Thanks Thanks:  192
Likes Likes:  132
Dislikes Dislikes:  2
Page 17 of 25 FirstFirst ... 7131415161718192021 ... LastLast
Results 241 to 255 of 367
Thread: Amiko HD 8260+
  1. #241
    Sw. "nou" STARTRACK-SRT-400HD adaptat pt. amiko 8250/60/70 RSP_MOD_ALI3516_14000A00_startrack_locus01_ps_starlight_1CA_1CI_2.3.76
    Versiune EMU.
    Youtube ok , autoconnect wi-fi ok , afiseaza doar primul rand al subtitrarii in mediaplayer.Fara "adult" in aplicatii.
    Branduit RSP si new bootlogo amiko.
    RsP_MoD_Amiko_8260_piccollo_3in1_2.2.83
    Varianta Conax fara functii "speciale".
    Codul"special" pentru sw. SabTitan2 este 1117(meniu-aplicatii-1117)
    Iar pentru cele de StarTrack 6666 si 777.
    Exemplu: meniu-instalare-6666 ascunde/arată meniul de cautare cablu.Meniu-acces conditionat-7777 arata/ascunde emu.
    Thanks to vulpea pt. codurile de StarTrack.
    RSP_MOD_1400A00_piccollo_3in1_PLUS_CI_2286
    - NETMEDIA: SUPER WEB TV LIST ! ! ! Youtube ! ! ! Youporn ! ! ! EZ IPTV ! ! ! GLOBAL IPTV ! ! ! YELLOW IPTV ! ! !
    - UPDATE WEB TV LIST (everyday new channels) :
      Application
      WEB tv
      press red button (Load from URL)
      press red button again
      press LOAD
      see the new WEB TV LIST
    SAB Titan III sw. pt. Amiko 8250/60/70
    ALI3516_14000A00_RSP_locus01_ps_starlight_1CA_1CI_2.4.20
    NEW !!!Support Stalker IPTV server.
    Youtube and youporn ok.Added Rakstar IPTV ,Xtream Codes IPTV .
    1- Please make an account from Xtream Codes IPTV server.
    2- You need to choose m3u with option for playlist type.
    3- Stream type will be mpegts.
    4- Xtream IPTV server will make an account like this: http://test.no-ip.net:8000/get.php?username=USER&password=PASS&type=m3u_plus&output=mpegts
    5- You will put this URL into eziptv server.txt file.
    6- If you want, you can change also server name.
    7- Please copy eziptv server.txt file to USB.
    8- Insert USB stick to SAB Titan receiver.
    9- Go to menu-application-IPTV-blue button
    10- Press OK button on the IPTV server.
    11- SAB Titan receiver will download IPTV playlist.
    12- You can press Left-Right buttons for group switch. RED button has also same option.
    13- If you press Blue button during Satellite channel watching than you will get IPTV channels or IPTV Server menu.
    14- If you press White button on the IPTV Server (Active Server) than this server will be actif.
    If you press Blue button during Satellite channel watching than you will get this IPTV channels. You will not see IPTV Server menu.
    15- If you want to get back IPTV Server menu than you need to press 9999 during IPTV watching.
    16- You can add up to 10 IPTV servers.
    Standard RSP member Member
    07 Jul 2007
    amiko_14000A00_galaxy_2.4.15_gisclub
    What's new , is inside of the box...
  7. #247
    Exclamation Atentie !
    Va rog sa retineti ca nicodata ,nu am /voi modifica data de compilare a softului pentru receptoarele cu SOC ALi.(Latest Update)
    E lipsa de etica si ilegal pe deasupra.
    PS: Nu va sfatuiesc sa puneti pe receptoare softuri noi modificate de....autori cunoscuti (nu dau niciun nume)
    Exista riscul sa nu mai puteti face downgrade , nici pe cablu (RS232) din cauza bootloaderului.
    17 Feb 2017
    Default Firmware
    Asteptam cu interes noutati pt 8260+, care sa merite sa fie "flashuite", si sa nu "bricuim" receptorul!
    Mersi!
  9. #249
    AMIKO_HD8260_2.4.11_conax
    AMIKO_HD8260_2.4.11_mcas
    AMIKO_HD8260_2.4.11_emu
    Release notes for 2.4.11:
    - Removed WiFi auto connect setting from the menu
    - Set WiFi auto connect to ON by factory default
    - Added Finnish OSD language
    To fix : subtitle character set select.
    17 Feb 2017
    Cateva obs dupa 1 zi de testat 2.4.11 emu :
    1. Nu mai functioneaza tasta PAGE de pe telecomanda(nu schimba canalele)
    2. WebTV-ul nu functioneaza corect: orice fisier Webtv list.txt nu-l recunoaste si da Warning(da, am respectat UTF8, si Channel list: ABC http://aaa.../a.ts, si chiar cu variante gen URL:http://... si URL1:http://...). Nu are posibilitatea de a incarca webtv list.m3u
    3. Youtube functioneaza, dar cand am incercat sa incarc melodia lui Missy Elliot: WTF, imi da check your age si nu o ruleaza, iar de schimbat varsta pt youtube nu ma prind de unde.
    4.Nu are Boot Channel pe un anume canal TV.
    5.Nu intra singur in stand-by cand inchid TV-ul(conectat prin HDMI la Amiko), ramanand pe programul TV mult si bine(TV inchis din telecomanda).
    6. DVB-C-ul se vede corect si la fel de bine ca si la alte versiuni.
    7.Nu are Youporn si altele la fel in aplicatii( super!)
    8.Nu afiseaza "boot" pe display la pornire, doar on si atat.
    9.Dupa un hard reboot tot pierde setarile din system si trebuie refacute( asta-i la fel si la alte firmware-uri, deh chinezarie ieftina)
    Nu am testat mediaplayer-ul ca nu il folosesc
  11. #251
    Softurile (cu boot channel ,hdmi cec , aplicații extra) sunt de la alte mărci de receptoare cu acelasi chipset și placă de bază.Fiecare producător implementează sw. in funcție de anumite politici de marketing și zonă geografică.Cele mai bune sw. după părerea mea , sunt cele de SabTitan III.
    Nu apar ca ciupercile după ploaie , sunt stabile și au foarte puține buguri.
    17 Feb 2017
    Ar fi bine daca ar pune si lb. Romana la setari. Cine se ocupa cu dezvoltarea softului,ca le-as da un email? PM daca nu-i voie...
  13. #253
    Și ce le spui celor de la dezvoltare , că folosești pe amiko un sw. de sab titan modificat?Parcă ți-am scris cum trebuie să procedezi pt. setările in limba romană...
    SAB Titan III sw. for Amiko 8250/60/70
    ALI3516_14000A00_RSP_locus01_mcas_starlight_1CA_1CI_2.4.20
    Multi CAS software(no key)
    17 Feb 2017
    Asa am facut cum ai spus,dar vreau si OSD-ul in RO si suportul in firmware. Am intrat pe pagina lor din olanda si le-am cerut RO in firmware. Le-am spus ca am un sab titan fara RO. Asta-i tot!
