Thanks Thanks:  10
Likes Likes:  4
Page 5 of 19 FirstFirst 12345678915 ... LastLast
Results 61 to 75 of 271
Thread: Openbox s9 hd pvr
  1. #61
    95 Post(s)
    Nu cred ca poti sa afli fec sau daca e dvb-s2 transponderul.
    Si cand definesti un TP nou se introduce doar frecventa, polaritatea si SR-ul.
  2. #62
    20 Sep 2007
    La multi ani !
    Am o intrebare: stie diseq 4+1 sau 8+1 ?
  3. #63
    95 Post(s)
    Stie diseqc 4, USALS, cu 8 nu am testat (nu prea am cu ce).
  4. #64
    20 Sep 2007
    Deci, in concluzie, merita luat acest receptor ? Vreau doar sa ma uit, nu prea am timp de teste.
  5. #65
    95 Post(s)
    E bun de sharing! stabil dar simplu.
  6. #66
    20 Sep 2007
    Mersi mult, cred ca il iau.
  7. #67
    Deci se pare ca merita. Stie cineva vreun dealer autohton?
  8. #68
    RSP Enigma Team
    28 Aug 2009
    Departe
    Nu am vazut mentionat anterior, dar intreb totusi: are si media player? File acces (Samba) sau cu un plugin VLC poate?
    A, si cum e timpul de pornire, din stand-by si din power-off?
  9. #69
    95 Post(s)
    Media playerul e restrans la MP3 si inregistrari TS.
    Porneste in maxim 30 sec (daca are linii CCCam de activat).
    Nu are standby activ (adica se opreste total cand apesi power off).
  10. #70
    Standard RSP member sergio_qqq's Avatar
    11 Nov 2010
    Default new firm
    New Official Firmware [HDS2-11-01-02:0899CMT] and L53_MOD_Dump.
    This is a New Official Firmware version, and was released on [06 January 2011]
    The New Official Firmware version do not include any channels.
    The L53_MOD dump file is based on firmware version [HDS2-11-01-02:0899CMT]
    The modified download includes a full channel list pre-installed.
    Included in the Dump file is a multi-satellite channel list.
    The channel list default setting is DisEqC 1.2.
    Coverage of the channel list is: 45east to 30west.
    Included in the zip file is a replace.list.
    The channel list can also be used on a fixed dish setup, simply click the Zoom or SatList button, and select any satellite from the data base that you wish to access.
    What's New:
    In version [HDS2-11-01-02:0899CMT] the following have either been added, fixed or changed:
    1 .. Making a full system dump is now fixed.
    2 .. CCcam Priority option added.
    3 .. Security Password when entering sections such as the CCcam secrion has now been deactivated.
    4 .. On Bootup the display will once again show the IP Address used in your clines.
    6 .. A few minor bugs addressed, making the receiver more stable.
    Well over 200 new or updated channels on various satellites.
    Re-organised channel list on a number of satellites.
    A number of non accessable channels removed from various satellites.
    I believe all the channels that cause rebooting problems, have now been removed.
    To optimize this list & receiver to it's full potential, you will require a full multi-sat coverage cline.
    Instructions:
    If this is the first time you have uploaded a Dump.file, then you will need to read the following instructions:-
    1 Click Menu -> System Setup -> TV System -> Video Resolution this will return to the default setting of [1080i 60] after each upload, if your TV has a refresh rate of 50Mhz then set the video resolution to [1080i 50] and the picture will become clear now press exit
    Now select Local Time Settings and set it as follows if your in the UK:
    1 GMT Usage ... ON
    2 GMT Offset .. UTC+00:00
    3 Summer Time . OFF
    now click exit and exit again
    Now select Network Local Setting and if your router supports DHCP then set it to On
    otherwise you will need to configure the settings manually, once you have set it up click Apply then exit
    Finally click CCcam Plug Setting, if you already have an active cccam.cfg file transfer it to a USB Stick insert the stick into the USB connection on the rear of the receiver and click Update Files By USB then select Option 1 in the popup box and click the OK button then click the Yellow button and your cccam.cfg files will be transfered
    Now you need to activate the files, click CCcam Plug Setting then Manage Config Files click Option 1 and select each file in turn and click the OK button when you have a tick next to the files you wish to activate then exit.
