Likes Likes:  1
Results 16 to 30 of 41
Thread: RSP e2 RSPv3.149 G1192
    Post
    Edit
    /var/config/amnt.sh
    and replace :
        if [ $lab == $record ] ;
          then
            if [ ! -e /hdd/movie ] ;
             then
             mkdir /hdd/movie
            fi
            mount $j /hdd/movie
        else
          lb=${j:5}
          mkdir /tmp/"$lb"
          mount $j /tmp/"$lb"
        fi
    with
     if [ $lab == $record ] ; then
               if [ ! -e /hdd/movie ] ;  then
                        mkdir /hdd/movie
               fi
       mount $j /hdd/movie
       else
       lb=${j:5}
          if [ $lb = sdb1 ] ; then
           if [ ! -e /media/mkv ] ; then
            mkdir /media/mkv
          fi
        mount $j /media/mkv
       else
        mkdir /tmp/"$lb"
        mount $j /tmp/"$lb"
       fi
    fi
    30 Dec 2008
    France
    thanks a lot
    i tested and i found this
    BusyBox v1.11.2 (2010-09-20 10:41:33 EEST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    Kathy_RSP:~# mount
    rootfs on / type rootfs (rw)
    /dev/root on / type ext2 (rw)
    proc on /proc type proc (rw)
    sysfs on /sys type sysfs (rw)
    tmpfs on /ram type tmpfs (rw)
    /dev/root on /dev.static type ext2 (rw)
    tmpfs on /dev type tmpfs (rw)
    devpts on /dev/pts type devpts (rw)
    tmpfs on /dev/shm type tmpfs (rw)
    usbfs on /proc/bus/usb type usbfs (rw)
    /dev/sda1 on /hdd type ext2 (rw,noatime,nodiratime)
    tmpfs on /tmp type tmpfs (rw)
    Kathy_RSP:~#
    i'll check this evening
    have a good sunday
    my file
    for j in $l
    do
    lab=`/var/config/tune2fs -l $j | grep "Filesystem volume name"`
    lab=${lab:24}
    echo $lab
    then
    then
    mkdir /hdd/movie
    fi
    mount $j /hdd/movie
    else
    lb=${j:5}
    mkdir /media/mkv
    fi
    mount $j /media/mkv
    else
    mkdir /tmp/"$lb"
    mount $j /tmp/"$lb"
    fi
    done
    Flash : AAF2.e
    USB Stick with BA : RSP ( pkt ou AAF) with OSCAM
    5?W_13?E_19?E_28?E
    for j in $l
    do
    lab=${lab:24}
    echo $lab
    then
    then
    mkdir /hdd/movie
    fi
    mount $j /hdd/movie
    else
    lb=${j:5}
    mkdir /media/mkv
    fi
    mount $j /media/mkv
    else
    mkdir /tmp/"$lb"
    mount $j /tmp/"$lb"
    fi
    fi
    done
    30 Dec 2008
    France
    mulţumesc mult
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    22 Dec 2008
    Default Incubus 1.16
    If your image is installed with KCC:
    edit:
    /hdd/ba/ba/e2_RSPv3.149_G1192/bootp.conf file
    or,
    /tmp/sda1/ba/ba/e2_RSPv3.149_G1192/bootp.conf file
    in e2 image.
    In this file you must replace:
    hwaddr:$ethaddr
    with
    hwaddr:00:13:18:00:01:02
    If image is installed from RSP Panel, you already have other ip in file (like hwaddr:00:50:fd:ff:78:ce)
    In this case replace existing mac with : hwaddr:00:13:18:ff:78:ce
    Thanks a lot Zildan,
    But doing this made my network very unstable. Th enetwork adapter could not be found. I reinstalled the iamage several times by formating the USB but the same problem. Finally I had to install the AAF flash image and it started working again.
    Best regards and thanks for once again your help,
    Afzal
    Change of mac address does not affect network stability.
    This method is verified by many users.
    Try to edit the file with Notepad2.
    16 Apr 2010
    Default Hi
    Zildan , how to change font and font size on DVB subtitle .
    Font size on DVB subtitle is skin resolution dependent.
    Big size at SD skin , small size at HD.
    30 Dec 2008
    France
    bonsoir
    how can I see subtitle.srt with a file.mkv ?
    thanks for your help
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    Latest SH4 DuckBOX images based on STM22, works with srt external at MKV files
    30 Dec 2008
    France
    thanks for your reply, but
    i can't find the subtitle.srt ?
    I transfert it in the same directory as the mkv file, in the tmp, but i don't understand how i can select the subtitle ( no blue button same as devil image )
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    RSP - TEAM
    03 May 2007
    Please tell us what E2 image you are using. Zildan spoke about latest images not the RSP e2 v.149 G1192.
    30 Dec 2008
    France
    same as this post : e2_RSPv3.149_G1192
    I'm very glad to read this , but how ?
    i'm sorry...
    Flash : AAF2.e
    5?W_13?E_19?E_28?E
    09 Jan 2010
    Default External USB tuner?
    any drivers for extra tuner in development?
    I want to use USB stick tuner for DVB-T2
    http://www.dabs.com/products/pctv-sy...b-t2-77KG.html
    29 Sep 2010
    Default UFS-910 e2 RSPv3.149 G1192
    Hello, I installed the image in usb, UFS-910 e2 RSPv3.149 G1192. and image TDT E2 RSPv3.98 VER1749 as Jame image very pleased, but I nji problem with the clock on the screen when Kathi is in stendbay looks at the screen, how can clock disappeared from the screen, when Kathi is in stendbay s, I like to look at the screen
