Thanks Thanks:  190
Likes Likes:  128
Dislikes Dislikes:  5
Page 1 of 56 123451151 ... LastLast
Results 1 to 15 of 832
    Default Amiko Mini HD Combo Old & SE
    Cel mai accesibil receptor combo apare curand in gama Amiko la vanzare.
    MAIN FEATURES:
    One Conax Embedded card reader
    6000 channels (TV and Radio) programmable
    External IR Sensor (Included in the package)
    Mountable on TV (Sticker included in the package)
    Two High Speed USB 2.0 Connections
    Ethernet Connection & USB WiFi Support (Ralink RT5370 chip only)
    YouTube videos
    RSS Reader & Weather Forecast Functions (Ethernet or WiFi connection required)
    DiSEqC 1.0, 1.1, 1.2 and USALS Compatible
    Full HD (1080p) Output via HDMI
    Channel Recording to External Storage Devices
    Timeshift support
    Channel Recording & Timeshifting Simulteniously (optional)
    Channel switching time less than 1 second
    True-color, User Friendly On-Screen Display (OSD)
    Full Picture In Graphic (PIG) function
    Electronic Program Guide (EPG) for on screen channel information
    Subtitle supported
    Teletext supported by VBI insertion and software emulation
    Parental lock facility by channel and program event
    Program and Channel information transfer from receiver to receiver
    Exciting games embedded
    Multi-Language support
    Power Consumption in Stand-By: <0.5W
    TECHNICAL SPECIFICATIONS:
    Tuner & Demodulation
    Tuner Type: DVB-S / DVB-S2
    Input Connector: F-type, Connector, Female
    Loop Through: F-type, Connector, Female
    Signal Level: -65 to -25 dBm
    LNB Power & Polarization: Vertical: +13V/+14V,
    Horizontal: +18V/+19V
    Current: Max. 300mA
    Overload Protection
    22KHz Tone Frequency: 22±1KHz
    DiSEqC Control: Version 1.0, 1.1, 1.2, USALS
    Demodulation: QPSK, 8PSK
    Input Symbol Rate: 2-45 Mbps,
    FEC: 1/2, 2/3, 3/4, 5/6, 7/8 and Auto
    Tuner Type: DVB-T2 / DVB-C
    Frequency Range: 48~862MHz
    RF Input Level: -80dBm to -20dBm
    Antenna power output: DC 5V at max 75mA, Overload protection
    Demodulation: COFDM 1K, 2K, 4K, 8K normal and extended, 16K normal and extended, 32K normal and extended
    Input Symbol Rate: 1.0 ~ 7.0Ms/s
    Constellations: QPSK, 16QAM, 64QAM, 256QAM / Both rotated and non-rotated
    Guard Intervals: 1/4, 19/256, 1/8, 19/128, 1/16, 1/32, 1/128
    Code Rate: 1/2, 3/5, 2/3, 3/4, 5/6
    System Resources
    Main Processor: 400MHz based CPU
    Flash Memory: 64MBits
    DDR RAM: 1024Mbits
    MPEG TS A/V Decoding
    Transport Stream: MPEG-2, H.264
    Input Rate: Max.120Mbit/s
    Aspect Radio: 4:3, 16:9, Letter Box
    Video Decoding: MPEG-2, MP@ML, MPEG-4 part 10/H264
    Video Resolution: 720*480P/I, 720*576P/I, 1280*720p, 1920*1080i, 1920*1080p
    Audio Decoding: MPEG-1 layer I/II, MPEG-2 layer II, Dolby digital
    Audio Mode: Left / Right / Stereo/ Mono
    Sampling Rate: 32, 44.1 and 48KHz
    Power Supply
    Input Voltage: 12V DC
    Power Consumption: 18W Max
    Stand-By Power Consumption: <0.5W
    A/V & Data Input/Output
    RCA A/V: (Jack Type) Video CVBS output, Audio L/R output
    RS-232C: (Jack Type) Transfer rate 115.2Kbps, 9 pin D-sub Type
    USB: One USB 2.0 slot
    HDMI: VER1.3, Type A
    Ethernet: 10M RJ45
    IR Port: Jack Type
    S/PDIF: Optical for Digital Audio or Dolby Digital output
    Physical Specifications
    Size[W*H*D]: 144mm*40mm*110mm
    Net Weight: 0.5KG
    Operation Temperature: 0°C~+45°C
    Storage Temperature: -10°C~+70°C
    Storage Humidity: 5%~95% RH (Non-Condensing)
    konstantine's Avatar
    O explicatie pe intelesul tuturor: System Resources
    Main Processor: 400MHz based CPU (ALI 3612)
    http://www.matisse.net/bitcalc/?inpu...otation=legacy
    Flash Memory: 8 Megabytes
    DDR RAM: 128 Megabytes
    Asta ca sa nu se tepuiasca si altii.
