Thanks Thanks:  6
Likes Likes:  2
Results 61 to 75 of 80
Thread: DVB Dream
  1. #61
    17 Nov 2008
    ALBA
    pune pe megaupload
  2. #62
    Default DVB Dream1.5e Special Full
  3. #63
    14 Aug 2007
    Comuna Miticestii de Campie. Sat Vanghelesti.
    Default DVB Dream : v1.5f is available
    v1.5f (29.05.2011) What's New
    Problems with des.dll crash fixed
    EVR 16/9 - 4/3 flickering problem fixed
    Some character set problems fixed
    Some fixes in FreeSat EPG
    Module API DDMODAPI_DVB_COMMAND function fixed
    Many critical bug fixes
    http://www.dvbdream.org/dlmanager.ph...setup_v15f.exe
  4. #64
    09 Sep 2007
    Ai si rezolvarea problemei?
  5. #65
    14 Aug 2007
    Nu, din pacate pana acum liniste.
    LE: M-am inselat se pare ca a avut cineva grija de problema . http://www.mediafire.com/?c9f9fag9ucdwchd sau http://masrawysat10.com/vb/r.php?ref...etup_v15f.html
  6. #66
    14 Aug 2007
    Default DVB Dream : v1.5g
    Now DD allows to save unlimited number of channels
    Device dialog now lists the devices of the same interface
    des.dll error fixed
    Some critical crash/bug fixes
    New channel list filter options "Found/Updated Recently"
    Japanese EPG is supported now
    Japanese language added
    Now possible to change dvbdream taskbar icon to identify different DD installations on taskbar. (Settings->Preferences->Other->Application Taskbar Icon)
    Now possible to use/share transponder INI file folders of other apps or DD installations (Settings->Preferences->PATHS)
    new modules by X05: TSWriter2, RecentRecordings, RendererSwap
    CHLTools module has been updated
    New DD Module API Functions added, check the latest header files for more information.
    *New TBS devices are supported
    *StreamRecorder module is now replaced by TSWriter2
    *For UK Freeview HD, Japanese pay TV and some other AAC channels you will need to install a compatible AAC codec and set it up in DVB Dream video configuration. MainConcept and DivX AAC codecs seem to work nice.
    Download: www.dvbdream.org
  7. #67
    14 Aug 2007
    Default DVB Dream : v1.6
    v1.6 (05.11.2011) What's New
    Fixed many bugs
    Better support for Japanese EPG and channel names
    Now scheduler is able to suspend or hibernate the PC after the record
    Diseqc on AverMedia cards now should work
    Geniatech cards should work better
    Fixed a crash bug which happens after scan
    * Cracked versions will not work stable! We recommend you buying it while the price is still the same and cheap. There will be a price change soon.
    * Please report on the DVB Dream forum if you run into any problem with Geniatech or Avermedia, we can probably fix that. We just need testers.
    * If DVB Dream doesn't display the codecs installed on your system, please manually add them into codecs.ini, you can also let us know on DD forum, so that we will add them into next setup files.
    * AVer3D Satellite TV, AVerTV Satellite PCI, AVerTV Galaxy should work well now on DD
    * For better performance on HD, make sure you use "Enhanced Video Renderer" in Video Options (Only if your graphic card has the necessary hardware acceleration) For SD channels, WMR9 is still recommended.
    * SECOSD won't work on DD now, it needs an update from its author
    * If DD interface is not completely in your own language or partially in English, you can translate the non-translated parts of the language INI files (in DD \languages) folder and post on DD forum for us to include in next versions.
    http://www.dvbdream.org/dlmanager.ph...msetup_v16.exe
  8. #68
    14 Aug 2007
    Default DvbDream v1.7
    v1.7 What's New
    Unicable support added (works only on TBS cards for now)
    CI/CAM support for AverMedia (not tested, please confirm)
    Support for NetUP devices (Diseqc & CI, not tested)
    BDA device error code:14 bug fixed which happens on some devices
    Initial installation dialog supports more languages now (Turkish,Greek,Chinese,Arabic,Ukranian,Farsi...)
