Thanks Thanks:  101
Likes Likes:  210
Dislikes Dislikes:  1
Page 60 of 63 FirstFirst ... 10505657585960616263 LastLast
Results 886 to 900 of 940
Thread: Digi TV...
  1. #886
    23 Apr 2008
    Bucharest West
    Nu l-am formatat, am trecut direct la copiere underworld (corect, este ver 2.30) peste firmware anterior (stealth)
    atunci poti sa i pui cruce, nu ai urmat procedura..
    daca ai drum prin B, da un semn si incerc sa ti le fac..
    Vu+Zero4K, Offset Motor 1m
  2. #887
    25 Jan 2011
    Default Digi TV...
    am intrebat p forumuri
    nu e timebomb
    in elvetia functioneaza inca
  3. #888
    11 Apr 2010
    Da, nimai ca noi suntem mai tari ca eletienii, avem 4 CAID-uri din care 3 sunt nagra.
    Posibil ca numai 2 sa fie tunelete catre emulatorul intern.
    Asta ar fi interesant de intrebat pe cineva care a lucrat la soft.
    Acolo cate CAID-ulri sunt?
  4. #889
    25 Jan 2011
    2 caiduri daca bine am inteles
    Care camuri mai merg?oricare unicam sau trex? Si care se pot edita cu CAS?
    Mersi
  5. #890
    Pana nu “ascund” 4K -ul e bine sa nu iei nimic.
    Vedem după.
  6. #891
    Mda, 4 CAID-uri !
    2018/12/11 13:35:58 7007AC8D c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1801 ECM_PID: 1583 PROVID: 000000
    2018/12/11 13:35:58 7007AC8D c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 1880 ECM_PID: 15B5 PROVID: 000000
    2018/12/11 13:35:58 7007AC8D c   (dvbapi) Demuxer 0 ecmpid 2 CAID: 06BB ECM_PID: 1AFB PROVID: 000000
    2018/12/11 13:35:58 7007AC8D c   (dvbapi) Demuxer 0 ecmpid 3 CAID: 1874 ECM_PID: 1B2D PROVID: 000000
  7. #892
    15 Feb 2007
    Două nagravision și două irdeto?
  8. #893
    Default Digi TV...
    1874 pare tot neagra, deci 3 neagra și un ird.
  9. #894
    15 Feb 2007
    tier	1802	002111	000000000000F639	00000000	2018-11-01	2019-04-02
    tier	1802	002111	0000000000000040	00000000	2016-11-05	2019-04-02
    tier	1802	002111	0000000000000083	00000000	2018-11-01	2019-04-02
    tier	1802	002111	000000000000121A	00000000	2018-11-01	2019-04-02
    tier	1802	002111	0000000000000067	00000000	2016-11-05	2019-04-02
    tier	1802	002111	0000000000000065	00000000	2016-11-05	2019-04-02
    tier	1802	002111	0000000000002488	00000000	1992-01-01	2019-04-02
    Imi apare ceva nou la pachete? Ce pachet este ultimul?
  10. #895
    30 May 2015
    Cine ma poate ajuta in buc sa scriu un t-rex supermodule ?
  11. #896
    19 Oct 2015
    Daca ai CAS3 e usor.. are tutorial in aplicatia lor Duolabs destul de explicit..
    Poate nu e necesar sa modifici softul si ai noroc sa poti introduce din telecomanda numerele lotto dorite..
  12. #897
    30 May 2015
    am rezolvat multumesc frumos, aveti idee unicam delta crypt merg folosite pe gigi tv la momentul actual sau sunt afectate precum diablo light ?
  13. #898
    45 Post(s)
    Quote Originally Posted by djcostyro View Post
    da unicam deltacrypt si trex functioneaza
  14. #899
    25 Jan 2011
    salut
    ceva nou cu dracu?
    Sent from my SM-G965F using Tapatalk
  15. #900
    30 May 2015
    salutare tututor am nevoie sa scriu un t-rex supermodule 4.6 in bucuresti (numai functioneaza programatorul) caut un coleg care poate sa ma ajute
