Results 1 to 13 of 13
Thread: Oscam 1.00 la panel de azi
    93 Post(s)
    Default Oscam 1.00 la panel de azi
    Incepand de azi consider deja utilizabil oscam 1.00.
    Am creat un nou pachet de emu oscam_1 la panel, bazat pe OSCAM 1.00-svn build #3282.
    oscam.conf
    oscam.server
    oscam.user
    nu sunt in pachetul central, se descarca de la meniul de download emu conf.
    Aceste file nu se pot sterge decat manual (ftp sau telnet) ca sa nu pierdeti cumva linii din neatentie !!!
    Recomand stergerea oscam.conf inainte de trecerea la noul oscam.
    Despre noua versiune 1.00 pot spune ca se misca mai bine si mananca resurse mult mai putine.
    Spor la teste !
    RSP Enigma Team & GM
    04 Feb 2007
    O intrebare referitoare la oscam :face AU pe CAID 1880????
    Daca da cum trebuie setat ?? Daca Nu asteptam in continuare
    f11
    Multumiri @Zildan
    01 Sep 2009
    Face doar cu mgcamd, cu dvbapi inca nu merge.
    [DIGI-S/C Extra Complet][0.8m Fe, LNB 0.2dB 1W+19.2E, DM500S][0.9m Al, LNB 0.2dB Quad 1W, HSS-1160NA] [1.5m Al Motorized (15W-53E), LNB 0.2dB, Sunray4 SR4 TripleTuner] [Humax DIGI+C]
    93 Post(s)
    @f11
    Pe kathy faci cu Incubus update, pui linia newcamd in incubus astfel:
    la :
    ########################### provider configuration ###########################
    Code:
    #GIGI_GALBEN
    [Prov:00000:CaID:1880]
    check_priority=cs,cs,cs
    cs_protocol_order=newcamd,,,,,
    process_emms_on_cs_mode=1
    process_emm_g=1
    process_emm_s=1
    process_emm_u=1
    si la [Servers]
    Code:
    card_server_url=newcamd://kathy:kat@192.168.124.110:7477:1880:000000/0102030405060708091011121314/EMM
    Face in max 1 minut update, daca nu face dai telefon la ei si ceri la robot activare.
    Cardul e evident il pui in OSCAM, si dai linie newcamd catre incubus.
    Oricum la nagra incubus e cel mai bun la EMM, el provine dintr-un emu dedicat nagra (rqcamd).
    27 Apr 2007
    Bayern, DE
    Default SaluT!
    Zildan, s-ar putea sa faci upload undeva al fisierului OSCAM 1.00-svn build #3282 ce il folositi la Kathrein? As dori sa-l folosesc pe Ipbox. Multumesc
    VU+ UNO 4K SE, VU+ Solo SE, Edision Progressiv Hdc+, Kathrein UFS 910
    04 Jan 2010
    Am incercat pe 910hd si svn3282 si altele mai noi.totul ar fi in regula daca nu ar ingreuna sistemul .reactia la telecomanda e foarte proasta.Cu 3090,3107 se misca putin mai aerisit dar tot greu.Cu 2978 e racheta !Cu noile versiuni procesorul este folosit dublu fata de cat era inainte.
    La voi ?
    93 Post(s)
    E exact pe dos la mine .
    04 Jan 2010
    Hmm..., puteti posta config. dvs?,cate grupuri,care grup e in local,cate linii primite si cate date ?Si eventual pe ce imagine si ce box.
    daca nu aici atunci pe pm sau email .
    Multumesc !
    19 Post(s)
    @technomate ... incearca sa te "joci" putin cu parametrul nice ...
    la noile versiuni de Oscam valori de genul -10 ... -5 sint OK !
    93 Post(s)
    Default oscam-svn3300-sh4-amino
    Oscam-svn3300-sh4-amino
    Pare stabila.
    3301 are probleme la loadbalancer.
    Attached Files Attached Files
    04 Jan 2010
    da ,pare.merge acum si la mine cu resurse mai putine si chiar rapid dar mi s-a innegrit pe tvr dupa 2 minute si dupa o jumateta ora de uitat pe alt post s-a inegrit ecarnul pe toate posturile desi emm isi ia si oscam functioneaza.am pus verisune mai veche si s-a albit .
    93 Post(s)
    Eu scriu de clientul de cccam, tu scrii de cardul de TVR pus in oscam.
    Cred ca voiai sa spui ecm-uri acolo.
    Cardul de tvr nu e stabil in oscam, cel putin eu nu am fost foarte multumit.
    04 Jan 2010
    Scuze daca s-a inteles altceva.nu de card vorbeam ci de tvr1 pe rc s .Tot de client vorbeam si eu .Mai testez .