    To finish the activation and configuration process you must now reboot your receiver, then once it has restarted all should be okay.
    The channel list included in the HDS2_L53_MOD file, includes the latest L53 multi-satellite channel list, this is by no means a finished list, and is still an ongoing project WITH REGULAR UPDATES.
    How to add the replace.list file.
    Click Menu -> Network Local Settings -> MGCamd Plug Settings -> Update Files by USB
    -> replace.list [MGCamd Plug] now click either the OK or Green button to select replace.list and place a check mark next to it, once the check mark or tick is visable click the Yellow button to upload.
    You can then if you wish, check to see if the replace list has been correctly added, by clicking Manage Config Files and clicking on relace.list if all went well, you will see the following line: X: {{ 1833 } { 1702 }}
    Anyone may use, or share this modified Dump file, all I ask is that you do not remove, or edit the files included in any way, or add any other extra files, which are mainly spam, giving credit to some obscure web site.
    Of course we are aware of the fact, that some still have a tendancy to ignore the above request.
    http://www.megaupload.com/?d=WJJPPDK0
    http://www.megaupload.com/?d=0L25ZJBI
  11. #71
    05 Feb 2008
    tauste,zaragoza,spania
    de pe alt forum:
    Pues bien, aqui os dejo como usar este juguetito nuevo como servidor:
    Importante: Tener ultima version del firmware la 20/10/2010 Manual Aquí
    Voy a poner el manual con un deco openbox como server:
    1.Menu
    1.2. Network Local Setting.
    1.3. Network Local Setting.DHCP, Apagado y ponemos la ip. ejemplo: 192.168.1.101.
    2.Newcamd Server Setting
    3.Newcamd Server Paraeter-----> Server Setting-----> Encendido
    4.Pulsamos Exit.
    5.Newcamd Server User Maganger---->Pulsamos boton verde (añadir). En User: nombre de usuario del cliente 1, en password: nombre del passwor del cliente 1, EMM Allow: Enable. Aqui agregamos todos los clientes.
    Ya esta el servidor listo a la espera de los clientes.
    Voy a poner el manual con un deco openbox como cliente:
    1.Menu
    1.3. 1.3. Network Local Setting.DHCP, Apagado y ponemos la ip diferente al server, osea correlativa mismo rango, ejemplo 192.168.1.102.
    2.Pulsamos con el mando Exit.
    3.Nos vamos a CCcam Plug Setting.
    3.1.Manage Config Files.
    3.2.. Pulsamos en 1 CCcam.cfg.
    3.3. Le damos boton azul y añadimos datos servidor.
    3.4. Añadimos los datos del servidor, Ip, puerto 12000 usuario y contraseña.
    3.5. Le damos activar.
    4. Reiniciamos.
    Vuala funcionando sin cortes ni nada (Probado en local) solo para salon y cuarto estar, si fuera por internet, abria que abrir los puertos del router apuntando al servidor openbox, y poner en vez de la ip del servidor la cuenta dyndns o no-ip que tengamos.
  12. #72
    Standard RSP member bobo74's Avatar
    02 Mar 2007
    O impresie placuta mi-a facut acest receptor...in cateva ore cat am avut timp sa-l butonez...
    Am ocazia sa testez cateva mostre Openbox S9 HD PVR aduse de un importator de la o fabrica din China si sunt placut impresionat de calitatea imaginii,usurinta in exploatare,sensibilitatea tunerului,rapiditatea blind scanului,usurinta cu care am instalat noul soft prin USB si stabilitatea in sharing ca si client Cccam.
    In concluzie,un raport excelent calitate pret.
  13. #73
    11 Nov 2010
    se vinde deja in Romania? unde si cu ce pret?
    tnx!
  14. #74
    02 Mar 2007
    Cu siguranta sunt in acest moment si in Romania dar in curand vor fi importate oficial.
  15. #75
    Azi le-a facut vama si marti imi vin 3 bucati pentru niste prieteni....
