Page 5 of 12 FirstFirst 123456789 ... LastLast
Results 61 to 75 of 176
Thread: OSCam - unstable sh4 - emu
  1. #61
    01 Sep 2010
    Andromeda
    Post Thanks / Like
    Oscam 6801
    Unix starttime: 1338342456
    Starttime:      30.05.12 01:47:36
    Version:        1.20-unstable_svn  Rev. 6801
    Max PID:        unlimited
    Active modules:
    Web interface support:      yes
    SSL support:                no
    DVB API support             yes
    DVB API with STAPI support: no
    Anti-cascading support:     yes
    Irdeto guessing:            yes
    Debug mode:                 yes
    Monitor:                    yes
    Loadbalancing support:      yes
    LCD support:                no
    IPv6 support:               no
    Cache exchange support:     yes
    camd 3.3x:                  no
    camd 3.5 UDP:               yes
    camd 3.5 TCP:               yes
    newcamd:                    yes
    CCcam:                      yes
    Pandora:                    yes
    gbox:                       yes
    radegast:                   yes
    serial:                     yes
    constant CW:                yes
    Cardreader:                 yes
    Nagra:                      yes
    Irdeto:                     yes
    Conax:                      yes
    Cryptoworks:                yes
    Seca:                       yes
    Viaccess:                   yes
    NDS Videoguard:             yes
    DRE Crypt:                  yes
    TONGFANG:                   yes
    BULCRYPT:                   yes
    Download
    ATENTIE!
    NU e compilat de RSP
  2. #62
    SUD
    Post Thanks / Like
    OSCAM 1.20-unstable_by_EasyBuild_svn build #6975
    | OSCAM ver: 1.20-unstable_by_EasyBuild_svn6975 rev: 6975 target: sh4-linux
    | Tools:
    |  CROSS    =
    |  CC       = /oscam-svn/toolchains/devkit_sh4/tdt/tdt/tufsbox/devkit/sh4/bin//sh4-linux-gcc
    |  AR       = /oscam-svn/toolchains/devkit_sh4/tdt/tdt/tufsbox/devkit/sh4/bin//sh4-linux-ar
    |  STRIP    = /oscam-svn/toolchains/devkit_sh4/tdt/tdt/tufsbox/devkit/sh4/bin//sh4-linux-strip
    |  RANLIB   = /oscam-svn/toolchains/devkit_sh4/tdt/tdt/tufsbox/devkit/sh4/bin//sh4-linux-ranlib
    | Settings:
    |  CONF_DIR = /var/keys
    |  CC_OPTS  = -O2
    |  CC_WARN  = -W -Wall -Winline -fno-strict-aliasing
    |  CFLAGS   = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=6975' -c -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=6975' -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LIBS     = -lcrypto -lm -lpthread       -lpthread -lm
    | Config:
    |  Addons   : WEBIF HAVE_DVBAPI WITH_LB CS_CACHEEX
    |  Protocols: CAMD33 NEWCAMD CCCAM CONSTCW
    |  Readers  : WITH_CARDREADER NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD BULCRYPT
    |  Compiler : sh4-linux-gcc (STMicroelectronics/Linux Base) 4.3.4 20091123
    Attached Files Attached Files
    Sh40, prime focus 1,5m si altele ...
  3. #63
    SUD
    Post Thanks / Like
    oscam-1.20-unstable_EasyBuild_Sh40_RSP_svn6979-sh4-linux
    | OSCAM ver: 1.20-unstable_EasyBuild_Sh40_RSP_svn6979 rev: 6979 target: sh4-linux
    | Tools:
    |  CROSS    =
    | Settings:
    |  CC_OPTS  = -O2
    |  CFLAGS   = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=6979' -c -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=6979' -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    | Config:
    |  Addons   : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_LB CS_CACHEEX
    |  Protocols: NEWCAMD CCCAM CONSTCW
  4. #64
    SUD
    Post Thanks / Like
    | OSCAM ver: 1.20-uEB_gensaveprio_RSP_svn7046 rev: 7046 target: sh4-linux
    | Tools:
    |  CROSS    =
    | Settings:
    |  CC_OPTS  = -O2
    |  CFLAGS   = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=7046' -c -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=7046' -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    | Config:
    |  Addons   : WEBIF HAVE_DVBAPI WITH_LB CS_CACHEEX IPV6SUPPORT
    Se pare ca nu merge Webif cu IPV6 asa ca atasam si versiunea IPV4.
  5. #65
    SUD
    Post Thanks / Like
    oscam-1.20-uEB_gensaveprio_RSP_svn7069-sh4-linux
    | OSCAM ver: 1.20-uEB_gensaveprio_RSP_svn7069 rev: 7069 target: sh4-linux
    | Tools:
    |  CROSS    =
    | Settings:
    |  CC_OPTS  = -O2
    |  CFLAGS   = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=7069' -c -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -O2 -DOS_LINUX -DSH4 -DTUXBOX -D'CS_SVN_VERSION=7069' -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    | Config:
    • This post requires you to click the Thanks button to see Attachments.
    • This post requires you to click the Likes button to see Attachments.
