Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Glass System Utility
    Default Glass System Utility
    Glass System Utility 3.11
    - added Devices manager - mount, unmont, format, file checking and partitions management - creating, deleting
    - small code correction, and update of cams
    29 Nov 2008
    Cu capu' in nori
    Glass Utility 3.40
    This one works for the Vu+Do and the et9000
    - 2nd fix oscam info - entitlements
    - added a new function: autoinstall
    Description: allows you to automatically install ipk packages stored in the source dir (defined in setup, default: / media / hdd / autoinstall) after the start of E2 (may be allowed via setup, default: inactive), through the setup it is possible to view the current state of ipk files in the source dir, it is possible to immediately run the installation.
    Applications: copy the required ipk (plugins, etc.) into the source dir, in the setup to allow autoinstall, after start plugin try installing new and unsuccessfully installed ipk packages
    Note: the state before each installation and display the status is updated
    Download :
    http://www.megaupload.com/?d=7LKQXRQT
    29 Nov 2008
    Cu capu' in nori
    GSU Full ver. 3.41
    - oscam info:
    1. added proxies(oscam, cccam) entitlements
    2. updated oscam to rev. 5372
    Download :
    http://www.megaupload.com/?d=73J1M9WY
    29 Nov 2008
    Cu capu' in nori
    GSU Full ver. 3.42
    - updated oscam rev. 5378
    - updated vizcam 1.15
    - updated hypercam 1.14
    - updated gbox net 796
    Download :
    http://www.megaupload.com/?d=C51L2JM0
    GSU Full ver. 3.93
    Download
    Thumbs up GSU ver. 6.88
    GSU ver. 6.88
    - system info: fix CPU using calculation
    - system info: fix displaying FHD icons
    update is available online
    Thx@shamann​
    enigma2-plugin-glasssysutil_6.88_all.ipk.zip
    https://mega.nz/#!vBNyiZxS!0c7AUh3OP...C0s4S2XTiWacgc
    enigma2-plugin-glasssysutil_6.88_all.deb.zip
    https://mega.nz/#!fJdknDxY!HS4dJNhVz...lgldmc5pEUMjiY
    Thumbs up Full HD Glass 17 ver. 1.86
    - updated: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt, fr
    - fix/corections more of screens
    - fix mgcamd, gcam detection
    - fix setup of FHDG17
    - acceleration menu items switching in menu types with icons and pictures
    - DOWNLOAD MENU: bigger update of menu icons, menu icons big
    - added alternative method to searching of picons (if missing search 1_0_1...,
    1_0_16..., 1_0_19...)
    - OTHERS: added option - Service scan long list
    - LISTBOX FONT SIZE: added auto settings of line hight if font size was changed
    - WEATHER: changed "Country" to "Location"
    update is available online (setup and website)
    Thx@shamann​
    enigma2-skin-fullhdglass17_1.86_all.ipk.zip
    https://mega.nz/#!7IckCBKR!3OYJ2nK7J...vTilKnSbhsYXf8
    enigma2-skin-fullhdglass17_1.86_all.deb.zip
    https://mega.nz/#!SNkBxJ5D!MfGLqhMPo...T-FD1W24YfxnwM
    Thumbs up GSU ver. 10.07
    GSU ver. 10.07
    - add sk,cz localization
    - added dir browser to all config screens where the path is requested
    - txt editor extended to fullscreen
    - extensive coding and optimization of listings for localization
    - device manager: change device mounting type to "by uuid", added detection of partition table error device and every partition, automatic detection of authorized operation with selected device/partition, added SD card detection in SD card reader (deb version only) with full administration and mounting options (test provider on dm900) , added possibility to mount device on multiple mount points (f.e. usb flash disk mount as /media/usb, /media/hdd ...)
    - modified/unified appearance for all GSU screens
    - fix oscam reader entitlements
    - cleaning ipk/deb packages from unnecessary files
    - fix TXTeditor
    Thx@shamann
    enigma2-plugin-glasssysutil_10.07_all.ipk.zip
    https://mega.nz/#!CdVGDRiI!aNdYi9q1U...8vZfUIUY6ga3XI
    enigma2-plugin-glasssysutil_10.07_all.deb.zip
    https://mega.nz/#!ac0yUDpa!PdBu5feKY...Y_u68OOW-vc8TQ
    Thumbs up GSU ver. 10.14
    GSU ver. 10.14
    - added help with translations to CAM/SRV manager
    - edited script centers with full support for naming translations and user script descriptions
    - added another cmd options for oscam start cfg
    - updated sk, cz translations
    - added picon channel to CAM/SRV manager
    - fix UHD, FHD, HD screen for CAM/SRV manager
    - changed calculation of position of satellite from static to dynamic by tuned data from tuner - it also allows you to get info about the newly created or non-standard sat positions - used in the channel information, CAM/SRV manager
    Thx@shamann
    enigma2-plugin-glasssysutil_10.14_all.ipk.zip
    https://mega.nz/#!iQFXxboJ!7o0mzMcs3...QSA7WhxE9QjpvE
    enigma2-plugin-glasssysutil_10.14_all.deb.zip
    https://mega.nz/#!GJcVBIgT!cGdfyfiCp...ZdJh1w4RFiDMCQ
    Thumbs up GSU ver. 10.18
    GSU ver. 10.18
    - added enhanced method searching picons
    - CAM/SRV manager: fix avalaible CAIDs
    - main code and screens corrections
    - fix/enhanced detection DVB-T/T2
    - fix channel information screen
    Thx@shamann
    enigma2-plugin-glasssysutil_10.18_all.ipk.zip
    https://mega.nz/#!WAsXwKLT!xLD5usloa...WPQ_J-F5_NTOMM
    enigma2-plugin-glasssysutil_10.18_all.deb.zip
    https://mega.nz/#!WNUWTYQK!UKGsz9KkM...XrqMiXA3GckiAA
    GSU ver. 11.06
    fix CAM/SRV version detection
    Thx@shamann
    enigma2-plugin-glasssysutil_11.06_all.ipk
    https://mega.nz/file/2RtyjIjS#pvEMgD...1qdlpUi7U7EQMw
