Am gasit un alt script, poate mai simplu de utilizat si am trecut pe el
Stie urmatoarele:
supported platforms
-native if compiler installed x86 x64 arm (dockstar)
-dbox2, dreambox 500,500-S
-dreambox 600,000,7020
-dreambox 500HD,800,800se,8000,7025
-openembedded 2.0 + new toolchain (gcc4.7 64bit build)
-fritzbox 33XX
-fritzbox 72XX
-fritzbox 73XX
-raspberry pi hard fpu
-raspberry pi soft fpu
-powerpc
-dockstar
-coolstream
-sh4
-sh_4 (new toolchain gcc 4.6.3 64bit build)
-tplink (1043ND)
-fonera
-ddwrt 2.4
-ddwrt 2.6
-openwrt 3.4.6
-openwrt 4.1.0
-arm nslu2 unslug
-arm nslu2 openwrt
simplebuild 1.07
IMPORTANT
MUST INSTALL THIS PACKAGES BY HAND
- dialog
- uni2ascii
- xz-utils
- subversion
- awk gawk or mawk (gawk is debian default)
- lib32z1 (for 64bit)
NATIVE - libusb-dev for libusb support
- libssl-dev for ssl support
cd /opt
mkdir simplebuild
cd simplebuild
wget http://ss4200.homelinux.com/oscam/simplebuild
chmod 777 simplebuild
./simplebuild checksys
./simplebuild menu
Daca apare o versiune noua de script te anunta la pornire si poti face update, descarca oscam ultimul/versiune aleasa, meniuri simple si intuitive, viteza sporita la compilare
Tnx @ Gorgone (Streamboardler )
