Cam repede a venit upadetul asta 2.4.1
Vad ca merge si tapatalk HDD pe samsung galaxii S3
Sent from my GT-I9300 using Tapatalk HD
un radio online si nu numai! l-am folosit mult timp pe windows mobile, nu au avut versiune pt android pina de curind...
mai bun decit TuneIn Radio in ceea ce priveste bufferingul, la online radio sau Shoutcast, lucru important pentru cei ce asculta in masina.
https://play.google.com/store/apps/details?id=com.kinoma.kinomaplay
bafta
DishPointer Pro.2.2.1.apk full
https://www.dropbox.com/s/5ygsdwh19n...0Pro.2.2.1.apk
salut
caut un app pentru inbunatatirea calitatii audio pentru casti, atat pentru muzica cat si pentru convorbiri...ceva gen "beats audio", dar ceva mai eficient..
cine foloseste sau a folosit asa ceva... sa posteze
bafta
Frumuşel programelul
Phone Tester
Test the capabilities of your phoneThis app allows you to test the correct operation of many parts of your device (phone or tablet). You can test the following:
- Device's sensors: accelerometer, gyroscope, compass...
- Wifi: internal & external IP, gateway, DHCP server...
- Telephony: signal, network type, external IP...
- GPS: satellites, latitude, longitude, speed...
- Battery: health, level of charge...
- Multitouch screen: how many fingers recognize your device?(not available in Android 1.6)
Also displays system information about hardware and software like RAM, kernel version, screen...
Pro version displays more information (CPU speed, phone memory, sd card memory) and removes the adds.
Bsplayer pro are cineva ?
---------- Post added at 17:54 ---------- Previous post was at 17:23 ----------
BSPlayer v1.6.146 - crkd -
Noozxoide EIZO-rewire™ PRO e postat mai sus, ▼ SETUP AS DEFAULT FILTER (reboot when necessary)
Settings > Sound > Music Effects > Choose “Noozxoide EIZO-rewire™ PRO Series” as root !
ar mai fi si Voodoo Sound insa eu nu prea m-am impacat cu el...
[UPDATE] XBMC "Frodo" -- Android with PVR
pentru acces stream din alta retea decat cea locala se aloca port in router(atentie la planul de internet 3G)
<iconpath>/storage/extSdCard/ /picon/icon_files.png (exemplu)
testul a fost efectuat cu receiver Azbox HD E2, XBMC build 13alpha pe Note2 JB_4.1.2, local wifi, picons cele de E2, se pot edita grupuri favorite: digi, sky..., terestru, etc
skin: xbmc Aeon Nox
supliment: Vu+/Enigma2 Client
Download:
Nightly(development--13 alpha) builds: http://mirrors.xbmc.org/nightlies/android/
Official stable builds(Android):http://xbmc.org/download/
legat de customizare cu picons pentru aplicatia Android Oscam Monitor se pot introduce aceleasi picons ca cele din E2 redenumite din forma initiala: 1_0_1_DAC_C_1_E082E7C_0_0_0.png in 1802_0DAC.pn (ex:boomerang_1802)
toate aceste picons se copiaza in Android in /sdcard/OscamMonitor/logos/...
Uploaded with ImageShack.us
cateva .pn logos pentru android pe pachetele nemtesti aici:
Code:http://www.streamboard.tv/wbb2/thread.php?threadid=30923&threadview=0&hilight=+pn+logos&hilightuser=0&page=31
Azbox HD with OpenSPA 3.0 powered by OSCam
UE46F8000 powered by SamyGO_OSCam
NFC Task Launcher
Pe langa transferul de date sau efectuarea de plati prin tehnologia NFC se pot rula si profile task personalizate de catre utilizator ce controleaza aplicatiile sau functiile smartphonului.
