Thanks Thanks:  11
Likes Likes:  4
Results 16 to 30 of 44
Thread: PKT e2
    14 Jun 2013
    Default PKT e2
    Multumesc
    Am depistat, necesar setarea in configurare tuner , se selecteaza avansat cu toate setarile de lnb universal ,disq 1.2 si inregistrarea indexului corespunzator tabel pozitie satelit in axa geo, si nu activare pozitioner goto x
    Apoi in configurare pozitioner cu alegerea transporder manual sau predefinit si cu corectie fina si memorare pozitie pe indexul de satelit adus este ok ,functioneaza, timpul de miscare este mai mare dar se poate regla
    07 May 2009
    Timisoara
    "E2 OpenSource SH4 Duckbox Project GIT-4767 PKT SVN-2060 HYPERION Image"
    Ma ajuta cineva cu un tutorial pentru instalarea pkt-hyperion pe un UFS910 ?
    Kathy, DM500, SS2, Humi, kaon, si cine le mai stie...
    Standard RSP member samuell's Avatar
    23 Sep 2010
    caransebes.CS-ghencea
    mege perfect pe 8900 un singur ecran verde la pluginul livescore today matches...in rest e ok.nu maintereseaza you tube si alte prostii
    FORZZA STEAUA,FORZZA MILAN....FORZZA LUPII GALBENI,,,FUCK THE SISTEM
    23 Sep 2010
    iMAGINEA ACEASTA CE EMULATOR FOLOSESTE PT CRIPTO,BISS,,SPORTDIGITAL...MGCAMD SAU......?
    13 Mar 2007
    Cluj
    Default Stie wireless
    Imaginea aceasta stie wireless?
    PKT GM 990 & GM Spark Reloaded E2 HYPERION V3 IMAGE 02/XI/2013
    PKT SVN-2595 HYPERION v3 Image
    SH4 Duckbox Project GIT-5557
    MIPS OpenPLI GIT-11190
    Added by PKT:
    [ALL SH4] add 6xPOWER = force reboot
    [MIPS] add SWAP support (default off)
    [arm] add djmount
    [ALL] update channel list
    [MIPS] start wizard fixes
    [ALL] EmuManager fix GS if CAM removed;
    [HyperCube] set recording path to /hdd/movie
    [MIPS] IMDb visibility added to plugin browser
    [LX] set default yellow as Plugin browser
    [LX] fix vfd info in movie player
    [MIPS] fix restart CCcam with GUI restart
    [MIPS] fix Aspect Selection
    [MIPS] added Infobar show on EXIT key pressed
    [LX] keymap - added aspect ratio switch to PLUGIN key
    [LX] fix Audio Selection
    [LX] fix a/v video mode
    [all] update backup manager translation
    [HC * IPBox] BootSetup and Install Manager fixes
    [ALL] Emu Manager - fix for to long name of Cam file
    [MIPS] fix info play reminding on front panel in Media Player
    [ARM] fix EPG saving/loading
    [sh4] fix start script file every restart GUI
    [MIPS] VideoWizard fix, default setting changes, fix of FPanel channel number displaying
    [mips] add support for samba setup manager
    [ALL] fix GS if streaming
    [gm990] added PORTAL key to keymap
    [ALL] Log raport
    [mips] fix autorestore if is usb or hdd
    [ALL] DLNA added ARM & MIPSEL support
    [MIPS] InfoCenter code optimization
    [MIPS] added CCCam info to InfoBar;
    [MIPS] add dvb-t firmware
    [mips] Media Player - better functionality changes
    [mips] Media Player color keys functionality
    [ALL] ScreenSaver smooth fading
    [ALL] EMUmanager add support CCcamd
    [mips] + crossepg
    [mips] deppstandby plugin fix, dump mem at awaking
    [MIPS] VM settings, save epg on standby, reference.dat ...
    [mips] timeshift fix & others
    [ALL] picons update
    [mips] fix infobar/eventview show/hide
    [mips] pig resized
    [IP9k] add BootPlus
    [ADB] add RC_Select plugin for RAW/CUT/XMP remote control select
    [ALL] fix transponder info
    [ALL] fix aio-grab
    [ALL] PKT skins - added channel name in nr zap
    [ALL] added: auto switch to standby if restarted in standby mode
    [ALL] added picons path selection in skin setup : default, hdd, usb, enigma. So if you do not want to awake your hdd, just choose usb or enigma and enjoy
    [GM990,GM7162] improved remote control sensitivity
    [ALL] Channel Control - german lang by @Data devil
    [ALL] PKT SKINS - All rights reserver. Skin is integral part of PKTeam image and is not allowed to modify and use it without permission of the author.
    [ALL] added StartUp to standby in DeepStandby plugin
    [ALL] added PIG in movie selection ( SilverHD & RedHD skin )
    [ALL] MediaPlayer fixes, added external txt/srt file support, other small addons
    [7162] AGC fix
    [all] fix sleep hard disk - based on data devil solution
    [ALL] OC Tool - modified fast boot.
