Thanks Thanks:  51
Likes Likes:  20
Page 11 of 81 FirstFirst ... 7891011121314152161 ... LastLast
Results 151 to 165 of 1201
Thread: OSCAM file
  1. #151
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3797-full-Distribution
    r3797 | hapeba | 2010-11-01 00:44:26 -0700 (Mon, 01 Nov 2010) | 1 line
    small fix for #3796
    r3796 | hapeba | 2010-11-01 00:39:00 -0700 (Mon, 01 Nov 2010) | 1 line
    Add QBOXHD_LED to oscam-config.h analogous to config.sh
  2. #152
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3798-full-Distribution
    r3798 | alno | 2010-11-01 08:32:59 -0700 (Mon, 01 Nov 2010) | 1 line
    WebIf: add some classes to tables to have more possibilities for skinning
    small fix for #3796
  3. #153
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3799-full-Distribution
    r3799 | _network | 2010-11-01 15:00:51 -0700 (Mon, 01 Nov 2010) | 2 lines
    fix possible segfaults in protocol T0
  4. #154
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3802-full-Distribution
    r3802 | rorothetroll | 2010-11-01 23:52:26 -0700 (Mon, 01 Nov 2010) | 1 line
    adding some debugging for card handle value in ifd_pcsc.c
    r3801 | rorothetroll | 2010-11-01 23:49:27 -0700 (Mon, 01 Nov 2010) | 1 line
    move some debug messages in ifd_pcsc.c
    r3800 | rorothetroll | 2010-11-01 23:46:00 -0700 (Mon, 01 Nov 2010) | 1 line
    minor casting in ifd_pcsc.c
  5. #155
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3805-full-Distribution
    r3805 | alno | 2010-11-02 05:02:29 -0700 (Tue, 02 Nov 2010) | 1 line
    WebIf: replaced 'newcamd525' with 'newcamd' in Add Reader protocol dropdown
    r3804 | alno | 2010-11-02 04:06:57 -0700 (Tue, 02 Nov 2010) | 1 line
    WebIf: restart cardreader removed on saving reader - the function causes segfault on several readertypes
  6. #156
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3806
    Oscam-1.00-svn3806
    Changeset #3806
    Message: WebIf: add some more style classes and div's for skinning header and footer
  7. #157
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3807-full-Distribution
    r3807 | rorothetroll | 2010-11-02 09:01:57 -0700 (Tue, 02 Nov 2010) | 1 line
    csctapi/ifd_pcsc.c : fix some return code in pcsc_reader_init as they were added when we moved to threads and were returning 0 even on error. now they return 2 to comply with the return code expected by the caller of reader_device_init in reader-common.c . I also change some debug to log as they could help the user understanding why the reader is not recognized
    r3806 | alno | 2010-11-02 06:02:07 -0700 (Tue, 02 Nov 2010) | 1 line
  8. #158
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3808
    Oscam-1.00-svn3808
    Changeset #3808
    Message: fix start of dvbapi emm filter in case of not found
  9. #159
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3809
    Oscam-1.00-svn3809
    Changeset #3809
    Message: dvbapi: changes for new liboscam_stapi version 0.06, older versions won't work anymor
  10. #160
    7 Post(s)
    oscam 1.00 -svn3810-full-Distribution
    r3810 | alno | 2010-11-03 01:01:18 -0700 (Wed, 03 Nov 2010) | 1 line
    WebIf: add 'device_out_endpoint' parameter dropdown in case of LIBUSB and HW Reader
    r3809 | _network | 2010-11-02 13:55:21 -0700 (Tue, 02 Nov 2010) | 2 lines
    dvbapi: changes for new liboscam_stapi version 0.06, older versions won't work anymore
    29 Mar 2009
    Austria - TM
    oscam 1.00 -svn3811-full-Distribution
    r3811 | alno | 2010-11-03 05:52:07 -0700 (Wed, 03 Nov 2010) | 1 line
    WebIf: reduce parameters in [global] token. Not save default or empty parameters
  12. #162
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3813
    Oscam-1.00-svn3813
    Changeset #3812
    Message: moved some constants to global.h
    Changeset #3813
    Message: WebIf: add enable/disable reader to reader overview (corosponding with user overview)
  13. #163
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3814
    Oscam-1.00-svn3814
    Changeset #3814
    Message: WebIf: further reduce of parameters in [global] token
  14. #164
    29 Nov 2008
    Cu capu' in nori
    Default Oscam-1.00-svn3815
    Oscam-1.00-svn3815
    Changeset #3815
    Message: WebIf: group statusview in server, reader, proxy, client
  15. #165
    14 Feb 2007
    Oscam-svn3816-full-Distribution
    r3816 | rorothetroll | 2010-11-03 20:57:12 -0700 (Wed, 03 Nov 2010) | 7 lines
    reader-viaccess.c : testing support for an acutal pin code, not just 0000
    csctapi/ifd_pcsc.c : minor changes to a debug message
    globals.h : nagra patch for card info
    reader-nagra.c : nagra patch for card info
