Results 31 to 45 of 65
Thread: Probleme rescriere imagine Spark
    RSP Enigma Team
    28 Aug 2009
    Departe
    Am incercat sa instalez E2 folosind procedura descrisa (Emergency boot, sageata). Mi-a aparut "Load" pe display si acolo a ramas, pe TV nu a mai afisat nimic.
    Dupa vreo 10 min. am repornit din buton, dar acum apare de display "boot" si apoi "Load", si acolo ramane.
    Emergency boot nu mai functioneaza deloc, nu mai reactioneaza la nici o tasta apasata.
    Am incercat deja cu un stick re-formatat, cu spark_rescue_image, nici o reactie.
    Ce as mai putea face?
    Daca nu trece ceasu pe cronometru direct ... e OK. Se rezolva sigur.
    31 Oct 2007
    Upgrade Spark by TFTP
    Since we have some restrictions and can not support all ki$$$ of USB stick, we
    provide another option (TFTP) to upgrade Enigma2/Spark.
    Preparation:
    1. Install TFTP tools [csicotftp11.rar] to your PC
    2. Set your PC IP addr to [192.168.40.19]
    3. connect your PC to STB by LAN, now we only support LAN, do not support WLAN
    4. Set default booting system to [spark]
    Upgrade Step:
    1. copy [mImage] and [userfsub.img] to any folder of your PC, for example [C:/spark]
    3. Keep Pressing [OK] Button in Front Panel, then power on STB.
    4. After 5 seco$$$ you will see [Forc] in LED, release [OK] button and press [Right]
    Button.
    5. if everything OK, You will see [T LD] shining in LED and you will see some debug
    information in TFTP Server, like
    “ Mon Oct 25 14:02:36 2010: Sending 'mImage' file to 192.168.40.19 in binary mode
    Mon Oct 25 14:02:39 2010: Successful.
    Mon Oct 25 14:02:50 2010: Sending 'userfsub.img' file to 192.168.40.19 in binary
    mode
    Mon Oct 25 14:03:33 2010: Successful.”
    6. if upgrade success, You will see [SUCC] and STB reboot automatically
    If upgrade not finishes in 5 minutes, then there must be something wrong, please
    check your configuration and re-try.
    RSP Enigma Team
    28 Aug 2009
    Departe
    Thanks for the instructions, but unfortunately they don't apply in my case. No matter how long I keep the OK button pressed, I never get to the Emergency boot. It doesn't recognize the pressing of the OK button anymore.
    RSP Enigma Team
    28 Aug 2009
    Departe
    Ajutat de Zildan, am ajuns si la procedura de recuperare boot pe RS232. Am mai gasit-o descrisa si intr-un post de MihaiP (http://sateliti.info/showthread.php?...e-boot-corrupt) si in ghidul oficial "SPARK7111 Upgrade Guide" (2010-10-25).
    Fara succes. Nu booteaza si ignora butonul OK tinut apasat. Am transferat u-boot.bin, in HyperTerminal raporteaza transferul OK, dar Alien zice tot "Bad magic number". La pornire, asta vad in terminal:
    U-Boot 1.3.1 (Mar 16 2011 - 11:42:45) - stm23_0043 - YW 1.0.019 Rel P1
    DRAM:  128 MiB
    NOR:     8 MiB
    NAND:  512 MiB
    In:    serial
    Out:   serial
    Err:   serial
    IdentID : 09 00 0a 00 00 4b b0
    Hit ESC to stop autoboot:  0
    Loading from NAND 512MiB 3,3V 8-bit, offset 0x18000000
     ** Bad Magic Number 0xffffffff **
    ## Booting image at 80000000 ...
    Bad Magic Number
    ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps...
    ...aici transfer u-boot.bin, si apare:
    CCxyzModem - CRC mode, 2(SOH)/384(STX)/0(CAN) packets, 4 retries
    ## Total Size      = 0x00060000 = 393216 Bytes
    Bad Magic Number
    CCCCCCCCCC
    Am incercat de foarte multe ori, tot la fel. Doar numarul de retries se modifica - si nu inteleg oricum de ce are retries. Cablul serial eu zic ca e bun, e cumparat din magazin, nu facut.
    Uite si pasii de upgrade care au adus receptorul in starea asta, daca cineva are curaj sa experimenteze:
    - Pus pe stick, in radacina, cele 2 fisiere Enigma. Prima greseala, ca trebuiau puse intr-un subdirector. Nu ca ar fi vreun readme, ceva, cu instructiuni.
    - Din Spark (functional, updatat), power off/on.
    - Tinut apasat OK si pornit emergency boot.
    - Selectat cu sageata jos "Enigma". A doua greseala, trebuia sageata dreapta, pt. update.
    - Acum sunt fericitul posesor al unei caramizi de 100 euro.
