Thanks Thanks:  12
Likes Likes:  12
Page 1 of 5 12345 LastLast
Results 1 to 15 of 65
Thread: Vu+ Solo2
    29 Nov 2008
    Cu capu' in nori
    Default Vu+ Solo2
    SOLO BCM7356
    HD Satellite SoC with Ethernet MII and PHY Capabilities for Home Networking
    The Broadcom BCM7356 is a single-chip, multi-format HD satellite STB solution featuring integrated Ethernet MII and PHY capabilities for connectivity with Broadcom's Wi-Fi and powerline solutions that enable service providers to deploy multi-room DVR while reducing cost and power requirements. The BCM7356 allows multiple users to store, time shift or access content from media servers or residential gateways for playback on STBs anywhere in the home, driving the transition to a more connected and interactive home network environment that also reduces the power, complexity and overall cost for the solution provider.
    FEATURES:
    • Support for multiple worldwide formats including the DVB-S2, DVB-S and 8PSK standards, with backwards compatibility to the DVB-S standard
    • High performance and cost effective DDR3-based memory providing significant cost and energy savings over DDR2-based memory
    • 3D graphics engine for an advanced user interface
    • Dynamic power management controllers that provide a very power efficient ecosystem, capable of shutting down unused system components in real-time
    • Support for the Digital Living Network Alliance (DLNA®) Interoperability Guidelines to facilitate the easy sharing of digital content between DLNA-enabled devices, allowing a seamless experience for sharing and enjoying digital media and content services throughout the home
    • Support for the Multimedia Home Platform (MHP), the Adobe Flash® Platform for TV and the RVU Alliance's pixel accurate Remote User Interface (RUI) technology that allows an identical user experience on multiple devices
    • A broad array of time-to-market web-based connected home STB software applications environments including Adobe Flash® Platform for TV, Webkit HMTL 5.0, Java, Nokia's Qt Framework including QtWebkit, DLNA 1.5, and DirectFB application libraries
    • Unique HD FastRTV™ channel change acceleration technology that improves channel change speeds by up to 500 percent
    • Support for Energy Star® and European Code of Conduct compliant
    29 Nov 2008
    Cu capu' in nori
    Vu+ Solo II
    Attached Files Attached Files
    29 Nov 2008
    Cu capu' in nori
    ---------- Post added at 22:33 ---------- Previous post was at 22:17 ----------
    29 Nov 2008
    Cu capu' in nori
    De pe forumul BlackHole :
    Vu solo2 is coming in the next2 months.
    Black Hole support is ready !!
    The performances of Vu+ Solo2 are AWESOME !!
    E2 starts in 3 seconds !!
    We are already working for you
    VU+ Solo² Full HD Twin DVB-S2 Linux HDTV PVR
    Digitaler Satelliten-Empfangsreceiver für HD TV- und Radioprogramme.
    Hauptmerkmal ist der 1300 MHz starke Prozessor der VU+ Solo². Erleben Sie HighDefinition TV mit Ihrem VU+ Solo².
