Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 110
Thread: e2 Alien Beta 05
  1. #46
    20 Mar 2011
    Default sound issues playing mkv's
    Thank you guys for this wonderfull image. It is really fun to use it.
    I really really want to have the cardreader working. Hope you can manage to get it to work...
    And since beta 5, I have issues when playing MKV with ac3 and DTS sound. I play it all over HDMI. Every few minutes or every minute, the sound stutters. The sound stops for a moment and then it plays further. I don't know if this due to a setting or is it a buffering problem?
    It appears more with DTS sound, than with Dolby. I suppose thats logical because of the higher bitrate with DTS. But also with Dolby, there is stuttering with the sound.
    And I play straight from the connected USB-harddrive. It is formatted by your image. Suppose that is ext2 or ext3?
  2. #47
    08 Jan 2011
    greece
    Se misca foarte usor si nu a rebootat niciodata,e super.
  3. #48
    27 Feb 2011
    whether the next Version of E2 to be a beta or final?
    When will appear the next Version of E2?
    Will you correct support for DVB subtitles?
    Thanks
  4. #49
    When we have multiple news, the image will become public.
  5. #50
    24 Dec 2010
    După oprirea receptorului pe E2 la repornire incepe se se restarteze singură fără să poti interveni.Am reinstalato si la fel pină să opresti receptorul merge foarte bine la repornire aceeasi problemă.Trebuie setat ceva ce nu stiu eu ?Doar cu ultima E2 V 05 am această problemă.
  6. #51
    23 Apr 2007
    P3X-888
    il scoti de sub tensiune 3 minute si o sa porneasca ... viitoarea versiune nu are acest bug .
  7. #52
    20 Mar 2011
    and please send message for support team,that scart and component output not work,
    in resolution 1080,720 (when i trying conect second TV)
    THANKS for good image
  8. #53
    19 Post(s)
    Normaly ... this setting is meaningless ! or SD or HD ! but if you want HD and from time to
    time to make tests on SD ... use V-Format button to switch dynamicaly the video mode !
  9. #54
    20 Mar 2011
    thanks for answer, i know about it, but it not so good (but not tragedy too) in dreambox 800 this problem isnt.
    is problem to fix this problem? just ask
    thanks
  10. #55
    08 Jan 2011
    greece
    alex 1971
    si eu am avut aceeasi problema si s-a rezolvat dupa ce am downloadat imaginea e2 beta5 de pe sat-support, merge foarte bine
  11. #56
    08 Feb 2011
    At the price of a DM800 you can buy another Amiko Alien or Edision Pingulux
  12. #57
    24 Dec 2010
    Sa rezolvat după ce am aplicat sfatul lui Stargate . La emulatoare nu reusesc ,aceeași problemă ca la MaximusFBI am router de la Romtelecom.Vă multumesc.
  13. #58
    08 Jan 2011
    SPACE
    Mai asteptam poate vine maestrul @Zildan cu o solutie pentru routerele astea Romtelecom sa putem downloada si noi.
  14. #59
    19 Dec 2010
    Drobeta Turnu Severin
    Default salut
    @MaximusFBI eu cred ca nu routerul de la romtelecom este problema,,,, alceva este la tine eu am net de la romtelecom + routerul dat de iei care este foarte bun ,testate de mine, spune ce model ai si poate te pot ajuta.
  15. #60
    08 Jan 2011
    SPACE
    Modem Huawei Romtelecom si router Netgear WPN824
    Cu specificarea ca da ping la google si da jos softcam si wheater ok dar nu emu .
