51
20
Dislikes:
Oscam-svn5334-light-Distribution
r5333 | Admin | 2011-05-29 19:30:20 +0200 (Sun, 29 May 2011) | 1 line
Only wait up to 500ms in llist destroy as there seem to exist deadlock conditions...
oscam 1.00 -svn5335-light-full-Distribution
r5335 | hapeba | 2011-05-30 09:05:53 +0200 (Mon, 30 May 2011) | 1 line
fixed help for cardmhz
Oscam-svn5338-light-Distribution
r5337 | merek | 2011-05-30 18:13:51 +0200 (Mon, 30 May 2011) | 1 line
Revert oscam-config.h changes
r5336 | merek | 2011-05-30 18:12:26 +0200 (Mon, 30 May 2011) | 1 line
Adding newcamd client id for Tvheadend - thanks to bowman
Oscam-svn5339-light-Distribution
r5339 | schlocke | 2011-05-30 21:43:27 +0200 (Mon, 30 May 2011) | 3 lines
loadbalancer: only add stat on found/not found/timeout. All others are
ignored
oscam 1.00 -svn5341-light-full-Distribution
r5341 | Admin | 2011-05-31 21:34:41 +0200 (Tue, 31 May 2011) | 1 line
Add reader, proxies and anticascader to username function. Use username function for monitor module.
r5340 | Admin | 2011-05-31 20:24:17 +0200 (Tue, 31 May 2011) | 1 line
Add some error handling to fix Segfaults when stopping readers.
oscam 1.00 -svn5343-light-full-Distribution
r5343 | Admin | 2011-05-31 23:46:50 +0200 (Tue, 31 May 2011) | 1 line
Let emmlogdir also save the bin files into the specified folder.
r5342 | Admin | 2011-05-31 22:44:39 +0200 (Tue, 31 May 2011) | 1 line
Add anticascader to monitor_get_proto function. Fix a compiler warning.
Oscam-svn5344-light-Distribution
r5344 | Admin | 2011-06-01 23:51:05 +0200 (Wed, 01 Jun 2011) | 1 line
Fix for #1899
oscam 1.00 -svn5350-light-full-Distribution
r5350 | Admin | 2011-06-03 01:42:39 +0200 (Fri, 03 Jun 2011) | 1 line
Remove unneeded variables from client struct.
r5349 | Admin | 2011-06-03 01:38:19 +0200 (Fri, 03 Jun 2011) | 2 lines
To find the locking issues in #5437 and #5438 we added debugging functionality for mutexes which is not normally needed. The debug code is added with this commit but it needs to be manually activated by defining WITH_MUTEXDEBUG in src code if we should need it again.
Furthermore, resolving the ip from a hostname has been refactored into a function.
oscam 1.00 -svn5351-light-full-Distribution
r5351 | _network | 2011-06-03 10:26:22 +0200 (Fri, 03 Jun 2011) | 2 lines
viaccess: possible workaround for emm from cccam (#1838)
oscam 1.00 -svn5352-light-full-Distribution
r5352 | schlocke | 2011-06-03 13:56:08 +0200 (Fri, 03 Jun 2011) | 3 lines
cccam: fixed auto refresh only for local cards, loadbalancer: do not
block timeouts if we got ecms in the past
Oscam-1.00-svn5353
Oscam-1.00-svn5353-light-Distribution
r5353 | Admin | 2011-06-04 19:40:33 +0200 (Sat, 04 Jun 2011) | 1 line
Fix wrong cancelstate-setting in cs_lock-functions, use global functions to add/remove readers to/from reader list and add a lock to make sure that the list always stays consistent.
Oscam-svn5354-light-Distribution
r5354 | neoen | 2011-06-05 15:02:31 +0200 (Sun, 05 Jun 2011) | 8 lines
NDS: added support for mail messages from provider.
Text mail messages sent by provider to subscriber are saved to file.
These messages are encapsulated into Unique EMMs.
Two new options in global section of oscam.conf are used to enable this feature:
disablemail = 0 (default is 1)
mailfile = /path/to/file
Tested only with SkyIT.
oscam 1.00 -svn5355-light-full-Distribution
r5355 | Admin | 2011-06-05 19:18:47 +0200 (Sun, 05 Jun 2011) | 1 line
Correct some field lengths in WebIf, don't exit OSCam anymore when some minor config parameters are wrong.
Oscam-1.00-svn5360
Oscam-1.00-svn5360-light-Distribution
r5360 | Admin | 2011-06-05 22:47:31 +0200 (Sun, 05 Jun 2011) | 1 line
WebIf: Remove whitespace from files section.
r5359 | Admin | 2011-06-05 22:38:42 +0200 (Sun, 05 Jun 2011) | 1 line
Fix #1894: Don't add messages about sending the pin to the card to the entitlements info.
r5358 | Admin | 2011-06-05 22:32:33 +0200 (Sun, 05 Jun 2011) | 1 line
Enhancement #1814: Add log message on failed ecm in order to be able to identify them. Get the caching use in getservicename function really working.
r5357 | landlord | 2011-06-05 20:47:12 +0200 (Sun, 05 Jun 2011) | 1 line
Added new parameter 'disablemail' and 'mailfile' to documentation.
r5356 | Admin | 2011-06-05 19:28:34 +0200 (Sun, 05 Jun 2011) | 1 line
If OSCam was compiled with debug the behaviour was like the following: A function is called via the call macro. If the function fails, a log is output and the current function also returns an error. As this is not the case with debug disabled it is not consistent. According to ngc1927 in #1906 removing this "return" fixes the enable/disable problem for sci readers and has not come to a drawback yet. If you experience drawbacks in hardware readers from this change (can only happen when the readers have other failures!), please report in the forum.
Oscam-svn5363-light-Distribution
r5363 | pattex | 2011-06-06 15:32:49 +0200 (Mon, 06 Jun 2011) | 1 line
WebIf: better sizing of editboxes
r5362 | hapeba | 2011-06-06 14:42:51 +0200 (Mon, 06 Jun 2011) | 1 line
fix #5361 (compile error - module-lcd.c, module-dvbapi.c)
r5361 | Admin | 2011-06-06 01:52:08 +02.00 (Mon, 06 June 2011) | 1 line
Some internal restructuring regarding globals.h file to make it a bit more structured.