    • Transcoding Funktion
    • Airplay Funktion
    • Opera Browser
    • HbbTV
    • HDMI 1.4 Anschluss
    • HD PIP
    • Gigabit Lan
    • Plug&Play Halterung für 2,5" SATA – Festplatten
    • 12 stelliges VFD Display
    • Externes 12 V Netzteil
    Technische Highlights:
    o 1300 MHz Mips Prozessor
    o 256MB Flash
    o 1GB DDR3 DRAM
    o Gigabit Lan
    o 1 x DVB Common-Interface Einschub
    o 2 x Smartcard-Reader (Xcrypt)
    o 3 x USB(1x Front, 2 x Rückseite)
    o SPDIF Audio Ausgang optisch (digital)
    o 1 x HDMI 1.4 Video/Audio Ausgang (digital)
    o 1 x Scart (TV)
    o 1 x Video Ausgang RCA
    o 2 x Audio Ausgang (L/R) RCA (analog)
    o Plug&Play Halterung für 2,5" SATA – Festplatten
    o unlimitierte Kanalliste für TV/Radio
    o EPG (electronic program guide) Unterstützung
    o Unterstützung von Bouquet-Listen
    o OSD in vielen Sprachen und Skin-Unterstützung
    o automatischer /manueller Kanalsuchlauf
    o DiSEqC 1.0/1.1/1.2, USALS
    o Externes 12 Volt Netzteil
    o Netzschalter
    VU+ Solo² Technische Daten:
    DVB-S2 Tuner:
    Eingangsfrequenzbereich 950...2150 MHz
    Eingangspegelbereich - 65 dBm...- 25 dBm
    Tuner Eingang F-Buchse
    Eingangsimpedanz 75 Ohm
    AFC-Fangbereich +/- 3,5 MHz
    Demodulation QPSK und 8PSK
    FEC Viterbi und Reed-Solomon
    Viterbiraten 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
    Roll-off Factor 35 %
    Common-Interface:
    Common-Interface Stromverbrauch max. 0,35A/5V
    Videodekodierung:
    Videokompression MPEG-2 / H.264 und MPEG-1 kompatibel
    Videostandard PAL G/ 25 Hz, NTSC
    Bildformat 4:3 / 16:9
    Letterbox für 4:3 TV-Geräte
    Ausgang Digital:
    Ausgangspegel 0,5 Vss an 75 Ohm
    Abtastfrequenzen 32 kHz, 44.1 kHz, 48 kHz
    S/PDIF-Ausgang optisch, coaxial (AC3)
    Audiokodierung:
    Audiokompression MPEG-1 & MPEG-2 Layer I und II, MP3
    Abtastfrequenzen 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
    Ausgang Analog:
    Ausgangspegel L/R 0,5 Vss an 600 Ohm
    THD > 60 dB (1 kHz)
    Übersprechen < -65 dB
    Video-Parameter:
    Eingangspegel FBAS 1 Vss +/- 0.25 dB an 75 Ohm
    TV-Scart:
    Ausgang: FBAS, RGB, über OSD wählbar
    Ethernet:
    1000/100/10 MBit kompatibles Interface
    USB:
    USB 2.0 Anschluss (3x)
    LNB Stromversorgung DVB-S2 Tuner:
    LNB Strom 400mA max. , kurzschlussfest
    LNB Spannung horizontal “ohne Last 19,5V“17,6V bei 400mA
    LNB Spannung vertikal “ohne Last 14,5V “ 11,8V bei 400mA
    LNB wird im Standby-Modus abgeschaltet
    Steuerung der Satellitenpositionen:
    DiSEqC 1.0/1.1/1.2 und USALS - Rotor Steuerung
    Leistungsaufnahme:
    < 13W (im Betrieb, mit LNB)
    < 12W (im Betrieb, ohne LNB)
    < 0,5W (Deep-Standby-Mode)
    Eingangsspannung:
    Externes Netzteil:
    Eingang:
    110-240V AC / 50-60Hz / 1,0A
    Ausgang:
    12V = / 3,5A
    Allgemeines:
    Umgebungstemperatur +15°C...+35°C
    Luftfeuchtigkeit < 80%
    Abmessungen (B x T x H): 280 mm x 200 mm x 50 mm
    Gewicht: 2,0 kg ohne HDD
    Q:VTi-Board
    pret de vanzare 329 € oficial precio la ielektroniks.com
    succes la achizitie tuturora
    29 Nov 2008
    Cu capu' in nori
    Standard RSP member dingo31's Avatar
    Default vu solo 2
    abia astept sa pun mana pe el, dar probabil pe la sfarsitul lui ianuarie. vu solo a fost primul meu receiver linux. bravo marusys, la naiba cu dreambox si cu pretzurile lor si cu gulerele lor albe - rest in peace dreambox!
    THE KING IS DEAD, LONG LIVE THE KING!
    vu uno si vu solo sunt cele mai tari receivere !
    incepand cu ziua de luni 16.12.2012 se va incepe livrarea de receptoare satelit VU+SOLO2 de catre unele magazine online din europa
    pentru acei care au facut precomanda
    15 Nov 2007
    pe mine ma intereseaza daca stie bluray 3d iso.
    daca la testat cineva il rog sa posteze.
    Default vu solo 2
    l-a cumparat cineva? cum se misca?
    29 Nov 2008
    Cu capu' in nori
    Am facut precomanda, dar nu a ajuns in Ro inca.
