doar local, dvbapi si un user catre mg, in mg la fel am scos cline si ce mai era prin el, am lasat doar ce vine de la oscam.
    deschide cu oscam fara probleme dar la EMM = 0....
    Merci
    ---------- Post added at 15:05 ---------- Previous post was at 14:30 ----------
    parca incepe sa vrea dar cu mgcamd:
    2011/02/10 13:03:14 C04 r nano A9: class: 0A, expiry date: 2011/02/08 - 2011/09/28
    2011/02/10 13:03:14 C04 r mgcamd emmtype=shared, len=61, idx=1, cnt=1: written (270 ms) by tvr-smargo3
    2011/02/10 13:03:21 1005 c >> OSCam << cardserver started version 1.00-unstable_svn, build #4690 (mips-azbox-linux)
    2011/02/10 13:03:21 1005 c version=1.00-unstable_svn, build #4690, system=mips-azbox-linux, nice=-1
    2011/02/10 13:03:21 1005 c client max. idle=150
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Folosesc oscam simplu....fara nicio combinatie. In el intra ca si "readere" doua linii cccam de la serverele mele si pleaca doua linii N ca si "acounturi" pe retur catre acestea. Dvbapi pornit si....restul am scris.
    Intrebare sau...cerere de ajutor, pentru sau....catre cei ce folosesc aceeasi combinatie ca mine. Oscam simplu. Va deschide din el sau pleaca tot pe cardurile akta?
    Daca da....cum? Daca nu....merci oricum!
    Spor!
    23 Apr 2007
    P3X-888
    am facut si eu update la card in echosmart 790 ( sw v.3.46 ) a durat nici macar un minut sa treaca la noul update .
    26 Oct 2009
    Walachia / Paname
    nu am reusit doar cu oscam simplu dar pun asta si in versiunile SVN compilate pentru azbox iar dvbapi foloseste acel bridge numit OpenXCAS, voi mai incerca cand testez E2.
    Important e ca oscam face AU la tvr chiar si cu ajutorul mgcamd si cum spune @parpaneata ca a reusit in simplu e o chestie super!
    Apropo de preferintele 22F00- 24F00 nu am reusit sa-l fixez pe 25900, lucreaza cand vrea el(de fapt cand nu gaseste in celelalte 2)chiar si cu prio/ignore in dvbapi conf.- ma gandesc ca acel preferlocalcards nu lucreaza cum trebuie.
    p.s. poti incerca scoaterea prin F din servere catre oscam a canalelor din AKTA(0001, 0002 si 000F).
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Quote Originally Posted by qwess View Post
    Pai...ce as rezolva? Ar pleca probabil din cardul TvR si....nu as mai receptiona Realitatea si....ce mai este pe caidurile alea. Cred.
    Raman la parerea ca este din Oscam....pentru ca acest lucru mergea f. bine la variantele de oscam mai vechi. Deschidea fara probleme din 0500:025900. A fost perioada cand nu a mai mers nimic, adica nu deschidea nici din TvR si nici din Akta. Apoi au venit variantele astea unde oscamul "se repede" in Akta sau deschide din TvR doar daca nu ai linii in oscam sau doar daca internetul e cazut sau taiat. Este un lucru de lauda, dupa cum scria cineva anterior, ca oscamul a ajuns la o oarecare maturitate. Cred ca au inca probleme minore dar...totusi probleme, pe providerii ce se deschid cu mai multe sisteme de codare. Acelasi, cum e cazul TvR (Via dar variante diferite) sau combinatii.
    Am facut azi update la 2 carduri in scam 3.58. In citeva minute.
    In oscam singur cu dvbapi n-a vrut, am versiunea 2980 care deschide, cam veche, dar superstabila daca folosesti oscamul doar server de card.
    @parpaneata
    scoate linia services din reader si user daca nu folosesti fisier-ul .services ....un alt hint ar fi sa adaugi si prov 025910
    09 Feb 2008
    Targu Jiu
    15 Post(s)
    Tehnic...nu e bine ce spui!
    Am fisier service, e pus la provider...fara astea ar fi cereri aiurea pe el.
    Astept evolutia oscam. E bine ca face updateul necesar.
