Menu->Setup->HD Glass Setup->Menu style: list
Thanx for that - it´s looks good.
bug-reports:
* autoswap causes boot-freezer every 2. boot
* hd_glass16 looks very good, but navigation in menu is tricky, jumping to next item in row is often not possible
Amiko Alien with RSP-Image
I try power off after night, but with the same result - restarting.
I will wait for your new version with old kernel settings.
Thanks for your work.
P.S.: But I don't understand, if the hardware is same, why I have this problem and the others no.
I also try ProtoLux_v2.1 and had the problem with bootlogo version, restart during boot.
when you flash de orginal fw first
and than the RC1?
DM800HD pvr
T90
Amiko Alien
I was trying flash Spark 1.1.35 first, then RC1 (long power off after first run), but with the same result - reboot after load modules on display. May this relate to the boot logo?
Thanks for the next help.
Super tare noul RC1 Enigma2. Este stabil , merge bine, MULTUMIM!!!!!!
Skinul HD-Glass 16 este f. fain.
Se poate instala si pluginul pentru subtirari DD-subt?
Multumiri pentru munca depusa
Am scos DD-subt pentru ca uneori nu mai pornea e2 de la el si nu am avut rabdare sa studiez problema.
HD-Glass 16 e frumos, util pentru informatiile sale, dar mananca 10 mega de ram in plus si ceva procesor.
Si, am uitat sa mentionez in primul post, acum subservices functioneaza pe VERDE.
---------- Post added at 12:18 ---------- Previous post was at 11:48 ----------
Am mai uitat si FLAC in media player, si multe altele adaugate in ultima luna.
Tanks i tested this versión anr report Log
Am uitat sa mentionez ca nu se mai poate face inregistare accidental in flash, nici timeshift.
Sunt implicit dezactivate la boot pentru ca accidental se putea face recording in flash!
Pentru inregistrari trebuie sa stiti urmatoarele:
- se poate inregistra doar pe partitii EXT2, EXT3 si FAT32 (cu limitare la 2Giga a unui fisier la FAT32)
- Daca partitia pe care inregistrati are LABEL = RECORD e montata automat la boot.
- O alta metoda este sa creati un director movie pe prima partitie !
---------- Post added at 16:32 ---------- Previous post was at 15:17 ----------
I forgot to mention that accidental recording in flash or timeshift recording start is no longer possible.
These are now disabled by default on boot.
To be able to use recording function, you must know the following:
- can be done only on EXT2, EXT3 and FAT32 partitions (with 2GB file limit applied on FAT32).
- If the recording partition is labeled RECORD it will be mounted on boot.
- Another method is to create a folder named movie on your first partition.
How to connect network hdd (cifs)? (timeshift,record)
cine a testat,stiti ceva citeste cardul conax ?? exemplu pocus?? asta pentru cei care au servere cu card local?? oricum multumim maestre zildan pt munca depusa !!!
@rudi77
For CIFS mount:
-enable CIFS in User options (RSP menu)
-edit /var/config/amnt.cfg
-restart box
For RECORDING read previous page
Timeshift need a lynk in image, momentan is disabled.
@spiry
Nu cred, inca nu am rezolvat total card readerul. Testate sunt vi@ si n@gr@
Buna,
Dupa instalare numai "boot-loading modules", am incercat de mai multe ori dar nu merge mai departe.Variantele anterioare au mers din prima.Oare sunt diferente hardware?
Thx
I had a movie folder on my Hard disk. I copied a movie in that folder. And now all of a sudden, it is deleted. It is no longer there.
Also the hard disk is not mounted on boot. Very anoying.
Can you explain how to format the hard disk? So I can use the Record, time-shift, media-player and also use Swap?
Or maybe you can make a menu item in the next image?
Because it is not clear to me now.
