Thanks Thanks:  10
Likes Likes:  5
Results 16 to 30 of 40
Thread: Amiko Alien 2
    01 Sep 2010
    Andromeda
    Plugin Amiko Alien 2
    Download Link 1 Link 2
    14 Nov 2010
    Nu se aude nimic despre acest receptor... Softul cu care vine este acceptabil? Cum se comporta in share?
    Ma intereseaza pentru ca cu vechiul Alien sunt foarte multumit.
    08 Jan 2011
    SPACE
    Receptorul este fain dar vad ca oscam imi intrerupe dupa 10 sec si asa ramane si tre restart si iarasi aceiasi poveste.
    Mai trebuie sa cautam la setari.
    01 Sep 2010
    Andromeda
    MaximusFBI - Din ce stiu eu sunt probleme legate de emu pe Spark. Din niste discutii facute cu cineva am inteles ca partea de 'emu' nu e prioritara pentru Fulan. Sunt ambele receptoare vizate: Amiko Alien 1 si 2! Chipurile...nu e definitiv cu emu...ca e posbil sa se mai 'umble' pe acolo. Dupa parerea mea nu sunt seriosi, dovada stau: actualizarile, lipsa satelitilor,etc!
    P.S: Ai putea incerca sa instalezi Enigma 2 pe Amiko Alien 2.
    Enigma 2 PKT Nebula for Amiko Alien 2:
    - update pngquant version 1.1
    - [p191] clear all buffers on demux error
    - Fix SCART output for stx7111 chips
    - [E2] fix for largefile Support
    - [player2_191] reset TSM when tsm is in idle mode
    - update jfsutils version 1.1.15
    - update libungif version 4.1.4
    - [e2proc] adding more compatibility for 3dmode
    - [player_191] ufs910 fix ca recording bug (camrouting)
    - [e2proc] new entry hdmi/output allowing switchin output on off by proc
    - fix ffmpeg patch
    - add vfd scrolling to hs7810a
    - [autofs] update to version 4.1.4 supporting ghost mode
    - [stmfb_102] fix hdmi hotplug error
    - Add dual frontends for ADB_BOX
    - [palyer191] add pcm delay support
    - [HS7110] optimize st-merger
    - update busybox 1.20.2
    - update ffmpeg 0.11.1
    - [starci] rework module detection handling
    - [ufs9xx_cic] rework module detection handling
    - [cimax] rework module detection handling
    ---> Nv3 changes
    - fix spark7162 driver by DboxOldie
    - [libeplayer3] fix free memleak on flv streams (myvideo)
    - [tuxtxt] fix transparent mode
    - cleanup ci/ca dev creation handling
    - fix spark7162 SIG and SNR dvb-s or dvb-t by dboxoldie
    Added by PKT:
    [ALL] refresh channel list without restart GUI
    [ALL] add support oscam as card server
    [ALL] add startup to standby function in BP->System->Standby Tools
    [ALL] add new Infocenter screen
    [ALL] EPG recovery fix
    [ALL] NIM selection adjust for 3 positions
    [ALL] added support for mini VFD in progress
    [GM7162] mini VFD configuration data for startup
    [gm7162] main loop:
    + clear vfd in deepstandby
    + support vfd & led settings in standby
    + fix extinguishing
    [ALL] fix lightUp
    [GM7162] added FP plugin settings support
    [ALL] Graph MultiEPG - added searching of picons on /hdd/picon
    [GM7162] set the turn off power led when starts from deep standby
    [ALL] KeyMapper extensions for red & yellow key
    [ALL] fix NES on startup when LNB not connected
    [ALL] fix preserve spaces in text of startup from standby mode
    [ALL] fix possibility of NES in startup of radio channel
    [GM7162] fix setting power led in TV mode
    [ALL] fix GS in instant record sometimes appears if TIMER conflicts
    [ALL] added subtitles support to Media Player - TXT files with time stamp & frame stamp.
    [ALL] MediaPlayer added SRT txt format , added txt speed regulation up/down key, and many more changes.
    [ALL] MediaPlayer: added in srt files detection uft8 format and other fixes
    [ALL] MediaPlayer:
    + fix playlist playing
    + fix FPS detection
    + fix text delay
    + added adjustment of text speed
    + fix text startup synchro
    [ALL] AudioSelection screen fix - sometimes on 1st start of AudioSelection, the screen contained only empty lines.