Pentru asta avem nevoie de un device compatibil NFC si stickere NFC programabile(la noi, nfstags se gasesc la suma de 12-15ron/buc in functie de memoria alocata).
exemple: http://nfctags.tagstand.com/#nfc-kits
Exista mai multe moduri pentru a automatiza un smartphone Android. Un instrument foarte util bazat pe NFC este NFC Task Launcher, care ne permite sa cumparam stickere NFC, sa scriem/executam/programam comenzi pentru tag (prin dispozitivul Android). Cu aceasta aplicatie / tag-ul programat, poti face lucruri cum ar fi:
- Activeaza si dezactiveaza servicii bazate pe locatie
- Rulati o aplicație de muzica sau navigator atunci cand asezati telefonul intr-o statie de andocare in masina
- Setati telefonul pentru modul "inactiv" cand scanati o ''etichetă de noapte'' din dormitor
- Permite oaspetilor sa se conecteze automat la internet Wi-Fi prin scanarea tag-ului
- Punerea in aplicare a unei politici de silent a telefonului pentru intalniri sau birou
- Configurarea automata tethering
- Instalati plugin-uri pentru SMS și apeluri telefonice
- Activeaza si dezactiveaza AllShare Cast
Sistemul suporta urmatoarele servicii:
- Turn Wifi on or off
- Turn Bluetooth on or off
- Make Bluetooth Discoverable
- Turn Airplane mode on or off (root required in 4.2+)
- Launch any installed Application
- Configure a new Wifi connection and connect
- Configure and enable Portable Hotspot
- Turn Auto-sync on or off
- Turn Auto-rotation on or off
- Turn Notificaiton light on or off
- Set Display brightness and auto-brightness
- Launch any Tasker Task (for users of Tasker)
- Chang Ringtone
- Change Notification Tone
- Changing Ringer Mode (Normal/Silent/Vibrate)
- Changing Ringer Volume
- Changing Media Volume
- Changing Alarm Volume
- Changing Notification Volume
- Set vibration
- Set Alarm (both a fixed time and as a timer)
- Check in with Google Latitude, Foursquare, Facebook and Google Places
- Send a tweet on Twitter directly from the tag
- Start / Stop media playback
- Turn GPS on or off (root Required)
- Turn Mobile Data on or off (root required)
- Changing Display Timeout
- Changing Auto-Rotation
- Changing Notification Light
la dispozitia dumneavoastra intr-o alta locatie
http://www.multiupload.nl/T95VPAJBLT
Vu+ Player is an Android app designed to allow you to control and stream from your Vu+ satellite receivers, either from the same network as the receiver, or from a remote location. Although designed for the Vu+ range of receivers, it should work with any satellite receiver compatible with Enigma2. There are three main purposes for this app:
1) As a substitute remote control while viewing your TV. If you do not like equipment on display, your receiver can be placed out of site (and IR remote range) and this app used to control it. You can change channels, look up EPG-information, set timers, send messages, use its virtual Remote Control etc.
2) A means of watching your satellite receiver on a portable Android-device at home. If you have a receiver with two or more tuners, then you can even stream an alternative channel and watch a different channel to the one displayed on the connected TV.
On selected receivers, such as the Vu+ Solo2, you can enable the transcoding function. This will enable streaming on an alternate port with the ability to watch HD channels with reduced bit rate. This function is experimental and still under development.
3) A remote viewer. If you have a very good upload speed from home and download speed from your current location, you can watch the stream from your satellite receiver remotely. The app can work from anywhere in the world where you can get a good WiFi/Mobile connection. All you need is a dynamic DNS address at home, e.g. DynDNS and forward ports on your router. Possible scenarios are airport lounges, coffee shops, hotels, etc. Receivers supporting transcoding, such as Vu+ Solo2, can enable this function and take advantage of this since lower upload speed is required in this mode.
Features:
- Internal video-player with OSD (On Screen Display). No need to download and install external video-player although many others are supported.
- Multiple connection profiles. All receivers on your network can be added
- Browse the EPG and individual channels
- Manage timers (add, edit, delete) either from EPG or manually. This can be done even when away from home
- Search EPG
- Grab screenshots from live TV
- Manage recordings
- Send on-screen messages
- Satellite signal strength meter for dish alignment and adjustment
- Integrated help
Pentru setari a se vedea Help/Instructions
