Thanks Thanks:  1
Likes Likes:  1
Results 1 to 4 of 4
Thread: DM 800 SE activare smartcard-reader !
    15 Feb 2007
    Default DM 800 SE activare smartcard-reader !
    Cum se activeaza cele doua smartcard-readere de la DM800SE, ma intereseaza o configuratie pentru reader 1 card DIGI, folosesc sbox acum, pentru reader 2 vreau sa folosesc un card de Focus !
    [slot0]
    active=1 # 0=inactive 1=active
    sci=/dev/sci0 # lower
    ncdserver=1 # 0=newcamd server off 1=newcamd server on
    deskey=0102030405060708091011121314 # newcamd deskey
    port=10000 # newcamd port
    mhz=368 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
    reader=1 # 0=phoenix, 1=sci (internal reader), 2=smartreader
    cache=5 # how many ecms can be cached, 0 or less=cache disabled
    #Nagra2/3 Example
    [AAAAAAAA] # nagra2 camid (4 bytes)
    rsa= # rsa "n" from this card (like newcs)
    boxkey= # boxkey from this card
    emm=0 # 0=accept all 1=block emms 2=block emmu 4=block emmg
    portlist=1 # use portlist or no
    portlistpath=/usr/keys/port.list # path from port.list
    #controlsid=0:0 # X:Y X=max sids allowed at same time, Y=seconds needed to allow new sid
    [slot1]
    sci=/dev/sci1 # higher
    port=11000 # newcamd port
    mhz=357 # Mhz for card in this reader, DON'T WORK ON PHOENIX INTERFACE. Example: mhz=357, mhz=368
    #Conax Example
    [CCCCCCCC] # conax camid (4 bytes)
    portlistpath=/usr/keys/portFocus.list # path from port.list
    Vezi ca la clonele cu sim2 sloturile sunt parca invers,slot0 e sus si slot1 e jos.La al tau tu stii.
    25 Sep 2008
    bucale
    Interesanta combinatie. Functioneza bine receptorul fiindca ma bate gandul sa trec si eu la o configuratue similara.
    antena triax td110 pe
    16 E +19 E
    38 Post(s)
    Super! Sa ne spui si noua daca functioneaza ok!
