Thanks Thanks:  192
Likes Likes:  132
Dislikes Dislikes:  2
Page 9 of 25 FirstFirst ... 567891011121319 ... LastLast
Results 121 to 135 of 367
Thread: Amiko HD 8260+
  1. #121
    konstantine's Avatar
    Pentru cine vrea sa testeze un sw. Edision adaptat pt.Amiko 8260+.
    Fixes: rezolvata maparea tastelor page up,page down.
    In modul radio,la apasarea tastei exit se dezactiveaza wallpaperul.
    Tasta power de pe telecomanda,actioneaza doar oprirea receptorului.
    Pornirea se face de pe panoul frontal.
    AMIKO_HD8260_Edision_2.2.15
    Am gasit ceva interesant pt. sw. de Edison adaptat pt Amiko 8260+ :
    "ONLINE UPDATE WEB TV LIST (everyday new channels) :
    - MENU from Remote Control
    - Application
    - WEB tv
    - 0000
    - press red button (Load from URL)
    - press red button again
    - press LOAD
    - see the new WEB TV LIST up to 150 channels "
    Testat,functioneaza.
    Update sw 8260+
    Fixes:network id scan modification,emulator hs_265,auto update web tv list from url.
    Not fixed:still do macros on povu channels,eastern european coding for subtitle,missing hdmi CEC,
    missing DLNA,key maping page up/down on channel list.
    AMIKO_HD8260_2.2.18_mcas
    AMIKO_HD8260_2.2.18_emu
    25 Mar 2013
    Ai link-uit fw pt 8270?
  5. #125
    Era scris gresit.Linkul duce la 8260+
    Apropo de asta: Amiko 8250,8260,8270 au aceeasi placa de baza, plus sau minus tunerele s2/t2/c.
    Softul e "universal" pt Amiko 8250,8260,8270
    http://sendvid.com/m3evpqvf
    Ultima versiune(2.2.18) e mult mai slaba si plina de buguri.Unul dintre cele mai grave,
    e ca tasta search de pe telecomanda nu e mapata(cu tasta search se incarca hsdata.cfg).
    Nu-l recomand.
    Default plugin de test pt amiko 8260+
    Un plugin de test (10 zile)pt amiko 8260(merge pe toate amiko):
    Prima data faceti backup la hsdata.cfg
    Activare:Meniu,acces conditionat,ip share,net client config,tasta alba
    de pe telecomanda,se selecteaza xcamd active(server 1,2,sau 3,oricare dintre ele)
    si se introduce codul de activare 9999888.Receptorul se restarteaza automat
    dupa introducerea codului.
    Nu pastreaza sortarea listelor si a favoritelor.
  9. #129
    Am scris la postul #104 cum se procedeza ca sa fie interschimbabile listele de canale.
    Uitandu-ma prim maincode de la versiunea 2.2.30 pt. amiko8260,
    am descoperit ca lipsesc cu desavarsire o serie de codecuri,
    inclusiv DX5(DIVX5).Softurile in loc sa corecteze lipsuri,adauga...
    Si un "hint" pt. activarea youporn pe sw. rusesti:meniu,sistem,
    control parental,0000,youporn,pornit sau oprit.
    AMIKO_HD8260_2.2.21_emu "original", nu rusesc.
    E o versiune test(beta).Nu vad nicio schimbare.Are aceleasi buguri.
    AMIKO_HD8260_Galaxy_2.2.19 cu grafica si logo,identice cu sw. original.
    Vad ca a aparut si versiunea 2.2.25.In afara de faptul ca merg vid. hd pe youtube,
    nu observ nicio modificare.Din contra,la net config,se restarteaza receptorul dupa introducerea parolei.
    Accesul in meniul ipshare se face de pe tasta albastru a telecomenzii.
    07 Nov 2015
    E o versiune veche(AMIKO_HD8260_2.2.06_emu),are un buchet de canale scanate pt.sky uk si vreo 3 sateliti adaugati in lista.Poti sa-l incerci,dar vei fi dezamagit...
    Incepand de azi si pana va apare un software decent,am pus la cutie amiko8260+
    si am revenit la amiko8240,care functioneaza impecabil in comparatie cu 8260+.
    Amiko8260+ e un receptor cu potential dar sw. e "facut pe genunchi",la repezeala...