    [E2] remove SimpleBitrate
    [ALL] added new skin PKT Red-HD
    [ALL] added EPG key support for MultiEPG
    [ALL] SD skin replace by PKT_BasicHD
    [ALL] set default skin to PKTRedHD
    [ALL] update WebInterface v1.7.1
    [GM7162] Volume +/- key functionality fix
    [SF918G+/SF1008SE+] fix time set in deep standby mode
    [GM7162] added 3rd tuner detection
    [ALL] force reboot for 7162 ( also 990 & ipboxes but not tested )
    [ALL] added paths list preserve for RecPaths
    [UFS910] remove SU2 fix
    [ALL] added oscam logs info in InfoCenter - required disabled authorization to http and access to local host
    [ALL] Add HDMI CEC on/off, default OFF, work only with SF1028/SF1008+/SF918+/UFS912
    [ADB] fix twin-tuner
    [UFS912] add support for mtd5 - now all flash space is using
    [ALL] fix missing lib for grab
    [ADB] Add BSKA fan support
    [ALL] fix TTX
    ---> Nv3 changes
    [ALL] fix for channels list picons located on external media like /hdd , /usb
    [ALL] SecondEvent in channel list speedup
    [9900] Boot Setup - fix exit key
    [gm7162] added REC support on VFD
    [ADB] add support STV090x tuner
    [GM7162] fix power led off after boot from deepstadby
    [ALL] fix GS if timezone not selected
    [ADB] fix cec
    [ALL] fix mount /hdd for recording
    [ADB] Add autodetect boxtype
    [ADB] Fix BXZB support
    [ALL] Info Center: added info for /movie folder if device is different then mounted to /hdd
    [ALL] fix utf8 characters in cifs
    [ADB] add BZZB support
    [ALL] Add converter *.pyc to *.pyo
    [GM7162] fix display "9" and "+" on vfd
    [ALL] added manual time shift for deepstandby if not match - file: /var/config/time.corr
    [ALL] added Permanent TimeShift - default : disabled (BP->System) test mode
    [ADB] fix avs error
    [ADB] add support CA1 tda8004
    [ALL] YouTube players remover from BP menu
    [ALL] InfoCenter - Oscam logs in new windows
    [ALL] InfoCenter - added USB drive model information
    [ALL] new method for CAM starting
    [BP] added picons for 13E & Astra19E
    [ALL] EMU Manager 1.1.3: added switches: Map CA and autorestart CAM
    [ALL] improve stability
    Nota bene:
    FTP login: root, passwd: pkteam
    oscam -> boxtype ipbox
    mgcamd -> boxtype 11
    known issues:
    - second tuner DVB-S2 not working
    - signal strength not working
    Download
    ---------- Post added at 08:27 ---------- Previous post was at 08:02 ----------
    HRnigma II for Amiko Alien2
    Some observations after the 48-hour test.
    For now runs faster and better than Aliena1.
    Faster response remote-channel, ddsubtitle player works superbly, Emulators (oscam and mgcamd) work very well (oscam accelerated in comparison to A1, mgcamd works superbly).
    Configuration Tuner (3 pieces) is very simple, tuner sensitivity surprisingly good, better than the A1.
    DVB-Terrestrial tuner is so good that scans 14 channels with an ordinary piece of wire, without antenna.
    The signal at the clock. channels displayed in true scale, hd channels work perfectly, all packages are available (depending on the line).
    Download
    Pentru un moderator: ar fi bine sa fie mutata discutia aici
    http://sateliti.info/showthread.php?...-Amiko-Alien-2!
    23 Apr 2007
    P3X-888
    Mutat si facut stiky
    01 Sep 2010
    Andromeda
    PKT Nebula 3 pentru Amiko Alien 2!
