Thanks Thanks:  12
Likes Likes:  7
Page 2 of 17 FirstFirst 12345612 ... LastLast
Results 16 to 30 of 247
Thread: Other Alien E2 Images ST7111
    14 Mar 2011
    Default oscam
    Yes yes my config probelm.
    Oscam run.
    Timeshift too!
    Mount cifs:
    telnet box:
    mount -t cifs //ipcomputer/share -o username=username,password=password /media/sda1/
    For cifs mount (in RSP images) edit /var/config/amnt.cfg, enable CIFS from RSP panel and reboot image.
    14 Mar 2011
    Default cifs
    This is image not yet!
    In all RSP image works CIFS mount and /var/config/amnt.cfg.
    14 Mar 2011
    Default mnt
    This is topic not rsp image!
    other image
    ProtoLux v2 vom NF-EOS-DEV-TEAM
    04 Mar 2011
    In this image on another. No such file.
    ---------- Post added at 19:20 ---------- Previous post was at 19:18 ----------
    Quote Originally Posted by rudi77 View Post
    Mount cifs:
    telnet box:
    Thank you.
    Oscam run.
    Timeshift too!
    You started oskam ? All is well now ?
    17 Apr 2011
    Image is designed for installation in flash
    Support receiver: Golden Media 990 CR HD
    http://e2.pkteam.pl/index.php?dir=IM...MEDIA/Enigma2/
    Added by PKT:
    - PKT Blue Panel
    - PKT EMU Manager v1.0.2
    - PKT Mount Manager v0.7.4
    - PKT Info Center
    - PKT Skin Setup
    - PKT Key Mapper v1.2
    - PKT Install Manager v1.0.2
    - PKT Disk Manager
    - PKT Media Center
    - PKT Channel Control
    - PKT Spinner Selector
    - GraphMultiEPG PKT mod
    - DD Subtitle
    - DM Napi v1.3.19
    - Dream Explorer v6.9
    - My Tube Player
    - VidBrowser v1.0
    - SHOUTcast
    - Simple Bitrate
    - WebcamViewer
    - CrossEPG v0.6.1
    - PKT Basic HD skin
    - PKT F1 HD skin
    - PKT Gold HD skin
    - PKT Silver HD skin
    - PKT Allien HD skin
    - PKT Black Glass HD skin
    - PKT Picons
    - add HighSR support
    - add RT2870 & RT3070 WIFI drivers & Setup
    - add FTDI & PL2303 Support
    - add SWAP support
    - add NFS/CIFS/NTFS support
    - add Timeshift & recording Patch
    - Remote control tuning:
    Folder - Media center
    Page Up/Down - Cahnnel Up/Down
    Tms - Timeshift
    TTX - Teletext
    FAV - Feed Panel
    Green - Audio Select
    Yellow - Video select
    Blue - Blue Panel
    and many others...
    FTP login: user:root, passwdkteam
    18 Feb 2011
    BiH
    Is this for amiko alien?
    17 Apr 2011
    Golden Media S 990 HD PVR spark LX (Enigma 2) has the same hardware as Amiko Alien so u can try this image.
    18 Feb 2011
    BiH
    Ok ty.
    Is this same instalation via usb like rsp?
    17 Apr 2011
    No one has tested this on the alien Amiko so you will be first.
    Introduction
    1. Prepare a USB stick with 1 partition in FAT32
    2. Set the default system boot for [enigma2] (For frontpanelu hold [OK] and then turn the power switch, after about 5 seconds, the display should appear in the display [FORCE] then you should let the [OK] and press [P] - appears Enig words)
    3. Create a directory on the pendrive enigma2
    4. Copy the uImage and e2jffs2.img a previously created directory enigma2
    Upload Image Enigma2:
    1. Turn off receiver
    2. Connect a USB stick ready to receiver
    2. On Frontpanelu hold [OK] and then turn the power switch
    3. After about 5 seconds, the display should appear in the display [FORCE] then you should release the [OK] and press [V +]
    4. If everything was done correctly the display flashes [U LD] which means that the image is loaded.
    5. After finishing the upload operation should be released shows [Succ], and the receiver will reboot automatically
    05 Feb 2007
    not working the download link. It's fake???????????
    30 Mar 2011
    Slovakia
    Lightbulb PKT image
    It's no fake, I flashed this image and trying. The remote work better then on EOS. But it's for GM990, so exit is find, colour keys a F1-F4 and so on. You must do some reconfiguration for the Alien remote.
    05 Feb 2007
    I can't get the image the download stop above 3,6 Mb
    PS: I find the problem
    My Disk is Full ) have no space
    17 Apr 2011
    @joberuc
    When you are done the test, write that all is well on Amiko Alien.