  6. #66
    SUD
    Post Thanks / Like
    oscam-1.20-uEB_RSP_svn7149-sh4-linux
    Compilat cu STM24 210
    | OSCam ver: 1.20-uEB_RSP_svn rev: 7149 target: sh4-linux
    | Tools:
    |  CROSS    = sh4-linux-
    |  CC       = sh4-linux-gcc
    |  AR       = sh4-linux-ar
    |  STRIP    = sh4-linux-strip
    |  RANLIB   = sh4-linux-ranlib
    | Settings:
    |  CC_OPTS  = -O2 -ffunction-sections -fdata-sections
    |  CC_WARN  = -W -Wall -fno-strict-aliasing -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
    |  CFLAGS   =     -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -Wl,--gc-sections     -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I  /oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LIBS     =     -lcrypto    -lpthread -ldl
    | Config:
    |  Protocols: NEWCAMD CCCAM GBOX CONSTCW
    |  Compiler : sh4-linux-gcc (GCC) 4.5.2 20110124 (STMicroelectronics/Linux Base 4.5.2-78)
    |  Binary   : Distribution/oscam-1.20-uEB_RSP_svn7149-sh4-linux
  7. #67
    SUD
    Post Thanks / Like
    | OSCam ver: 1.20-uEB_RSP_STM210_svn rev: 7170 target: sh4-linux
    | Tools:
    |  CROSS    = sh4-linux-
    |  CC       = sh4-linux-gcc
    |  AR       = sh4-linux-ar
    | Settings:
    |  LDFLAGS  = -Wl,--gc-sections     -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
    | Config:
    |  Binary   : Distribution/oscam-1.20-uEB_RSP_STM210_svn7170-sh4-linux
  8. #68
    SUD
    Post Thanks / Like
    | OSCam ver: 1.20-uEB_RSP_STM210_svn rev: 7277 target: sh4-linux
    | Tools:
    |  CROSS    = sh4-linux-
    |  CC       = sh4-linux-gcc
    |  AR       = sh4-linux-ar
    | Settings:
    |  CFLAGS   =     -I/oscam/oscam-svn/external_LIBS/SH4-DVBAPI/include
    |  LDFLAGS  = -Wl,--gc-sections     -L/oscam/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam/oscam-svn/external_LIBS/SH4-DVBAPI/include
    | Config:
    |  Addons   : SHOW_DREAMBOX_BUILD SHOW_SH4_DVBAPI_BUILD SHOW_PC_BUILD SHOW_NSLU2UNSLUNG_BUILD DO_ONLINECHECK WEBIF HAVE_DVBAPI WITH_LIBCRYPTO_SO CS_ANTICASC WITH_LB CS_CACHEEX MODULE_NEWCAMD MODULE_CCCAM MODULE_CONSTCW WITH_CARDREADER READER_NAGRA READER_IRDETO READER_CONAX READER_CRYPTOWORKS READER_SECA READER_VIACCESS READER_VIDEOGUARD READER_DRE READER_BULCRYPT FB7270
    |  Readers  : WITH_CARDREADER NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD DRE BULCRYPT
    |  Binary   : Distribution/oscam-1.20-uEB_RSP_STM210_svn7277-sh4-linux
  9. #69
    06 Dec 2008
    Post Thanks / Like
    Thumbs up Is gbox realy running in this compilation .
    | Tools:
    |  CROSS    = sh4-linux-
    |  CC       = sh4-linux-gcc
    |  AR       = sh4-linux-ar
    | Settings:
    | Config:
    Is gbox running in this version ?
  10. #70
    SUD
    Post Thanks / Like
  11. #71
    SUD
    Post Thanks / Like
    @Meridian
    Valoarea "nice" depinde de aparat si de versiunile de linux.
    oscam-1.20uEB_RSP_svn7410-sh4-linux
    | OSCam ver: 1.20uEB_RSP_svn rev: 7410 target: sh4-linux
    | Tools:
    |  CROSS    = sh4-linux-
    |  CC       = sh4-linux-gcc
    |  AR       = sh4-linux-ar
    | Settings:
    |  CC_WARN  = -W -Wall -fno-strict-aliasing -Wredundant-decls -Wstrict-prototype s -Wold-style-definition
    | Config:
    |  Compiler : sh4-linux-gcc (GCC) 4.5.2 20110124 (STMicroelectronics/Linux Base4.5.2-78)
    |  Binary   : Distribution/oscam-1.20uEB_RSP_svn7410-sh4-linux
  12. #72
    SUD
    Post Thanks / Like
    oscam-1.20uEB_RSP_svn7420-sh4-linux
    | OSCam ver: 1.20uEB_RSP_svn rev: 7420 target: sh4-linux
    | Tools:
    |  CROSS    = /duck210/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-
    |  CC       = /duck210/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-gcc
    |  AR       = /duck210/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-ar
    |  STRIP    = /duck210/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-strip
    |  RANLIB   = /duck210/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-ranlib
    | Settings:
    |  CONF_DIR = /usr/local/etc
    |  CFLAGS   =
    |  LIBS     =         -lpthread -ldl
    | Config:
    |  Binary   : Distribution/oscam-1.20uEB_RSP_svn7420-sh4-linux
  13. #73
    01 Sep 2010
    Andromeda
    Post Thanks / Like
    @zildan - Am incercat sa pun aceasta versiune pe rsp team e2. Am redenumit oscam-1.20uEB_RSP_svn7420-sh4-linux in oscam6182 si am dat atribut 755. Am primit eroarea din captura. Solutia: am pus oscam.config, oscam.server si oscam.user in 'locul indicat din imaginea de mai jos' si abia apoi a functionat. E pentru prima data cand se intampla acest lucru.
  14. #74
    30 Mar 2007
    Post Thanks / Like
    O fi pentru prima data cand s-a compilat cu o locatie diferita pentru config files si anume in /usr/local/etc nu in locatia default /var/tuxbox/config.
  15. #75
    01 Sep 2010
    Andromeda
    Post Thanks / Like
    Sub Spark nu emuleaza nimic! Oscam offline...
