Page 3 of 18 FirstFirst 123456713 ... LastLast
Results 31 to 45 of 261
Thread: e2 Alien RC1
    14 Mar 2011
    Default mount
    Not mount hdd!!!!!!!!
    cfg:
    record="RECORD"
    cifssrv="192.168.1.8"
    cifsdir="movies"
    cifsuser=""
    cifspass=""
    94 Post(s)
    #RECORD
    # Edit this if you want to use a different name for the label to mount
    # in /hdd/movie used for recording
    record="RECORD"
    ####CIFS
    # IP of the PC on which the shares are
    cifssrv="192.168.1.110"
    # A list of share names (it may be or not the directory name).
    # You can add more than one separated by spaces. If the share name
    # has spaces in it use '%' to replace it
    cifsdir="moviepc"
    # User used to log on on the PC
    cifsuser="user"
    # Password used to log on on the PC. If you don't use any just leave
    # it empty
    cifspass=""
    Attached Images Attached Images
    30 Mar 2011
    Slovakia
    Thumbs up Request for Zildan, please
    Can you give to us (I think waterman has the same problem) new kernel with old boot options please? I would to try new version your very good work, but we have this problem with restart.
    Thanks for your work
    20 Mar 2011
    You don't understand my point.
    It is the USB connected harddrive. It is not mounted to /dev/sda1. Not automatically
    I had it perfectly formated as ext3 with a movie folder in it. Inside there was a mkv movie. After connection to this image, the movie folder is empty. The file was deleted somehow. And I did not do it. So, there is something terrible wrong with the mounting of the USB drive.
    I did a re-format of the drive with the menu of this image. And again I copied a MKV movie to the /movie folder. There-after, the same thing hapened. After reboot, the MKV disappears. It was deleted somehow. I tried to re-mount the harddisk, but the file was still not there.
    Then, just to be sure I started SPARK. And indeed, no MKV file in the movie folder.
    So my question remains: How to handle with the USB harddrive? Because, it is pretty annoying to lose those big MKV files.
    94 Post(s)
    @waterman
    Formateaza stickul, scrie imaginea iar, si lasa 10 minute aparatul oprit inainte de boot.
    Daca face la fel, il opresti si il lasi iar oprit timp indelungat, apoi il pornesti.
    ---------- Post added at 21:48 ---------- Previous post was at 21:43 ----------
    @satrich
    Is a bug in my code.
    Mount HDD before delete "movie" folder.
    edit /etc/init.d/rcS
    rm -r /hdd/movie
    replace with
    #rm -r /hdd/movie
    Put mkv movie in other folder (on hdd) and find file in /hdd or /tmp/sda1 with media player !
    14 Mar 2011
    Default timeshift
    Ok good mount!
    How to activation timeshift?
    10 Apr 2011
    How do you install CCcam, in this version? and What to use?
    17 Mar 2011
    Quote Originally Posted by joberuc View Post
    Thanks for you work RSP team
    I have problem with this version, beta 5 works OK, but when I install this version RC1,
    Alien boot, then Loading modules, on display Load and then restart (boot) and again and again.
    On TV no screen, only flash when reboot Alien.
    I try download from rapid and megaupload, but it is the same.
    Thanks for your help.
    joberuc
    Same problem here, tried to reflash a couple times but every time with same result.
    Also tried to leave the device off for a couple minutes but same result agian.
    19 Post(s)
    @fundidum --- use Oscam instead ! there is no CCcam in SH4 boxes world ! but Oscam
    is the EMU witch solves all the required functions ... read and use it !
    Use RED ...then RSP pannel ...download Oscam emu and his configs !
    14 Nov 2010
    Bravo pentru noua versiune enigma2!
    A inaintat mult enigma pentru alienul nostru, si functioneaza perfect. Dar calitatea imaginii tot e mai slab fata de spark...
    Standard RSP member spiry's Avatar
    15 Apr 2009
    bukowinen
    Default stik problem
    am incercat sa instalez imaginea cu stik kingston de 4 giga. da eroare 7 70. trebuie sa caut alt model,sau capacitate, de 2 sau 8 giga.
    94 Post(s)
    @Tody
    Incearca sa reglezi lumina si contrastul la e2 din meniul AV setting, e iluzie ca se vede mai bine la spark.
    10 Apr 2011
    Quote Originally Posted by mihaip View Post
    Thank Mihaip The problem is I have multiple users on my forum that are waiting to see how it works CCcam with this version and gives them problems both Spark and in RSP.
    14 Nov 2010
    Quote Originally Posted by spiry View Post
    Eu spun, fa un full format pentru stick (in FAT32), copieaza-l din nou pe el enigma2, si daca tot da error, atunci raspunsul e: DA.
    20 Mar 2011
    @waterman
    @satrich
    rm -r /hdd/movie
    replace with
    #rm -r /hdd/movie
    I did edit the /etc/init.d/rcS file with telnet. But after that I can not boot. The display shows just 'boot'.
    So there is something wrong with the harddisk handling in this image.....
    I think /hdd is in flash memory? And not the physical harddrive.
    Thanks anyway for your great work.
