51
20
Dislikes:
oscam 1.00 -svn5196-light-full-Distribution
r5196 | Admin | 2011-05-08 00:51:59 +0200 (Sun, 08 May 2011) | 1 line
Fix a segfault when editing users via WebIf.
r5195 | _network | 2011-05-07 20:19:39 +0200 (Sat, 07 May 2011) | 2 lines
another fix for r5192
oscam 1.00 -svn5197-light-full-Distribution
r5197 | Admin | 2011-05-08 02:49:08 +0200 (Sun, 08 May 2011) | 1 line
Small fix on connecting to network readers.
Oscam-1.00-svn5199
Oscam-1.00-svn5199
r5199 | schlocke | 2011-05-08 21:54:23 +0200 (Sun, 08 May 2011) | 2 lines
fixed possible segfault
r5198 | schlocke | 2011-05-08 18:21:43 +0200 (Sun, 08 May 2011) | 2 lines
cccam: fixed card group comparison
oscam 1.00 -svn5200-light-full-Distribution
r5200 | _network | 2011-05-08 22:31:58 +0200 (Sun, 08 May 2011) | 2 lines
WebIf: replace select() with poll() and some optimizations
Oscam-1.00-svn5206
Oscam-1.00-svn5206
r5206 | schlocke | 2011-05-09 12:02:57 +0200 (Mon, 09 May 2011) | 3 lines
cccam: reshare_mode=0 on cccam readers with defined services just filter
cards without generating cards
r5205 | Admin | 2011-05-09 02:04:49 +0200 (Mon, 09 May 2011) | 1 line
Some cleanups: Remove getprotobyname() uses, replace getpwuid by getpwuid_r and only call it once, move srand into init_rnd function.
r5204 | Admin | 2011-05-09 00:15:07 +0200 (Mon, 09 May 2011) | 1 line
Remove obsolete "build"/"cccbuild" parameter from docu (are automatically set since some time ago)
r5203 | schlocke | 2011-05-09 00:01:13 +0200 (Mon, 09 May 2011) | 2 lines
cccam: fixed check provider
r5202 | Admin | 2011-05-08 23:18:48 +0200 (Sun, 08 May 2011) | 1 line
Fix small typing error
r5201 | Admin | 2011-05-08 23:08:36 +0200 (Sun, 08 May 2011) | 1 line
Replace strtok() with the reentrant and threadsafe function strtok_r()
Oscam-1.00-svn5207
Oscam-1.00-svn5207
r5207 | Admin | 2011-05-09 20:48:56 +0200 (Mon, 09 May 2011) | 1 line
WebIf: Add class parameter in user and reader section as well as the corresponding saving mechanism. Some internal improvement on tpl_addVar vs. tpl_printf usage to save ressources.
Oscam-1.00-svn5218
Oscam-1.00-svn5218-light-Distribution
Oscam-svn5216-sh4-amino
r5218 | schlocke | 2011-05-10 19:45:35 +0200 (Tue, 10 May 2011) | 2 lines
cccam: added missing changes
r5217 | schlocke | 2011-05-10 18:59:41 +0200 (Tue, 10 May 2011) | 2 lines
cccam: reader bad sids and client bad sids are combined on one card
r5216 | hapeba | 2011-05-10 15:53:58 +0200 (Tue, 10 May 2011) | 1 line
cosmetics: dokumentation and "oscam -h"
r5215 | schlocke | 2011-05-10 14:05:11 +0200 (Tue, 10 May 2011) | 2 lines
cccam: fixed memleak
r5214 | Admin | 2011-05-10 01:20:32 +0200 (Tue, 10 May 2011) | 1 line
WebIf: Small code cleanups
r5213 | Admin | 2011-05-10 00:30:39 +0200 (Tue, 10 May 2011) | 1 line
WebIf: Further improve browser caching through implementation of etag/if-none-match header for images/css/js
r5212 | Admin | 2011-05-09 23:05:31 +0200 (Mon, 09 May 2011) | 1 line
WebIf: Add parsing for etag, keepalive and if-modified-sinced header. Implement if-modified-since header parsing so that images, js and css are not transmitted on refreshs if unchanged.