    A aparut deja la vanzare.
    Luni comand unul!
    In cateva zile aveti informatii!
    25 Nov 2013
    chiar is curios si eu cum se comporta
    Standard RSP member wilee's Avatar
    25 Feb 2009
    Terra
    Fratele geaman al sau, Amiko mini hd SE ( doar ca nu are al doi-lea tuner) se comporta foarte bine . Il am in teste de 1 luna si sunt foarte multumit de el . Rivalizeaza in proportie de 95% cu DM 800 hd care este foarte scump . Nu s-a blocat niciodata, iar pe canale hd full 1080p/ i merge ca uns. Felicitari AMIKO. Ultimul soft este 1.0.33 conax / emu .
    23 Jun 2008
    Poate fi server de oscam ?
    A sosit aparatul.
    E construit special pentru a putea fi montat pe spatele televizorului sau unde e loc.
    Senzorul telecomenzii se monteaza undeva in fata televizorului.
    Cablul HDMI e scurt special .
    Interfata HD (meniurile) seamana cu cea de la AMIKO 8000.
    Am scanat cablu (DVB-C) si a mers din prima, scaneaza plecand de pe 306 Mhz, cu NIT.
    Vine cu soft multicas, fara emu (key sau share).
    Am facut update cu AMIKO_MiniHD_Combo_1.1.50_emu.zip si au aparut meniurile interesante pentru cablu si satelit!
    Dupa ceva balbaieli am reusit sa testez emu pe cablu si am constatat ca merge foarte bine.
    HH si scanarea pe satelit functioneaza.
    Deschide foarte bine si stabil pe "linii".
    Client stie cam tot ce exista (suporta 7 linii), server e doar HomeCamd versiunile 1, 2 si 3.
    Pe partea de NetMedia stie WebTV si Youtube, pe care l-am si testat.
    Google Maps apare si el in meniul de internet dar nu a auzit de Romania.
    Pana acum sunt placut surprins de aparat.
    Nu am gasit un media player si nu sunt obisnuit cu lista de canale .
    Dupa mai multe teste revin cu noi impresii.
    27 Sep 2007
    Deci isi merita toti banii !!! Maine il am si eu...dar asteptam cu totii de la tine, Zildan, noua RSP E2 pentru Alien1&2.
    23 Jun 2008
    Poti defini liste de favorite cu canale satelit si cablu la un loc?
    Trateaza cablul ca pe un satelit. Poti avea lista comuna.
    Dupa cateva ore de teste:
    - uneori mai sare randuri la subtitrare pe Digi cablu (destul de rar)
    + apasarea tastei ALBE direct pe imagine restarteaza liniile
    + Info > Info > Rosu > Rosu, te duce in meniul de kei, cred ca poti sa bagi BISS
    - dupa ce am scris 5 linii cu hsdata.cfg, nu mai pot sa intru in Internet > NetConfig, cere parola si nu e buna 00000000
    - Pg + si PG- nu schimba canalele
    - pe 28E nu am vazut lumina!
    - sacadeaza pe transponderul cu Digi Sport 1 HD HU de pe Thor (poate nu e antena pe care fac teste foarte buna)
    + are player media doar USB
    Testam!
    PS:
    Am instalt si in Bucuresti un sistem de compilat imagini.
    In noaptea asta se compileaza prima de Alien2.
    Nu am reusit sa aflu parola de la :
    "MainMenu", "Internet", "Net Config"
    se povesteste pe net ca ar fi 00000000 da nu merge nici daca dai reset to default!
    Cea mai mare lipsa constatata pana la ora asta e lipsa unui client Samba sau DLNA pentru media player.
    Telecomada merge foarte bine ca semnal, e cam zgomotoasa la apasare .
    27 Sep 2007
    Prima impresie la aparitia receptorului este data de dimensiunile reduse ale acestuia. Telecomanda pare imensa in comparatie cu aparatul si "pocneste" la apasarea tastelor din jurul butonului ok dar are raza mare de actiune. Dupa adaugarea celei de a doua linii, nu mai exista acces la submeniul Net Config dar daca il lasi oprit de la inceput nu mai ai nevoie de parola. Pe cablu merge struna iar pe satelit, din cat am testat, se comporta la fel de bine, inclusiv la comanda monturii h-h. Sensibilitate destul de buna a tunerului pe satelit, am reusit receptia stabila a canalelor nordice in hd de pe Thor( Canal More HD , etc...). Cu subtitrarea pe stick, am reusit sa sincronizez cu un film de pe un canal satelit. Pg Up si Pg Dw schimba doar in lista de canale, YouTube nu e pus la punct...si telecomanda se potriveste de minune si la Alien 2, invers nu.
    Alinen 1 si 2 au suport pentru 5 telecomenzi !
    O sa testez si eu asta
