Results 1 to 7 of 7
Thread: AAF Enigma2 Summer Image UFS 910
    Default AAF Enigma2 Summer Image UFS 910
    Iata o noua imagine AAF FullUSB
    SH4 Duckbox Projekt Git 2691
    + neuer Kernel P207 (STM2.4)
    + neuer Havana Player 191
    + updated ffmpeg 0.6.3
    + updated multicom 3.2.4
    + introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
    + [Player2 179/191] possible fix for chopped DTS sound on some files
    + [libeplayer3] support for OSD 3D modes for subtitles
    + [busybox] add busybox 1.18.5 stable
    + [at7500] flash_Extended better partitioning
    + [at7000]cam module fix
    + [at700/7000] Smartcardreader Treiber (Funktionieren die ?)
    + [tf7700] implement longkeypress support
    + [TF7700] Fixed sporadic crash in VFD plugin (hdd size)
    AAF SVN m9214
    + Auto Mode Switcher 3D (3D representation of the OSD in 3D on channels / videos)
    + 3D-mode tool to send the tv automatically in the 3d mode (only works on SBS) thx light MasterCard
    if it should go niche (as example):
    cd / dev
    rm hdmi0.0
    c 253 0 mknod hdmi0.0
    which must be specified as one can see with
    code:
    AAF at700: / # cat / sys/class/stmcoredisplay/display0/hdmi0.0/dev
    252:0
    + 3D mode on (Green ->) Blue button
    + Channel list updated
    + [E2 lng] - add PL.po for aaf panel
    + [Mc] File Browser
    + [Mc] fix imdb background search
    + [Mc] vp add default directory DeviceList and allowed DeviceList lastdir
    + [Mc] pp DeviceList you add default
    + [Mc] ap DeviceList you add default
    + [Mc] added option to remove MC main menu entries! Have a look at Settings -> Global Settings ....
    + [Mc] readd myvideo old apple trailer pys
    + [Ufs912] USB WiFi Support
    + [Ipbox] add terrestrial and cable xml
    + [At7500] add terrestrial.xml
    - http://www.megaupload.com/?d=M5KKF5J0
    01 Nov 2008
    Default Aaf
    Cum se instaleaza?....Cu KCC 3.2 nu reusesc.
    01 Nov 2008
    Default Aaf
    cu multipart installer 2.1 merge
    La mine multipart installer 2.1 nu imi vede/recunoaste stick-ul usb , deci cu acest soft nu pot instala nimic ( BA, Imagine )
    Am incercat un "mixaj" in schimb intre kcc si multipart installer , cu kcc am partitionat/instalat BA 6.1 pe stick si cu multipart am instalat imaginea asta
    Totul este ok cu acest soft la instalarea imaginii ( multipart ) , insa practic cand am dat sa booteze dupa aceasta imagine 1-ma oara a ramas pe "Load AAF Summer......."
    Am gasit si versiunea de kcc a acestei imaginii ( link-ul de mai jos ) si tot asa instalez imaginea aceasta cu kcc-ul
    La 1-ma bootare , ma intreaba/afiseaza pe afisajul receptorului : Use DHCP ? ( ca apesi pe butonul OK sau nu trece mai departe ) si ramane pe AAF Wizard si mai mult de 7/8 minute fara sa se intample/afiseze ceva
    Deci ce este gresit sau care ar fii pasii mai exact cu multipart ?
    - http://www.megaupload.com/?d=OR6LOQ14
    01 Nov 2008
    Default Aaf
    Am instalat imaginea dupa diverse incercari cu MP 2.1:
    -partitionare sick cu CreateMini_1.1
    -Connect
    -Mini-Uboot
    -Install Mini U-boot(exista in setul MP 2.1)
    -click dreapta :install image
    Viitoarea imagine RSP STM24, merge instalata si pe vechiul sistem foarte bine.
    Oricum o sa dezvolt topicul cu MAXIBOOT, sa trecem toti. Mai fac ceva teste !
    09 Jan 2010
    I had big problems with AAF image, not stable. Wont load properly.