r5211 | schlocke | 2011-05-09 22:29:23 +0200 (Mon, 09 May 2011) | 2 lines
r5210 | landlord | 2011-05-09 22:06:25 +0200 (Mon, 09 May 2011) | 1 line
Added new option for parameter 'reshare_mode' to documentation.
r5209 | schlocke | 2011-05-09 21:49:01 +0200 (Mon, 09 May 2011) | 2 lines
cccam: reshare mode 4: reshare only received cards
Oscam-1.00-svn5223
Oscam-1.00-svn5223
r5223 | schlocke | 2011-05-11 14:47:18 +0200 (Wed, 11 May 2011) | 2 lines
cccam: fix for last fix
r5222 | schlocke | 2011-05-11 14:37:31 +0200 (Wed, 11 May 2011) | 2 lines
cccam: fixed too many nodes with minimize_cards=1
r5221 | schlocke | 2011-05-11 11:56:15 +0200 (Wed, 11 May 2011) | 4 lines
loadbalancer: default mode back to 0
cccam: minimize_cards=1 keeps bad sids
r5220 | schlocke | 2011-05-11 10:27:30 +0200 (Wed, 11 May 2011) | 2 lines
cccam: fixed a memleak
oscam 1.00 -svn5224-light-full-Distribution
r5224 | landlord | 2011-05-11 15:33:52 +0200 (Wed, 11 May 2011) | 1 line
Set new default value for 'lb_mode' parameter in documentation.
oscam 1.00 -svn5225-light-full-Distribution
r5225 | Admin | 2011-05-11 22:23:15 +0200 (Wed, 11 May 2011) | 1 line
WebIf: Leak fix for external css.
Oscam-svn5227-light-Distribution
r5227 | schlocke | 2011-05-12 16:11:48 +0200 (Thu, 12 May 2011) | 2 lines
completet refactoring
r5226 | schlocke | 2011-05-12 12:32:36 +0200 (Thu, 12 May 2011) | 2 lines
iterator refactoring: iterators now on stack instead heap
Oscam_svn5228_light_Distribution
r5228 | Admin | 2011-05-12 22:21:17 +0200 (Thu, 12 May 2011) | 1 line
Client list may get inconsistent if there are multiple thread kills and starts concurrently. Thus, a write lock is added to ensure consistency.
Oscam_svn5229_light_Distribution
r5229 | Admin | 2011-05-13 01:11:34 +0200 (Fri, 13 May 2011) | 1 line
WebIf: Implement keepalive mechanism. This should make WebIf a lot more responsive as no new connection has to be created on each request (on SSL, the whole handshake process is also saved). Tested to work properly on Opera 11.10, Firefox 3.6.17 and IE9. Please report in the FORUM if you experience problems with this. In the meantime, you can restore old behaviour by removing the line "keepalive = 1" (line 3366) from oscam-http.c.
Oscam-svn5230-light-Distribution
r5230 | _network | 2011-05-13 16:48:50 +0200 (Fri, 13 May 2011) | 2 lines
WebIf: fix segfault with ssl enabled
oscam 1.00 -svn5231-light-full-Distribution
r5231 | _network | 2011-05-13 19:08:20 +0200 (Fri, 13 May 2011) | 2 lines
WebIf: fix for r5230
Oscam-1.00-svn5231
Oscam-svn5231-sh4-amino
r5231 | _network | 2011-05-13 07:08:20 +0200 (Fri, 13 May 2011) | 2 lines
Oscam-svn5232-light-Distribution
r5232 | schlocke | 2011-05-13 22:53:44 +0200 (Fri, 13 May 2011) | 2 lines
fixed "invalid read" (valgrind)
