Thanks Thanks:  363
Likes Likes:  153
Page 12 of 12 FirstFirst ... 289101112
Results 166 to 176 of 176
Thread: OSCam - unstable sh4 - emu
  1. #166
    OscamEMU10004RSP
    Attached Files Attached Files
  2. #167
    19 Aug 2011
    UTC+13
    Speram ca 10001 sa ne aduca ceva interesant/nou. Foc de artificii, macar un CSS nou pentru look, etc.
    muta sobolanu` de aici
  3. #168
    OSCAM EMU SH40 10985 RSP cu toate optiunile.
    Pentru emu pe cablu adaugati 1801:002111 la CAID in readerul "emulator "
    Web interface support:                   yes
    LiveLog support:                         yes
    jQuery support intern:                   no
    Touch interface support:                 no
    SSL support:                             no
    DVB API support:                         yes
    DVB API with AZBOX support:              no
    DVB API with MCA support:                no
    DVB API with COOLAPI support:            no
    DVB API with STAPI support:              no
    DVB API with STAPI5 support:             no
    DVB API read-sdt charsets:               no
    Irdeto guessing:                         no
    Anti-cascading support:                  yes
    Debug mode:                              yes
    Monitor:                                 no
    Loadbalancing support:                   yes
    Cache exchange support:                  yes
    CW Cycle Check support:                  yes
    LCD support:                             no
    LED support:                             no
    Emulator support:                        yes
    Clockfix with realtime clock:            yes
    IPv6 support:                            no
    camd 3.3x:                               no
    camd 3.5 UDP:                            yes
    camd 3.5 TCP:                            yes
    newcamd:                                 yes
    CCcam:                                   yes
    CCcam share:                             yes
    gbox:                                    yes
    radegast:                                yes
    scam:                                    yes
    serial:                                  yes
    constant CW:                             yes
    Pandora:                                 yes
    ghttp:                                   yes
    Reader support:                          yes
    Nagra:                                   yes
    Irdeto:                                  yes
    Conax:                                   yes
    Cryptoworks:                             yes
    Seca:                                    yes
    Viaccess:                                yes
    NDS Videoguard:                          yes
    DRE Crypt:                               yes
    TONGFANG:                                yes
    Bulcrypt:                                yes
    Griffin:                                 yes
    DGCrypt:                                 yes
    cardreader_phoenix:                      yes
    cardreader_internal_azbox:               no
    cardreader_internal_coolapi:             no
    cardreader_internal_sci:                 yes
    cardreader_sc8in1:                       yes
    cardreader_mp35:                         yes
    cardreader_smargo:                       yes
    cardreader_pcsc:                         no
    cardreader_smartreader:                  no
    cardreader_db2com:                       yes
    cardreader_stapi:                        no
    cardreader_stapi5:                       no
    cardreader_stinger:                      yes
  4. #169
    Default Oscam emu sh40 10991
    OSCAM EMU SH40 10991.
    Am introdus direct in soft provaiderul autohton la CAID 1801
    | OSCam ver: 1.20-unstable_svn rev: 10991 target: sh4-linux
    | Tools:
    | Settings:
    |  CONF_DIR = /var/keys
    |  CC_OPTS  = -O2 -ggdb -pipe -ffunction-sections -fdata-sections
    |  CC_WARN  = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
    |  CFLAGS   = -fexpensive-optimizations
    |  LDFLAGS  = -Wl,--gc-sections -Wl,--format=binary -Wl,SoftCam.Key -Wl,--format=default
    |  LIBS     = -lpthread -ldl -lrt
    |  UseFlags =
    | Config:
    |  Addons   : WEBIF WEBIF_LIVELOG HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK LOCKFIX WITH_EMU
    |  Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
    |  Readers  : NAGRA CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD BULCRYPT
    |  CardRdrs : PHOENIX INTERNAL SMARGO STAPI STAPI5
    |  Compiler : sh4-linux-gcc (GCC) 4.7.3 20130514 (STMicroelectronics/Linux Base  4.7.3-124)
    |  Config   : build/sh4-linux/config.mak
    |  Binary   : Distribution/oscam-1.20-unstable_svn10991-sh4-linux
  5. #170
    OSCam SH40 ver: 1.20-unstable_svn rev: 10998
    | OSCam ver: 1.20-unstable_svn rev: 10998 target: sh4-linux
    | Settings:
    |  UseFlags =
    | Config:
    |  Addons   : WEBIF WEBIF_LIVELOG HAVE_DVBAPI READ_SDT_CHARSETS CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
    |  Protocols: CAMD33 CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
    |  Readers  : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD
    |  Binary   : Distribution/oscam-1.20-unstable_svn10998-sh4-linux
  6. #171
    26 Apr 2014
    De ce nu ami apare la emulatoare lam transferat cu TCM?multumiri anticipate
  7. #172
    E facut pentru imaginea RSP, se copiaza in /tmp si apoi se instaleaza din meniul de pe albastru.
  8. #173
    26 Apr 2014
    ok mersi frumos
  9. #174
    Default OscamEMU 11087
    | OSCam ver: 1.20-unstable_svn rev: 11087 target: sh4-linux
    | Tools:
    | Settings:
    |  CC_WARN  = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-stye-definitioni
    |  LDFLAGS  = -Wl,--gc-sections -Wl,--format=binary -Wl,SoftCam.Key -Wl,--format =default
    |  UseFlags =
    | Config:
    |  CardRdrs : PHOENIX INTERNAL SC8IN1 MP35 SMARGO DB2COM STAPI STAPI5 STINGER
    |  Binary   : Distribution/oscam-1.20-unstable_svn11087-sh4-linux
  10. #175
    14 Jun 2008
    Ro
    Salut! Ceva sperante pentru a avea si noi, cei cu sh4, lumina direct din oscam-emu in cazul canalelor p*wer vu? Ma gandesc la cei care au reusit asta direct pe DM fara stream relay. Am incercat cu patch de pe SU, pus la 11085 dar nu vrea.
  11. #176
    Daca ai ceva detalii cu ce au facut da un lynk.
    Sunt necesare modificari la DVB-api.