    Login: root
    Password: pkteam
    Download
    10 Nov 2012
    http://sourceforge.net/projects/hdmusti7162/files/HDMU_1337_E2_spark7162_211_git_4875_nodebug_nolcd_Diff0_ffm_Flash.zip/download
    CHANGELOG
    HDMU_1337_E2_spark7162_211_git_4875_nodebug_nolcd_ Diff0_ffm_Flash
    Sat Nov 10 03:55:25 2012 +0100: change to diff0, in futher use diff 0 not diff3
    Sat Nov 10 03:52:18 2012 +0100: fix step2
    Sat Nov 10 03:28:07 2012 +0100: fix
    Sat Nov 10 02:58:25 2012 +0100: update some files in patch path
    A aparut versiunea noua de Alien2 + cu tunner DVB T2.
    Pentru cei care nu stiu, tunnerul terestru/cabu la ALIEN2 necesita restart, adica e ori de cablu ori terestru.
    Nu e capat de tara dar e bine sa se stie clar cum functioneaza.
    Ma joc de ieri cu un aparat din asta si revin spunand ca a evoluat foarte mult SPARK (softul).
    Standard RSP member bogdan007's Avatar
    25 May 2010
    N V
    Pentru Novoce tv nu stie nimeni parola?
    31 Dec 2008
    Smile lista canale
    Ma poate ajuta cineva cu o lista de canale pentru cablu tv, de la rcs-rds, scanata cu Alien 2!
    Vreau sa o pun in rec cu dreamboxedit ...al meu nu vrea sa scaneze decat o frecventa!
    Merci!
    26 Dec 2011
    Agen
    Default Gm Triplex
    De cateva zile ma joc cu GM Triplex; mare, bine ventilat; presupun ca merge identic cu fratele lui, Alien 2 cu trei tunere; am facut initial un reader intern (oscam 1.10)cu \sci0, care mergea la slotul de sus, OK. Am mai adaugat un reader intern, cu \sci1; surpriza: slotul de jos (readerul al doilea) merge OK, primul reader insa nu mai merge (nici cu restart, reboot), nu poate citi cardul! Oare Oscam nu poate utiliza doua readere interne simultan?
    Minitastatura de la Alien e compatibila 100% (desi in soft lipseste folderul keyboard prezent la Alien1, care poate asigura suport pt. russian, arabic, etc); compatibil orice dispozitiv WiFi ce merge la Alien1 (ieri am testat un microUSB WiFi adaptor Silvercrest luat de la Lidl cu 30 RON, care merge super!).
    Din pacate renuntasem de mult la cablul TV, astfel incat am putut testa si tunerul al treilea (va trebui sa ma deplasez la cineva cu cablu).
    26 Dec 2011
    Agen
    Rezolvată problema cu cele 2 readere; merg amandouă, cu frecvenţa card 5 MHz (primul, care nu mergea era pe 3,57). Alt lucru interesant: cu versiumea .61 de Spark a activat un card Pocus nou doar cu CAM-ul inclus (fără nici un softcam activ); am ratat proba pe Alien1 la inceputul lunii (dacă face şi el AU fără Oscam), voi proba luna viitoare.
    31 Dec 2008
    Verifica te rog ,daca sub enigma2 poti scana canalele de pe cablu tv...*cs-*ds!
    La mine nu vrea sa scaneze decat o frecventa!
    26 Dec 2011
    Agen
    Dacă ai versiunea cu tuner T2 şi nu T (la GM triplex sunt ambele, nu ştiu la Alien2 cum e; eu am cel cu T2 de ex.), nu are suport incă in E2 (şi din păcate dezvoltatorii E2 pt Alien2 au in ţările lor standard DVB T şi nu T2 la televiziunea terestră); poate versiunile ulterioare. Asta ar fi cauza difuncţionalităţii şi pe DVB C.
    Standard RSP member 72THX's Avatar
    25 Jun 2010
    Satu' cu ministri
    Ai dreptate ce spui tu tunerul T2 este o gaselnita pentru viitor. Se pare ca vor sa treaca transmisia terestra de la T la T2 nu stiu de ce sau pentru ce.
    Am citit undeva de chestia asta ca altfel nu luam nici eu.
    Dar problema mare este ca dezvoltatorii enigma nu fac si pentru dvb-c/T2 ce trebuie.
    Din cate am vazut SPARK si Enigma au la baza linux ( sper sa nu spun prostii) dar crezi ca nu se putea copia ( sau inspita) cei de la E2 din Spark.
    Nu fura Guvernul uraste competitia
    Amiko Alien2 Triple Plus