    [7162] OC Tool - added 720MHz to fast boot
    [ALL] Speed Tool - GUI changes, added Polish translation
    [ALL] added to EPG key support for Cool TV Guide
    [ALL] fixed stopping countdown for deep standby if awake + other small changes for triplex
    [ALL] removed containers usage in bitrate info for smoother operation
    [ALL] Deep Standby fix
    [99xx] Fan Control fix
    [7162] VFD icon fix
    [ALL] no swap needed if crossepg not in use
    [ALL] added saving EPG data file on standby
    [ALL] changed virtual memory management
    [ALL] add switching between eplayer/gstreamer BP>Settings>ExtraSetup>MediaFramework (experimental)
    [ALL] EMUmanager fix gs when cam is incorrect
    [ALL] InfoCenter - added partition filesystem info
    [ALL] GS in awaiking from standby fix - getoutput issue.
    [ALL] extended cache writeback delay
    [ALL] EMUmanager- fix emu counter
    [ALL] increased efficiency of swap file
    [ALL] added clean up memory function in BP
    [ALL] swap usage less aggressive. Pressure on RAM, and if insufficient then swapping.
    [ALL] other smaller code changes
    [ALL] sync front panel clock display in standby fix
    [arm] add autorestore for arm based on sh4
    [ALL] fix value OC on sti7100 and sti7109
    [IPBOX99X] - added new patches for frontend driver to increase stability
    [ALL] many stability fixes no included in changelog
    Known Issues:
    [ADB] PIG can cause unexpected uboot remove due to error decoder design - as written by Jacek, so we can not guarantee 100% secure
    Special THX to TDT, OpenPLI, all sh4 community and all betatesters.
    Extra THX goto data devil
    FTP login: root, passwd: pkteam
    DOWNLOAD:
    PKT_GM990_E2_HYPERION_v3_NAND FALSH IMAGE
    http://www.sendspace.com/file/5ge1ae
    PKT_GM990_E2_HYPERION_v3_USB
    http://www.sendspace.com/file/p77j9c
    03 Aug 2011
    why all images excepr ar-p there is alot of C-band frequency give no signal while same frequency i test in dm800 se working f9 like pas 7/10 68.5 duniya new 4006 v 2990 // 4003 v 7200 8psk 3/4 4117 v 3333 2/3 all hv no signal evern spark original spark firmware works fine with these frequencies only problem in enigma2 image any help
    07 Sep 2008
    Buna
    Am instalat acum cvreo 3 saptamini pe un Amiko Alien2 Triple Plus o imagine E2 pkt Hyperion svn 3089 based on GIT 5767 . Exceptand faptul ca pe cablu a trebuit sa scanez manual fiecare frecventa pe care sunt programe deoarece scanarea intregii retele dadea eroare, imaginea functiona ok, nici o problema pe jiji si nici pe satelit in sharing. In date de 1 martie am mai instalat un cccam server si alte cateva pluginuri si am introdus citeva linii de test pentru sharing. Am observant ca aveam problem pe sharing, nu mai decoda ( cu oscam ) si dupa aceea nici pe cablu ( cu mgcamd) nu mai decoda digitv, hbo, etc ( cele codate ). Am verificat pe imaginea spark si decodarea merge fara problem. Nu am reusit sa aflu cauza, asa ca am reinstalat imaginea , keyle si pluginurile, dar aceiasi problema. Observ ca in EMU manager, in parte de jos in momentul cind e active mgcamd, afiseaza si date despre criptare ( system, kaid, provider, pkey, cw0, cw1 ) ca si cind decodarea e ok, dar degeaba.
    Am banuit ca e o ghidusie a jijeilor, dar dupa cum am mai spus pe spark totul e ok. are cineva vreo idee care e cauza /
    Multumesc
    Pune oscamemu ca sa nu mai ai probleme pe cablu si pe sat merge f bine daca il configurezi!
    07 Sep 2008
    in emu am si oscam il activam cind intram pe satelit ( care merge acum ok cu linii de sharing). Pe cablu nu-mi merge, foloseam mgcamd, am citit pe forumuri ca e recomandat pe Alien cind folosesti E2. Poti sa-mi spui ce setari mai trebuie sa fac ca sa folosesc oscam si pentru cablu ? Multumesc.
    07 Sep 2008
    Multumesc mult de tot. Am rezolvat, totul e functional De curiozitate, au mai modificat jijeii ceva de nu mai receptiona prin mgcamd ?
    17 Nov 2008
    ALBA
    A reusit cineva sa ruleze cron ? cronmanager
    E foarte simplu, dai in telnet comanda:
    crontab -e
    Poate sa se planga ca nu exista un anumit fisier, in creezi cu
    touch .....
    eventual crezi si director daca nu exista, normal doar editezi si salvezi.
    Apoi editezi fila respectiva.
    Nu ai nevoie de plugins etc pt asta.
    17 Nov 2008
    ALBA
    pot asa sa rulez acest script ?
    */1 * * * * /usr/script/oscamcheck.sh
    ai cuma te rog acest script oscamcheck.sh sa fie comanda oscam in /var/emu/oscam daca modific ceva in script nu mai ruleaza not found
    Nu il am dar pot sa il scriu, tu povestesti ce probleme ai si facem.
    In crontab poti aduga scripturi care ruleaza la ore fixe sau la intervale.
    Quote Originally Posted by cipryDXfeed
    editezi cu ceva care strica formatul fisierului.
