Page 4 of 18 FirstFirst 1234567814 ... LastLast
Results 46 to 60 of 261
Thread: e2 Alien RC1
  1. #46
    19 Post(s)
    @fundidun --- your problem has two solutions !
    1) install RSP E2 RC1 ... on RED you'll find RSP menu ...Installer ...Download EMU
    ...Download EMU config ...then you must edit ( Linux style ) ... /var/keys/oscam.server
    in order to reflect your C: lines ... and from the same panel in EMU ...Start/Stop ...
    2) in Spark ... download last plugin from www.sat-support.org ... install it ...then edit
    in /var/tuxbox/config/oscam.server ...put your lines there ...and start Oscam from plugin
    window !
    Both systems , E2 and Spark , are supporting Oscam as CCcam client as well as CCcam server !
    Into the Spark plugin you'll find a read.me file and some usefull example config files !
  2. #47
    10 Apr 2011
    Thanks for your reply, I indicated that I have already and I'm making a video, to be in them more clear,
    then I go up the youtube link to also help the members of this forum
  3. #48
    30 Mar 2011
    Slovakia
    Lightbulb Please help us Zildan
    @zildan
    Hi,
    can you give to us the information please, if you prepare kernel with old values​​ to prevent restart after the load modules. Or how we can use the RC1 on our Aliens.
    Thank you for your good job.
    joberuc
  4. #49
    Standard RSP member bogdan007's Avatar
    25 May 2010
    N V
    Default e2
    Exista diferenta mare intre Spark Si E2 la Sher ?
  5. #50
    23 Apr 2007
    P3X-888
    nu ... fisierele de configurare sunt 99,99% la fel difera doar linia boxtype = din oscam.conf , care pe enigma2 este boxtype = dreambox iar pe spark este boxtype = ufs910
  6. #51
    95 Post(s)
    I have now an image that seems to be working on all hardware, even on those that were reported to have big problems. A few of our betatesters have it, if everything will be alright, I will make it public.
  7. #52
    30 Mar 2011
    Slovakia
    Thumbs up Very good news about new version
    Thank you for your very good hard work again .
    I will wait for new version for all hardware.
  8. #53
    04 Mar 2011
    Default problem
    dont work total tv subtitle
    pliese help
  9. #54
    20 Mar 2011
    Are there different hardware versions of Amiko Alien???
  10. #55
    14 Feb 2011
    How I can install samba server on this image?
  11. #56
    19 Post(s)
    @satrich ... yes ! is a small difference but it is ! Spark was adapted to support both versions
    from the beggining ... in E2 this process just happens ! is visible at the bootup ...when the
    system is working with a minimal driver support and error recovery !
  12. #57
    20 Mar 2011
    What are the differences then?
  13. #58
    13 Apr 2011
    Buna ziua
    Nu ma luati tare sunt incepator cu alien-ul. Am instalat e2 RC1, pus oscam, aceleasi configurari ca pe spark insa nu merge card readerul intern (un card focus).Precizez ca in spark totul e ok. Am citit undeva pe aici ca nu ar functiona. Doresc doar o confirmare/infirmare pt RC1 sa stiu daca am gresit eu ceva sau mai trebuie sa astept o viitoare posibila rezolvare.
    Multumesc
  14. #59
    23 Apr 2007
    P3X-888
    inca nu functioneaza conax cu cardreaderul in enigma2 .... se lucreaza la un nou driver
  15. #60
    13 Apr 2011
    Multumesc stargate. Atunci hai cu driverul ca-mi face cam tare cu ochiul e2. Multumiri dezvoltatorilor si testerilor
