Page 5 of 8 FirstFirst 12345678 LastLast
Results 61 to 75 of 110
Thread: e2 Alien Beta 05
  1. #61
    19 Dec 2010
    Drobeta Turnu Severin
    Default ress
    poti instala emulatorul si manual, sa pui imaginea din nou si-l downloadezi sigur...
  2. #62
    Editeaza cu ceva care nu schimba tipul fisierului (din unix in DoS) :
    /usr/lib/enigma2/python/Plugins/Extensions/Fantastic/addons.sh
    schimba :
    ping -c 1 www.google.com
    cu
    echo ok
    si va merge !
  3. #63
    08 Jan 2011
    SPACE
    @Zildan un adevarat shaolin . Mergeeeeeeeee .
    Am emu .
    THX .
    Uffff ! ce bine !
  4. #64
    14 Mar 2011
    Default diseq8
    Diseq 8 not yet enigma2?
  5. #65
    04 Mar 2011
    Post
    Quote Originally Posted by rudi77 View Post
    To configure the tuner including advanced settings.
  6. #66
    14 Mar 2011
    Default disq8
    Original spark good disq8.
    Vu+duo enigm2 too.
    E2 alien beta 05 not yet!
  7. #67
    24 Dec 2010
    Cum ai procedat MaximusFBI?
  8. #68
    20 Mar 2011
    Quote Originally Posted by mihaip View Post
    Normaly ... this setting is meaningless ! or SD or HD ! but if you want HD and from time to
    time to make tests on SD ... use V-Format button to switch dynamicaly the video mode !
    wanna say, if i use resolution 1080,720- main TV with HDMI work,but second TV (i conected it from scart,or RCA) have no picture. only in resolution 576 picture is in main TV ,and second TV
    i tried another in another receiver,like dm800, vu+, ariva, its havent this problem
  9. #69
    08 Jan 2011
    SPACE
    @alex1971 vezi postul lui Zildan mai sus .
    Intra cu Total comander si editeaza cu un editor linux ce a scris , introdu la loc si e ok .
    La mine a mers din prima .
  10. #70
    31 Dec 2010
    Vu+duo enigm2 too.
    Works fine with a 10/1 diseq switch! Check your settings. Use diseq1.1 mode & uncomitted input settigs.
  11. #71
    04 Mar 2011
    Post
    Vu+duo enigm2 too.
    Do not talk nonsense.
    Beta 5 - works fine with diseqc on 8 !
    See the screenshot above to the topic.
    Set mode 1.1 , uncommit inputs 1-8 and all ok.
  12. #72
    24 Dec 2010
    Default salut
    Unde pot să descarc o listă sateliti pină la 90-96 grade E .
  13. #73
    Peste 65E ... nu cred sa prinzi ceva .
  14. #74
    26 Feb 2011
    Hello guys, when will the final version of the E2 Amik!!
    many thanks for your work so far
    Thanxs
  15. #75
    18 Mar 2011
    Can I just notice for the content of E2. Do we have reason to celebrate.
    I know of skin: HD Glass 16
    Thanks to the earlier work!