    A few bugs in scheduler fixed
    Arabic epg bug fix
    Snapshot crash bug fixed
    LNB Power Off/On support added (in File menu, works only on TBS and Compro devices for now)
    EPG support option added for Israel cable provider HOT.
    * If you encounter any problem with EPG text charset, you should pick the correct EPG code page instead of "auto"
    * BDA Device options now provides different methods for diseqc (Main Menu->Options->Device Options)
    * For unicable, you should select the LNB type as unicable while adding satellites in diseqc dialog
    * Unicable and LNB Power Off/On is not supported on all devices. It should work fine on TBS cards with new drivers (these new drivers should be released by TBS in next few days)
    * If you are still having problem with diseqc on AverMedia devices, please report. You just need to download latest aver media drivers.
    * Kaspersky Antivirus is not recommended since it could be the culprit responsible for des.dll errors due to some false virus alarms / heuristic scan.
    download: http://www.dvbdream.org/
  9. #69
    DVBDream V2.0b stardvb Edition Cracked By Rawdvb
    dvbdream-Stardvb_v20b.rar
    https://hotfile.com/dl/167726501/294..._v20b.rar.html
    Thank you Rawdvb
  10. #70
    45 Post(s)
    Ms, am instalat si testat dvbdream 2.0 si dupa 2 ore pot spune ca pare OK.
    Oricum ramane sa testez mai departe, prima impresie ca nu se compara cu limitatele dvbdream 1.7a sau 1.7b, versiunea din link se pare ca nu este cu nimic mai prejos decat celebrul progdvb 6.8x.
    Multumiri BASKAN REL from Turkey.
  11. #71
    Cu parere de rau dar am sters postarea ta pentru ca incalca punctul 2 din regulament
    edit: stargate
  12. #72
    45 Post(s)
    DVB Dream a ajuns la ver 2.5 dar eu nu sunt sigur daca s-a rezolvat problema cu subtitrarile. Nu am gasit nimic in sensul asta! Poate are cineva info daca merg subtitrarile la dvb dream? Poate exista pe undeva vre-un plugin de subtitrari? Cine are info in domeniul asta il rog sa dea o manutza de ajutor
  13. #73
    Thumbs up DVB Dream: v3.2 is available!
    v3.2 (29 December 2016) What's New
    BISS and Fixed CW keys are now stored/remembered for each channel
    LCN setting is remembered
    H264 video information is reported correctly now for 4:2:2
    Fixed a crash problem happened while scanning channels
    Reverted back to old Windows Scheduler API because of stability problems.
    Several bug fixes
    http://www.dvbdream.org/files/dvbdre..._v32_trial.exe
    full need to activation :
    DVBDream 3.2 Valid Serial 0A4CC-043E7-65932-001E2-90A93
    http://www.dvbdream.org/files/ddfull...msetup_v32.exe
    4:2:2 is one of the option added in the last released of DVB Dream V3.2 and it's as mentioned in DVB Dream home page
    after testing the new version 3.2 on one feed it was OK and the info was added down right of the main DVB Dream V3.2 screen after of course inserting the BISS Key in this feed and will work also in any other encryption 4:2:2 feed when keys are provided and supported by the plugin EMU.
    Note:
    to use the serial you have to use the other released NOT the trial version
    LAV filter is adviced to be used in all codecs
  14. #74
    Thumbs up DVB Dream: v3.3 is available!
    v3.3 (27.02.2017) What's New
    Channel scan improvements
    Several fixes (BISS, BlindScan, StreamReader interface)
    https://mega.nz/#!7MsgwZYa!gu5ZWwWdH...49ZErBky_1UxNY
  15. #75
    45 Post(s)
    Am cumparat licenta DVBDREAM 3.4 dar nici versiunea asta nu are plugin pentru subtitrari. Ce or fi avand in cap cei de la tepesoft pentru ca refuza de atata vreme sa include si subtitrarile in aplicatie? DVB Viewer, Prog DVB au subtitrarile inca de la primele editii. Nu merita sa dati 49 usd pentru licenta DVBDREAM, nici imaginea nu este la nivelul DVBViewer iar placa TBS 5927 usb se blocheaza de multe ori cu driverul 1.0.0.4, in schimb cu versiunea 1.0.0.3 nu am remarcat probleme.