    Ca sa continui discutia cu Stargate din alt thread:
    eu vorbesc din experienta mea, de exemplu in perioada cand incercam sa adaptez pluginul la Alien ii faceam praff bootargs de 4-5 ori intr-o zi si trebuia sa reinstalez uneori si Spark si E2 de tot atatea ori si asta mai multe zile la rand de imi era si mie teama ca o sa crape flash-ul intr-o zi
    Stargate, e clar ca ai foarte multa experienta si cunostinte in domeniu - de invidiat si respectat, mai ales ca le folosesti si ca sa-i ajuti pe altii. Dar tocmai din experienta asta nu mai apuci tu sa faci greselile stupide pe care le facem noi, incepatorii
    incearca sa instalezi enigma2 sau spark fara cablul serial conectat la receptor
    Nu am cum sa instalez cat timp nu pot ajunge in meniul de boot.
    eu am avut un asemenea incident cand degeaba tineam apasat OK ca nu trecea in boot de urgenta si nu puteam sa-i dau comanda sa treaca la scriere imagine ... pur si simplu trecea mai departe si ramanea blocat in LOAD pe afisaj si dupa ce am scos cablul din receptor a fost ok
    Situatia pare intr-adevar similara, am scos toat cablurile, am reconectat apoi numai serialul, dar tot nimic.
    Oricum, multumesc pentru ca incerci sa ajuti. Daca vrei si ai cum, incearca si tu procedura "mea" de upgrade, sa vedem daca e o eroare generala sau e numai norocul meu. Sau, daca te intereseaza, pot sa-ti dau acces cu teamviewer.
    23 Apr 2007
    P3X-888
    In seara asta nu am cum sa te ajut ... dar lasa-mi o adresa de mess in PM si maine o sa te contactez sa mai incercam ceva ... trebuie sa reusim , din ce vad din log de la tine si din ce am mai patit si eu tot testand diferite lucruri pe Alien pare o formatare gresita a flashului .
    RSP Enigma Team
    28 Aug 2009
    Departe
    In lipsa de altceva ce sa mai incerc, am zis sa verific cum sunt conectati pinii la cablul serial, si mi-a dat ceva ciudat. Maparea este:
    1 1
    2 5 + 9
    3 4
    4 3
    5 2
    6 - (neconectact)
    7 8
    8 7
    9 2
    Uitandu-ma la http://www.lammertbies.nl/comm/info/...ull_modem.html, vad o cu totul alta mapare. Are idee cineva ce tip de cablu serial e asta, si daca e potrivit pt recovery la Alien? Daca nu, o sa incerc sa-l tai si sa remapez pinii, asa cum sunt descrisi la link-ul de mai sus (ca la ora asta n-am de unde cumpara un alt cablu serial).
    Asta trebuie sa fie :
    RSP Enigma Team
    28 Aug 2009
    Departe
    Sigur nu asta am. Cablul nici macar nu e simetric.
    Si totusi cu acelasi cablu am salvat un Kathy in trecut, iar la Alien vedem totusi ce se intampla la boot, iar fisierul este transmis la Alien, care raporteaza ca a primit cei 384K.
    In fine, o sa caut un alt cablu si revin cu detalii, dar s-ar putea sa dureze o zi sau doua. Pacat, mi-ar fi placut sa pot testa noua imagine RSP.
    23 Apr 2007
    P3X-888
    Ar fi ideal sa gasesti un cablu testat sa putem fi siguri de el , trebuie sa gasim o rezolvare .
    叛徒 daradici's Avatar
    12 Apr 2008
    覆盆子灌木
    Lightbulb
    Daca ai nevoie de cablul nullmodem, eu dupa schema asta folosesc, facut din cablu UTP.
    Se gasesc in comert cabluri de 3m, aproape la orice magazin de tehnica de calcul.
    Eu a trebuit sa-l construiesc din cauza lungimii neconventianal de mari (aprox 25M !!!).
    RSP Enigma Team
    28 Aug 2009
    Departe
    Iaca am gasit la un prieten un cablu verificat, si-a refacut un DM800 cu el. Surpriza, este fix aceeasi cablare ca si la cablul pe care il am deja. Am fost sambata pe la cateva magazine de calculatoare pe aici, nu mai tine nimeni cabluri seriale. Nici pe net sa comand nu prea gasesc.
    Oricum, am 2 cabluri care au mers sigur cu Kathy si respectiv DM800. Doar la Alien nu merg. Logic, eu cred ca buba e la Alien totusi.
    Dar o sa mai caut nenorocitul asta de cablu serial, desi la momentul asta asa imi vine sa-l trimit inapoi in garantie, ca batem pasul pe log degeaba.
    Si multumiri din inima celui care s-a gandit ca un "factory reset" nu este util.
    ---------- Post added at 18:53 ---------- Previous post was at 17:24 ----------
    Am taiat unul din cablurile pe care le am si am facut cablul recomandat de Zildan (2-3, 3-2, 5-5). Nu merge deloc, in Putty nu vad nimic venind pe seriala.
    OK, si daca totusi nu cablul e problema, ce alte optiuni mai sunt? Ce s-ar mai putea face?
    08 Jan 2011
    SPACE
    Eu zic sa il lasi vreo 24 de ore scos din priza si fara cablu satelit si dupa sa incerci cu spark rescue cu stick-ul.
    RSP Enigma Team
    28 Aug 2009
    Departe
    OK, cu ce anume difera daca e scos din priza 5 sau 24 de ore? Exista vreo explicatie fizica/logica?
    Dupa cum am spus mai sus, cablul satelit a fost scos deja. Iar stick-ul i-l bag degea, daca nu ajunge la emergency boot.
    08 Jan 2011
    SPACE
    Nu stiu explicatia dar am patit cu un opticum la fel ramasese blocat cand upgradam un sw .
    L-am lasat o zii si dupa a mers fara probleme .
    La probleme anormale solutii anormale.
