Thanks Thanks:  192
Likes Likes:  132
Dislikes Dislikes:  2
Page 19 of 25 FirstFirst ... 9151617181920212223 ... LastLast
Results 271 to 285 of 367
Thread: Amiko HD 8260+
  1. #271
    konstantine's Avatar
    RsP_MoD_Amiko_8260_piccollo_3in1_2.3.03
    - NETMEDIA: SUPER WEB TV LIST ! ! ! Youtube ! ! ! Youporn ! ! ! BR.TV ! ! ! EZ IPTV ! ! ! DLNA ! ! ! GLOBAL IPTV ! ! ! YELLOW IPTV ! ! !
    - UPDATE WEB TV LIST (everyday new channels) :
      Application
      WEB tv
      press red button (Load from URL)
      press red button again
      press LOAD
      see the new WEB TV LIST
    RsP_MoD_Amiko_8260_piccollo_3in1_2.3.11
    - NETMEDIA: SUPER WEB TV LIST ! ! ! Youtube ! ! ! FIX Youporn ! ! ! DLNA ! ! ! STALKER IPTV ! ! ! EZ IPTV ! ! ! DLNA ! ! ! GLOBAL IPTV ! ! ! YELLOW IPTV ! ! !
      Application
      WEB tv
      press LOAD
    -    3E: DIGEA, ERT
    -    9E: Ant1Europe, Monitor games, FREE TO AIR SD & HD channels
    -   13E: SRG Swiss, Mezzo
    - 19,2E: FREE TO AIR SD & HD channels
    - 28,2E: FREE TO AIR SD & HD channels
    -   39Ĺ: Bulsat
    - 27,5W: BBC all channels
    In versiunea " ALI3516_14000A00_galaxy_combo_220_ps_starlight_1CA_1CI_2.4.35 " rușii au implementat SAMBA.In rest ,aceleași plusuri și minusuri.
    What's new:
    Added: Samba Client
    Updated: Improving CI CAM + modules
    Fixed: Screen format change when working with DVB-T2 TV Guide
    Fixed: Kino-live, the main server is attached to the mirror
    Fixed: Application Import E2 database, audio track correction tracks
    Fixed: Tube 8
    E client samba?
  5. #275
    E client dar nu am facut teste.
    Asteptam asta de peste 5 ani la ALI!
    Ar trebui sa iti vada filmele sherizate de pe windows.
  7. #277
    Imi trebuie un dump de amiko8260+ extras cu unul dintre utilitarele de aici.
    Merci anticipat !
    Quote Originally Posted by intros View Post
    Asa am facut cum ai spus,dar vreau si OSD-ul in RO si suportul in firmware. Am intrat pe pagina lor din olanda si le-am cerut RO in firmware. Le-am spus ca am un sab titan fara RO. Asta-i tot!
    Ai primit raspuns? Daca nu ai primit , iti spun eu : o sa mai mearga softurile de sab titan 3 pe amiko 8260+ , cand o zbura porcu'.Vorba lui MihaiP : "mai binele , e dusmanul binelui"
    17 Feb 2017
    Salut,
    Nu am primit raspuns,probabil ca ei nu inteleg limba romana, o limba de succes de altfel pe unde te plimbi prin afara...
  10. #280
    A testat careva versiunea 2.4.22 ?S-a rezolvat subtitle character set select?
    06 Nov 2015
    Si "2.4.22" restarteaza la zappare satelit - cablu. Revenit la Sab Titan (pacat ca nu are macar posibilitatea alegerii limbii romane, macar la subtitrare)
  12. #282
    Am pus unui prieten
    AMIKO_HD8260_Galaxy_2.4.40_by Dekolte
    si merge ok.
  13. #283
    28 Dec 2015
    Germany
    Quote Originally Posted by rrzxxx View Post
    Confirm problema cu restartarea nu doar la zappare ci si asa din senin. Am revenit la 2.3.65, care are probleme cu update-ul la EPG, in rest stabil. 2.4.22 mergea bine EPG-ul, dar daca se restarteaza ... plus vesnica problema de freezing
  14. #284
    Am mai descoperit un receptor pe acceasi platforma cu Amiko 8260+ :Icecrypt STC3220CCIHD
    04 Jun 2007
    @intros
    daca te ajuta pot sa-ti dau un id de skype al celui care se ocupa de partea de soft /dezvoltare a receptoarelor sab (sper sa mai lucreze la ei) , omul e turc (si toti angajatii lor sint turci) fata de mine a fost foarte serios si binevoitor .
